AMD Ryzen 5000U Mobile CPU specs leak - A mix of Zen 2 and Zen 3
Faster clocks and a confusing naming scheme
Following their leak of AMD's Ryzen 5 5600U specifications, ExecutableFix has revealed the specifications of AMD's entire Ryzen 5000U mobile GPU lineup, revealing processors which higher CPU/GPU clock speeds, more GPU CUs and SMT across the entire range.
If these leaks are accurate, AMD will be releasing their Ryzen 5000U CPU lineup with both Zen 3 and Zen 2 processors, launching Cezanne (Zen 3) and Lucienne (Zen 2) processors. Lucienne is a refined iteration of today's Ryzen 4000-series Renoir processors, while Cezanne is AMD's Zen 3 based Renoir successor.
What we don't like about this is that AMD's entire Ryzen 5000 series won't be based on Zen 3. It allows customers to purchase systems with Zen 2 processors in error, giving them less performance than expected.
All of these new processors will feature configurable TDPs of between 10W/25W and are due to deliver higher performance levels and greater power efficiency than their predecessors. AMD's new Zen 3 Cezanne SKUs are also reported to feature L3 cache sizes as large as 16MB, doubling Cezanne's L3 cache sizes over that of Renoir.
GPU-wise, AMD's Ryzen 5000 series processors will all feature higher GPU clock speeds and lower-end models will all feature higher GPU core counts. This change will allow AMD to combat the integrated graphics performance of Intel's Tiger Lake series processors. Both Cezanne and Lucienne reportedly use Radeon Vega graphics.
At this time, it is unclear when AMD will reveal its Cezanne series of Ryzen mobile processors. AMD could unveil their next generation of Ryzen mobile processors at CES 2021, highlighting their performance and efficiency gains over today's Renoir offerings.
Ryzen 5000 SeriesZen CoreCores/ThreadsBase ClockBoost ClockL3 CacheGPU CUsGPU Clock
Ryzen 7 5800UZen 38/162.0 GHz4.4 GHz16MB82.0 GHz
Ryzen 7 5700UZen 28/161.8 GHz4.3 GHz8MB81.9 GHz
Ryzen 5 5600UZen 36/122.3 GHz4.2 GHz12MB71.8 GHz
Ryzen 5 5500UZen 26/122.1 GHz4.0 GHz8MB71.8 GHz
Ryzen 3 5400UZen 34/82.6 GHz4.0 GHz8MB61.6 GHz
Ryzen 3 5300UZen 24/82.6 GHz3.85 GHz4MB61.5 GHz
Ryzen 4000 Series
Ryzen 7 4800UZen 28/161.8 GHz4.2 GHz8MB81.75 GHz
Ryzen 7 4700UZen 28/82.0 GHz4.1 GHz8MB71.6 GHz
Ryzen 5 4600UZen 26/122.1 GHz4.0 GHz8MB61.5 GHz
Ryzen 5 4500UZen 26/62.3 GHz4.0 GHz8MB61.5 GHz
Ryzen 3 4300UZen 24/42.7 GHz3.7 GHz4MB51.4 GHz
You can join the discussion on AMD's Ryzen 5000U series of mobile processors on the OC3D Forums
«Prev 1 Next»
