Nvidia reveals the specifications of their Geforce RTX 2080 Ti, RTX 2080 and RTX 2070
How well does Turing compare to Pascal?
When Nvidia officially announced their Geforce RTX series of graphics cards, they spent little time talking about their specifications in detail, aside from references to their respective Ray Tracing performance.
Sadly, these specifications can only provide us with a limited amount of detail, as Nvidia's new Turing SM units are said to increase their performance in ways outside of traditional clock speed boosts, making normal TFLOPS-to-TFLOPS comparisons inaccurate. Nvidia has also revealed no performance comparisons outside of Ray Traced applications, again giving gamers limited data with regards to real-world performance within today's gaming workloads.
Nvidia's website also reveals little detail regarding the AI/Tensor performance of their Geforce Turing graphics cards, again leaving gamers without exact information.
Alongside their Turing announcement, Nvidia also confirmed that their Turing series graphics cards would be moving away from traditional SLI bridges, replacing them with NVLink, which provides connected GPUs with a higher bandwidth connection that is suitable for higher resolutions and framerates. Nvidia's NVLink bridges will cost £75 each in the UK and can span either three or four PCIe slots.
Unlike previous XX70 series models, Nvidia has opted to release their RTX 2070 without SLI/NVLink support, removing Multi-GPU support.
Nvidia Founders Edition Graphics Geforce RTX 2080 TiGeforce GTX 1080 TiGeforce RTX 2080Geforce GTX 1080 Geforce RTX 2070
Geforce GTX 1070 TiGeforce GTX 1070
ArchitectureTuringPascalTuringPascalTuringPascalPascal
CUDA Cores4,352358429442560 230424321920
Tensor Cores???N/A???N/A???N/AN/A
Ray Tracing Performance10 Gigarays-8 Gigarays-6 Gigarays--
Base Clock
1350MHz1481MHz1510Mhz1607MHz1410MHz1607MHz1506MHz
Boost Clock1635MHz1582MHz1800MHz1733MHz1710MHz1683MHz1683MHz
Memory TypeGDDR6GDDR5XGDDR6GDDR5XGDDR6GDDR5GDDR5
Memory Capacity11GB11GB8GB8GB8GB8GB8GB
Memory Speed14Gbps11Gbps14Gbps10Gbps14Gbps8Gbps8Gbps
Memory Bandwidth616GB/s484GB/s448GB/s320GB/s448GB/s256GB/S256GB/s
Memory Bus Size352-bit352-bit256-bit256-bit
256-bit256-bit256-bit
SLIVia NVLinkSLIVia NVLinkSLIN/ASLISLI
Nvidia's RTX 20 series graphics cards are already available to pre-order within the UK, pricing info is available here
You can join the discussion on Nvidia's RTX 2080 Ti, 2080 and 2070 specifications on the OC3D Forums
«Prev 1 Next»
20-08-2018, 16:59:55
TheF34RChannel
VHS. It looks like a VHS tape.Quote
20-08-2018, 17:04:48
WYP
Once you see it you can't unsee it.Quote
20-08-2018, 17:18:58
TheF34RChannel
Ha! So true Quote
20-08-2018, 17:20:06
AlienALX
Be kind, please rewind.Quote
20-08-2018, 20:03:59
HJ1mech
I know ill be getting the EVGA 2080 ti FTW3....as much as i may resist.Quote
