Kingston 266X 4GB Compact Flash Card
Test Setup and Notes
Test Setup
For this review I am using the following PC:
Intel Xeon 3070 @ 3.3GHz
Abit IP35 Pro
Cellshock PC6400 @ 1100MHz 5-5-5-15
MSI 8800 GTX
Hitachi Deskstar 7K160
I am using the external card reader on my Dell 2405FPW plugged into one of the rear USB ports on the motherboard.
I am using Windows Vista Ultimate for testing.
Comparison Cards
1GB PNY Compact Flash P-CF1GB-BX
2GB Sandisk Extreme III Compact Flash Card
comparison cards
Testing
Each test was performed three times for consistency. Read/Write tests were timed using a stopwatch. The PC was rebooted and the reader unplugged between tests in order to ensure that no files were cached.
Read/Write File test
Folder of 645MB containing 252 pictures. Written from hard drive of PC to the CF card and then written back again.
HD Tach
Burst Speed and Average Read
SiSoft Sandra External Storage Test
To get a "feel" of the speed of the card in a real situation I took several lots of pictures using my Canon EOS 400D. Shots taken were in normal shoot mode (indoors with flash) and "Sports Mode" (set of 10 consecutive pictures). Although no exact measurement was taken I wanted to see how fast the cards felt when doing this.
card installed
Note that an external card reader was used for testing and as such speeds reached were limited to this.
«Prev 1 2 3 4 5 Next»
28-08-2007, 14:25:18
FarFarAway
Check out what it's like hereQuote
