PNY leaks their RTX 2080 & RTX 2080 Ti XLR8 series and specifications
Well done PNY...
Published: 18th August 2018 | Source: PNY - Via Reddit user SassyBlackyJackyChan |
Below we have information from PNY which lits the TDP, CUDA core count and images of the company's upcoming XLR8 designs, though please note that these graphics cards are listed as overclocked models, which means that we should expect lower clock speeds from Nvidia's reference design.
The pricing below appears to be a placeholder value, with the RTX 2080 Ti sitting at $1000 while the RTX 2080 costs $800. Final pricing is expected to be lower.
The web pages for each graphics card also makes a note of Real-Time Ray Tracing, AI Enhanced Graphics and support for SLI via NVLink. This seems to indicate that both Nvidia's RT cores and Tensor cores will be active in Nvidia's gaming lineup.
Below are the specifications of PNY's Turing-powered RTX 2080 XLR8 and RTX 2080 Ti XLR8, both of which have unique triple fan cooler designs. Both graphics cards are fed by dual 8-pin PCI power connectors and have a TDP of 285W, though some of this TDP likely comes from the 30W power requirements of the VirtualLink standard.
PNY RTX 2080 Ti XLR8 | PNY RTX 2080 XLR8 | |
Architecture | Turing | Turing |
CUDA Cores | 4,352 | 2944 |
Tensor Cores | ??? | ??? |
Base Clock | 1350 MHz | ??? |
Boost Clock | 1545MHz | 1710MHz |
GPU Memory Type | GDDR6 | GDDR6 |
GPU Memory Capacity | 11GB | 8GB |
Memory Bus Size | 352-bit | 256-bit |
Memory Bandwidth | 616 Gbps | 448 Gbps |
TDP | 285W | 285W |
Power | 2x 8-pin | 2x 8-pin |
SLI | Via NVLink | Via NVLink |
You can join the discussion on PNY's RTX 2080 and RTX 2080 Ti specifications leaks on the OC3D Forums.
Avoid.
Mind you it does get your brain going huh? if this toss of the toss card is a bag of sand how much is a Strix going to be?Quote
