Kingston SSDNow V+ 64GB
Synthetic Benchmarks
Published: 4th December 2009 | Source: Kingston | Price: £133.40 |
HDTach
HDTach isn't the perfect benchmark for testing SSD drives as the results can be sporadic under certain circumstances. However, the benefit it does have is providing a result that is very clear to understand, especially in terms of pure sequential data read performance.
As you can see from the graph on the left, the Kingston SSDNow V+ stays around the 200MBps mark, which is very good for a drive around this price point. It also highlights the main benefit of SSDs (pure speed aside) in that regardless of where the information is held, the speeds returned are the same. In contrast the F1 remains typical with all platter drives in that it starts able to read the data quite quickly, although please note that the scale on the vertical axis is different to the SSD graph, but very obviously slows as the data moves to the outside of the disk.
Everest Random Read
Lavalys' Everest provides a better method than HDTach for testing the latest high-performance storage solutions. For the purposes of this test both the Samsung and Kingston were put under the Everest Random Read test. The Samsung results approximately mirrored those of the ATTO read test below, but as the graph is so jumbled as to be no use it has been left out for clarity.
The Kingston SSDNow V+ provided a very stable result across the entire drive with the peak read speed surpassing the magical 220MB/s barrier, and with the minimum read speed obtained only going down to the 162MB/s mark, another very impressive result for the Kingston here.
ATTO Benchmark
The ATTO benchmark tests multiple sizes from 512bytes all the way up to 8MB. However, really the important tests are tiny files and the largest one, as there isn't much performance difference to be seen between a 1MB file and a 8MB one.
The tests were run three times and the average result calculated. As you can see from our results the Kingston SSDNow V+ got within 2MB/s of the potential read speed of the Samsung layout with the 8192KB test, and the write speed even surpassed the manufacturers claims of 140MB/s in both the 8192KB test and the 32KB test. Highly impressive. Nearly double the performance of the Samsung in both read and write testing should help dispel the doubts of those who cling to their platters.
If the read speeds are impressive, the write speeds are fantastic.
So far in the theoretical tests the Kingston has performed as well as could be hoped. Whilst some of the sustained speeds haven't been as impressive as very high-end SSDs, nonetheless it's proving that under ideal conditions it is exceptional value.
On the next page we'll look at the last synthetic before moving on and seeing if PCMark's benchmark suite shows that these speeds are obtainable in actual use conditions.
Very nice review mate, after reading;
"Luckily you aren't the type who want the quick answer otherwise you'd have skipped on to the conclusion", I decided to continue reading as I am the kind of person referred to that skips on !
I do agree that an SSD is the best performance upgrade for a PC, however the price is still way too high and unfortunately it doesn't look like it will be dropping soon. That said, I know I will have one/three soon ! Good job.
damn tempting for Red October Mk2... really want something a bit bigger, but £130 for a fast as hell drive is tempting, and I imagine 64gb is enough for Windows 7 and a handful of games... damn you, I want this now!
Still, those write speeds are very impressive, anyone know how much the 128Gb model costs?
Nice review VB of a decent budget drive, it would deffo make a nice boot drive
I'm managing to resist buying anything until the new year becasue I think once the sata3 ssd's arrive the sata2 tech should drop in price.
going on play.com for £120... is that the same drive?
http://www.play.com/PC/PCs/-/2358/1625/-/11924385/Kingston-SSDNow-V-Series-64GB-SSD-2-5-Internal-SATA-Hard-Drive-With-Desktop-Accessory-Kit/Product.html?searchtype=genre#
Cause if it is I might just buy one, or get Santa to get me one
http://www.play.com/PC/PCs/-/2358/1625/-/11924385/Kingston-SSDNow-V-Series-64GB-SSD-2-5-Internal-SATA-Hard-Drive-With-Desktop-Accessory-Kit/Product.html?searchtype=genre# Cause if it is I might just buy one, or get Santa to get me one |
Where are you seeing it for £130?
Great review.
All we really need now is for another company to undercut Kingston by £20 and the cycle of sanity can continue.
I do agree that the pricing of this is 'good' in comparison with it's fellow suspects, but on the whole, whilst also considering the traditional drive it's reviewed against, I strongly disagree with the 9 rating in the price category. I personally think ssds should start with a '5' rating handicap on general principle.
What does bother me is whilst it boots an OS nicely faster by some 10-15s usually, the files in consideration against the game loading are not a fair template for comparison. What I took from it is that forgiving 10-15s, the traditional harddrive is an awesome purchase, whilst ssds are what they are.
If a traditional harddrive comes out with a 128mb (or even 64mb) cache, the ssd drive will look pretty poor. This ofc will only happen with those manufacturers who don't make ssds.
All scores for pricing within reviews are taken against similar products.
Otherwise the HD5970 should get 1 because you can get a X1950 for £20. Logical fallacy.
That an@logy has never worked for me. I can't think of anything relevant to today that the X1950 could do better than the HD5970. Mode promote to an external tv whilst using mpclassic perhaps as the drivers are old enough and u could use an unupd8d xp.
Whereas the F1 can do what HDD's were designed for alot more than all but 1 (that I know of) single SSD can. And that's to store more pr0n, I mean data.
It's not an analogy. It's pointing out that your argument is invalid.
HDDs are not priced comparably to SSDs, nor even are they in competition with them. The sole feature is that they both store data. Thusly HDDs are not taken into account when scoring the price.
Maybe the F1 can do what HDDs are designed to do. But in case you didn't notice this is an SSD review.
HDDs are not priced comparably to SSDs, nor even are they in competition with them. The sole feature is that they both store data. Thusly HDDs are not taken into account when scoring the price. Maybe the F1 can do what HDDs are designed to do. But in case you didn't notice this is an SSD review. |
And u need to rethink - thinking that SSDs are not in competition with HDDs. They each have more than just the unique feature to store data.
If u also didn't notice, the F1 is used as a comparison more-or-less through-out the review.
Infact, what the fudge was the point in posting what u just posted ?
It is very difficult to justify a price tag like that on what is essentially a 64gb hard drive. Sure it's priced well compared to the competition, but the competition is priced at laughable levels.
Good review all the same
Anyone seen one in stock at any reputable re/e-tailer?
me want!
Continue Reading
