Kingston SSDNow V+ 64GB
Technical Specifications and Test System
Published: 4th December 2009 | Source: Kingston | Price: £133.40 |
Technical Specifications and data-sheet
The Kingston SSDNow V+ series come with a three-year warranty and 24/7 technical support.
The Data sheet taken directly from the Kingston webpage, viewable here are :
Features :
o Innovative – Uses MLC NAND flash memory components.
o Silent – Runs silent and cool with no moving mechanical parts.
o Shock Proof – No moving mechanical parts so the SSD handles rougher conditions.
o Supports S.M.A.R.T. – Self-Monitoring, Analysis and Reporting Technology tells the user when a drive is about to fail
o Guaranteed – 3 year legendary Kingston warranty, 24/7 tech support
Data-sheet and Technical Specifications :
o Sequential Read Throughput – 64GB, 128GB, and 256GB - 220MB/s
o Sequential Write Throughput – 64GB - 140MB/s, 128GB - 170MB/s, 256GB - 180MB/s
o Form Factor – 2.5"
o Interface – SATA 1.5 Gb/sec. and 3.0 Gb/sec
o Capacity* – 64GB, 128GB, 256GB
o Storage temperatures — -40 - 85°C
o Operating temperatures — 0 ~ 70°C
o Dimensions — 69.85 x 100 x 9.5 mm
o Weight — 84 gram
o IOPS** (Input and Output Operations Per Second) —
Random 4K read: 6300 IOPS
Random 4K write: 64GB = 84 IOPS
Random 4K write: 128GB = 158 IOPS
Random 4K write: 256GB = 291 IOPS
o Vibration operating — 2.7G
o Vibration non-operating — 20G
o Power specs — 2.6 W - active / 0.15W Idle
o Life expectancy** — 1,000,000 Hrs mean time before failure
o Operating shock — 1500G
o Weight — 84 gram
So far, nothing particularly earth shattering and about on par with other offerings using the Samsung combination.
Test Setup
For the battery of tests we're running today we're using an i7 system to ensure that the other parts of the PC can provide the data as swiftly as possible. We're also be comparing results against a Samsung Spinpoint F1 1TB, to see if the speed increase is sufficient that the reasonable pricing makes it worth the jump to SSD.
CPU : Intel Core i7 920 @ 3GHz
Motherboard : Biostar T-Power X58A using the A13 BIOS dated 13/10/09
RAM : 6GB Corsair Dominator GT @ 1600MHz
GPU : ASUS 4870X2
OS : Windows 7 64 Bit
Drives : Kingston SSDNow V+ 64GB. Samsung Spinpoint F1 1TB
GPU : ASUS 4870X2
Very nice review mate, after reading;
"Luckily you aren't the type who want the quick answer otherwise you'd have skipped on to the conclusion", I decided to continue reading as I am the kind of person referred to that skips on !
I do agree that an SSD is the best performance upgrade for a PC, however the price is still way too high and unfortunately it doesn't look like it will be dropping soon. That said, I know I will have one/three soon ! Good job.
damn tempting for Red October Mk2... really want something a bit bigger, but £130 for a fast as hell drive is tempting, and I imagine 64gb is enough for Windows 7 and a handful of games... damn you, I want this now!
Still, those write speeds are very impressive, anyone know how much the 128Gb model costs?
Nice review VB of a decent budget drive, it would deffo make a nice boot drive
I'm managing to resist buying anything until the new year becasue I think once the sata3 ssd's arrive the sata2 tech should drop in price.
going on play.com for £120... is that the same drive?
http://www.play.com/PC/PCs/-/2358/1625/-/11924385/Kingston-SSDNow-V-Series-64GB-SSD-2-5-Internal-SATA-Hard-Drive-With-Desktop-Accessory-Kit/Product.html?searchtype=genre#
Cause if it is I might just buy one, or get Santa to get me one
http://www.play.com/PC/PCs/-/2358/1625/-/11924385/Kingston-SSDNow-V-Series-64GB-SSD-2-5-Internal-SATA-Hard-Drive-With-Desktop-Accessory-Kit/Product.html?searchtype=genre# Cause if it is I might just buy one, or get Santa to get me one |
Where are you seeing it for £130?
Great review.
All we really need now is for another company to undercut Kingston by £20 and the cycle of sanity can continue.
I do agree that the pricing of this is 'good' in comparison with it's fellow suspects, but on the whole, whilst also considering the traditional drive it's reviewed against, I strongly disagree with the 9 rating in the price category. I personally think ssds should start with a '5' rating handicap on general principle.
What does bother me is whilst it boots an OS nicely faster by some 10-15s usually, the files in consideration against the game loading are not a fair template for comparison. What I took from it is that forgiving 10-15s, the traditional harddrive is an awesome purchase, whilst ssds are what they are.
If a traditional harddrive comes out with a 128mb (or even 64mb) cache, the ssd drive will look pretty poor. This ofc will only happen with those manufacturers who don't make ssds.
All scores for pricing within reviews are taken against similar products.
Otherwise the HD5970 should get 1 because you can get a X1950 for £20. Logical fallacy.
That an@logy has never worked for me. I can't think of anything relevant to today that the X1950 could do better than the HD5970. Mode promote to an external tv whilst using mpclassic perhaps as the drivers are old enough and u could use an unupd8d xp.
Whereas the F1 can do what HDD's were designed for alot more than all but 1 (that I know of) single SSD can. And that's to store more pr0n, I mean data.
It's not an analogy. It's pointing out that your argument is invalid.
HDDs are not priced comparably to SSDs, nor even are they in competition with them. The sole feature is that they both store data. Thusly HDDs are not taken into account when scoring the price.
Maybe the F1 can do what HDDs are designed to do. But in case you didn't notice this is an SSD review.
HDDs are not priced comparably to SSDs, nor even are they in competition with them. The sole feature is that they both store data. Thusly HDDs are not taken into account when scoring the price. Maybe the F1 can do what HDDs are designed to do. But in case you didn't notice this is an SSD review. |
And u need to rethink - thinking that SSDs are not in competition with HDDs. They each have more than just the unique feature to store data.
If u also didn't notice, the F1 is used as a comparison more-or-less through-out the review.
Infact, what the fudge was the point in posting what u just posted ?
It is very difficult to justify a price tag like that on what is essentially a 64gb hard drive. Sure it's priced well compared to the competition, but the competition is priced at laughable levels.
Good review all the same
Anyone seen one in stock at any reputable re/e-tailer?
me want!
Continue Reading
