Sapphire launches their Radeon RX 5700 Pulse series of Graphics Cards
Custom Navi GPUs are available today!
Sapphire has officially released its Radeon Navi RX 5700 Pulse series of graphics cards, offering purchasers a custom cooling solution, dual UEFI and a set of unique features within the company's TriXX overclocking utility.
With its PULSE series of Navi graphics cards, Sapphire is offering its users a Dual-X cooling solution with replaceable quick-connect fans, offering superior thermals to AMD's reference cooling solution while also allowing users to replace their fans with ease in the event of damage. This makes the Radeon 5700 Pulse's RMA process a lot easier.
Both the RX 5700 Pulse and RX 5700 XT Pulse are available starting today in the UK, shipping with prices of £364.99 and £424.99 at Overclockers UK respectively. Below are the specifications of Sapphire's RX 5700 Pulse series of graphics cards. Please note that higher-end models are expected from Sapphire in the future, likely in the form of a Nitro+ model.
Both RX 5700 Pulse models ship with 8+6-pin power config, with Sapphire recommending a 600W power supply at a minimum.
Sapphire RX 5700 XT PULSEAMD RX 5700 XT 50thAMD RX 5700 XTSAPPHIRE RX 5700 PULSEAMD RX 5700
Process Tech/ Architecture7nm Navi7nm Navi7nm Navi7nm Navi7nm Navi
Stream
Processors
25602560256023042304
Base Clock 1670MHz1680MHz1605MHz1540MHz1465MHz
Gaming Clock1815MHz1830MHz1755MHz1700MHz1625MHz
Boost Clock1925MHz1980MHz1905MHz1750MHz1725MHz
Memory8GB GDDR68GB GDDR68GB GDDR68GB GDDR68GB GDDR6
Memory Bus256-bit256-bit256-bit256-bit256-bit
Memory Clock14Gbps14Gbps14Gbps14Gbps14Gbps
Memory
Bandwidth
448GB/s448GB/s448GB/s448GB/s448GB/s
You can join the discussion on Sapphire's Radeon RX 5700 Pulse series of graphics cards on the OC3D Forums
«Prev 1 Next»
