LG reveals their 34GK950G and 34GK950F Nano IPS G-Sync and FreeSync displays
Need a Gaming-oriented Nano IPS 3440x1440 monitor?
LG reveals their 34GK950G and LG 34GK950F Nano IPS G-Sync and FreeSync displays
At IFA 2018, LG has unveiled two gaming-oriented displays for ultra-high-end PC gamers, both of which offer resolutions of 3440x1440 and high refresh rate playback.
These two monitors are designed to cater to the opposing sides of the PC market, with the 34GK950G supporting G-Sync while the 34GF950F supports VESA Adaptive-Sync and FreeSync 2. Both monitors use an LG "Nano IPS" display, which used a flicker-free W-LED backlight with a KSF phosphor layer to deliver 98% coverage of a DCI-P3 colour space.
From here on, both monitors become very different, with the G-Sync variant supporting a 100Hz refresh rate and a 120Hz overclocked mode while the FreeSync version supports a full 144Hz refresh rate without any need to overclock. In modern displays, "Overclocking" refers to the limiting of colour depth, chroma or other bandwidth-heavy features to enable support for higher maximum refresh rates. This makes the FreeSync version of this display superior in terms of image quality, at least when compared to the G-Sync version when running at its overclocked 120Hz mode.
Why is the G-Sync version so limited? The 34GK950G only offers support for DisplayPort 1.2 and provides an 8-bit colour depth, whereas the FreeSync 34GK950F supports DisplayPort 1.4, which delivers the ability to support higher refresh rates without compromises.  The FreeSYnc version also supports HDMI 2.0, while the G-Sync version only supports HDMI 1.4, suggesting that it doesn't use Nvidia's latest DisplayPort 1.4 complaint G-Sync module.
Both monitors support a peak brightness of 400 nits, which is low as far as HDR compliance goes, though it is enough to grant the FreeSync version a full FreeSync 2 certification. The FreeSync version also offers support for 10-bit colour depths (8-bit + FRC). Both models feature stand with tilt, height and swivel options, though the G-Sync version also features LG's "Sphere Lighting" system on the rear of the monitor.
Right now, the G-Sync version of this monitor is set to ship in November for an MSRP of €1399. The pricing and release date of the FreeSync version remains unknown, though it is expected to release within a similar timeframe.
You can join the discussion on LG's 34GK950G and LG 34GK950F Nano IPS G-Sync and FreeSync displays on the OC3D Forums
«Prev 1 Next»
31-08-2018, 15:00:22
tolagarf
Originally Posted by WYP View Post
The FreeSync version offers a higher Refresh rate
That is due to nvidia not bothering to update their old G-Sync module (the non-HDR version). This effectively caps it at 120 Hz.
It's definitely a screen I've got my eye on. I hope there's isn't a huge difference in price between the two models.Quote
31-08-2018, 15:03:45
NeverBackDown
What a rip off. 1300 Euros for a GSync monitor that is using the old module.Quote
31-08-2018, 16:51:28
atomicus
Let's say you ran a 2080Ti on either of these monitors... with such a powerful GPU, would you miss G-Sync on the Freesync version? I really don't know as I've never had a GPU that can seriously push a monitor before, but have seen G-Sync benefit at lower FPS for sure.Quote
31-08-2018, 19:30:14
Dawelio
Here's a video on it, if I understood your question correctly:
https://www.youtube.com/watch?v=j_KFd8TASdc
But yes, in my experience, G-Sync does help a lot.Quote
31-08-2018, 21:04:04
tolagarf
I wonder how long it will take before a proper hack comes around that let's you do this without an AMD APU or GPU. Actually I'm surprised it hasn't happened yet, considering the G-Sync enabled notebooks are all software based on adaptive sync anywayQuote
