Geforce RTX 2080, 2070 and 2060 mobile specs leaked by Chinese manufacturer
Geforce RT 2080, 2070 and 2060 mobile specs leaked by Chinese manufacturer
It has long been speculated that Nvidia’s RTX series of mobile graphics cards will be launched at CES 2019 alongside Nvidia’s RTX 2060 graphics card.  This means that Q1 2019 is set to receive a large number of GPU launches, ushering in a range of new gaming notebooks and other systems.
The Chinese OEM CJSCOPE has released details for their planned HX-970 gaming notebook, which packs Intel’s Z370 chipset, desktop-grade LGA 1151 processors and RTX 2080, 2070 and 2060 MXM graphics cards, all of which are listed as overclocked models.
A launch date of January 15th is also listed, supporting rumours that Nvidia’s RTX 2060 will be launched at CES 2019.
Looking at CJSCOPE’s specifications, Nvidia’s RTX 2080 and RTX 2070 mobile graphics cards will offer specifications that are similar to their desktop Founders Edition counterparts, though these graphics cards are listed as overclocked models. Nvidia’s reference mobile specifications are expected to be close to Nvidia’s desktop reference specs.
  RTX 2080 Ti FE RTX 2080 FE RTX 2080 Mobile MXM OC RTX 2070 FE
RTX 2070 Mobile MXM OC RTX 2060 Mobile MXM OC GTX 1060 6GB FE
Architecture Turing Turing Turing Turing Turing Turing Pascal
CUDA Cores 4,352 2944 2944  2304 2304 1536 1280
Ray Tracing Performance 10 Gigarays 8 Gigarays ??? 6 Gigarays ??? ???
Base Clock
1350MHz 1510Mhz 1515MHz 1410MHz 1410MHz 1320MHz 1506MHz
Boost Clock 1635MHz 1800MHz 1847MHz 1710MHz 1740MHz 1620MHz 1708MHz
Memory Type GDDR6 GDDR6 GDDR6 GDDR6 GDDR6 GDDR6 GDDR5
Memory Capacity 11GB 8GB 8GB 8GB 8GB 6GB 6GB
Memory Speed 14Gbps 14Gbps 14Gbps 14Gbps 14Gbps 14Gbps 8Gbps
Memory Bandwidth 616GB/s 448GB/s 488GB/s 448GB/s 448GB/s 366GB/s 192GB/s
Memory Bus Size 352-bit 256-bit 256-bit 256-bit 256-bit 192-bit 192-bit
You can join the discussion on Nvidia’s leaked RTX 2080, 2070 and 2060 mobile specifications on the OC3D Forums.Â
