Look ma, no fans! Palit releases their passively cooled GTX 1650 KalmX
Please note that this is a GTX 1650, not a Nvidia GTX 1650 Super. Nvidia’s GTX 1650 Super is actually a cut-down GTX 1660, which uses a different Turing chip and consumes too much power to be suitable for a passive cooler of this size. Palit’s GTX 1650 KalmX requires no external power and fits within a 75W power envelope, which is the primary reason why this graphics card can be passively cooled.Â
Palit cools this graphics card with two nickel-plated heat pipes and a large volume of nickel-plated fins, using a copper base to connect with the KalmX’s main components. This graphics card is designed to be a value component, which means that this graphics card shouldn’t cost much more than normal GTX 1650 graphics cards.Â
By default, this graphics card will ship with a base clock speed of 1485MHz and a boost clock speed of 1665MHz and I/O-wise, this graphics card features an HDMI 2.0b port and two DisplayPort 1.4a connections.Â
 Â
You can join the discussion on Palit’s passively cooled GTX 1650 KalmX graphics card on the OC3D Forums.Â
