Seagate Barracuda 7200.10 750 GB SATA Hard Drive
Specifications and Perpendicular Recording
Specifications
Seagate list the Barracuda 7200.10 as "the Highest Capacity 3.5-inch disc drive". Sustained data transfer is listed as 78Mbytes/sec, with a spin speed of 7200RPM.
Quick Features:
seagate 7200.10 750 gb
We'll see if the drive lives up to its claimed speed later on.
Seagate offer a 5 year Warranty on this drive. It's always nice to know that your drive will be replaced if anything unseen happens to it. This does not extend to your data, of course.
The Seagate has Native Command Queuing as one of its features. This feature means that the drive prioritises it's access requests to best utilise the way in which it is spinning. This isn't so useful for one user workstation, unless you are heavily multitasking the HDD. However, in situations such as a home media server, this leads to better response time for the PC's giving the requests.
Seagate's 7200.10 features perpendicular recording. This is a pretty exciting feature in a Hard Drive. Perpendicular recording allows the drive to record the data vertically onto the drive surface. This is compared to normal drives that record in a linear fashion. This means that the drive permits much higher data density per square inch. The drive platters are slightly thicker than traditional hard drives, with a soft underlayer.
Another advantage to perpendicular recording is that where data from longitudinal recording is very dense, this can cause the particle magnetic orientation to flip and this can cause data corruption as a result. This means that longitudinal hard drives have to leave a larger space between the data as if it gets too dense this will cause data loss. Perpendicular recording means that the data stored vertically does not get as dense. This means that it can record far denser data. It is claimed that perpendicular recording produces 1 Tb/in², 5-10 times that of longitudinal recording, which maxes out at 100 to 200 Gb/in².
For more info check Hitachi's site for a pretty "flash" animation on the technology here
seagate 750gb
Now I've blinded you with the science, lets take a look at the test setup, then what you can actually expect from this behemoth
«Prev 1 2 3 4 5 6 Next»
07-07-2005, 04:11:19
balilu
"... ..for the amount of money you are paying you are getting a drive that is one of the fastest drives available as well as the largest in capacity, which in my opinion is worth paying a premium price for."
http://hi-techreviews.com/reviews/7K500/hitachi.htmlQuote
07-07-2005, 04:33:42
bloodthirst
yes and its also sata II
ay from the picture in the link.... im not very familiar with sata but that looks ide?Quote
07-07-2005, 05:13:03
limqareb
do all mobo support it?Quote
