Icy Box IB-MP301 HDD Media Player
Installation & Setup
Search Reviews
Installation
Getting the IB-MP301 up and running couldn't be easier. Simply open the side of the unit by unscrewing the four large black screws and lift out the plastic side panel. Once inside you are presented with an IDE cable and a molex connector. These need to be connected to the hard disk you have chosen for the unit (in this case an 80gb Hitachi Deskstar).
Icy Box IB-MP301 Inside Icy Box IB-MP301 Hard Disk
Once you have re-assembled the unit, connect the power and USB leads. The Icy Box will first check the hard disk is installed and then perform a quick scan of the files on it. Once this is completed, the device will be detected under Windows as a standard hard disk.
If the hard disk you've installed is brand new, it will need to be formatted using the FAT32 file system. Unfortunately, due to an operating system limitation, Windows 2000 and above are only able to format up to 32GB when using FAT32 (see Microsoft KB article here). However, Raidsonic do have a DOS based utility that can be downloaded from their website (here) that allows the disk to be formatted up to its maximum size.
Setup
With the disk installed and formatted, you will then be able to transfer files to the Icy Box and access the main setup menu using the remote control. The following images have been taken directly of my LCD display with the IB-MP301 connected.
IB-MP301 Setup IB-MP301 Setup
A comprehensive range of options are available under the 6 menu headers, and navigation around the menu's is easy using either the remote control or the directional buttons on the front of the unit. One thing I did find disappointing was the lack of any options to do with the installed hard disk. In my opinion it would be beneficial for users to be able to format the hard drive using the menu system and even check the current space left available on the device without needing to connect it to a PC.
«Prev 1 2 3 4 5 Next»
12-07-2007, 06:30:12
Jim
"Looking for easy access to your MP3, video and image collections via your TV without the need for an expensive HTPC setup? Maybe Icy Box have the answer with their HDD Media Player."
http://www.overclock3d.net/gfx/artic...224003620s.jpg
Linky
12-07-2007, 07:24:23
Rastalovich
Great read m8. All through the descriptions I kept stopping and thinking "hmm ageing tech.." - then getting to the end and seeing the price tag, it`s pretty decent.
I couldn`t see myself buying it to house my DVD collection, as frankly it wouldn`t fit (limiting to 500g), but I could however see myself filling it with all music, photos/pictures and maybe music videos. Even tho that`d probably only take perhaps a safe 200g.
For the price I think it`s great, not a movie thing for me tho.
12-07-2007, 07:32:27
Jim
Yeah agreed. In all honesty I can see it appealing more to people who download things like episodes of Lost, 24, Simpsons etc off the net (note: I don't condone this!) and just want to be able to watch it on a big screen without faffing around burning it to disks.
09-08-2007, 05:34:22
Barnie
one thing i will say is the manual is pretty poor, offers no problem solutions
09-08-2007, 05:43:12
Jim
Hi Barnie, What problems are you having? I'll try and give you a hand as I was the one who wrote the review. If not, we also have a supported Icy Box forum here: http://forum.overclock3d.net/forumdisplay.php?f=148
09-08-2007, 10:42:53
Xebedie
Hi There,
I wonder if, as the reviewer, you would be so good as to tell us what the solution was that Raidsonic provided you with to format a HDD in the unit.
I have formatted a 500g drive using mac OSX, which works ok except for the fact that the unit only recognizes 3000 of the media items stored on it.
When I try to format it using a windows XP machine, the unit doesn't recognize the disk at all.
I have tried to contact Raidsonic myself, but after three days they have not responded.
Yours
Xebedie
09-08-2007, 10:46:06
Barnie
hi as ive just done it i may be able to help
raidsonic were very quick in there reply to me
right some issues i had was, you have to use the fat32 system to format to which i didnt first time and it wont read
second was the jumpers were in the incorrect position but all good now
09-08-2007, 10:57:48
Xebedie
ok, great.
What's the best way to format in fat32 in XPSP2.. (i'm a mac person!)
XP only seems to give the option to format in NTFS (or whatever it is)...
09-08-2007, 12:18:09
Barnie
pass im not up on macs sorry
10-08-2007, 03:45:58
Xebedie
Hi Barney,
Ok, so I formatted the HDD for FAT32 on a PC... but I get the SAME PROBLEM... which is that the unit only recognizes the first 3000 media items. Everyone seems stumped on this... any thoughts anyone?
Xeb
10-08-2007, 04:26:56
!TIMMY!
Good review Jim, this is comething that i would be interested in. As you pointed out, if you could put for example freeview through the box and record off it, then this would be a must buy. I was surprised that the lack of s-video out, as all 3 of my t.v.'s have s-video in's
28-08-2007, 08:56:42
Pingman
I found your article after randomly seeing the Icybox Ib-MP301 for sale on SCAN, so did a quick google search to find out more. I must say, a very good article.
The reason i was interested in the Ib-MP301 is because i bought a simular product last year, The Rapsody RSH 110. CLICK ME
Just wondered what your opinion is on the Rapsody as it's very simular to the Icybox. Im over the moon with mine. Maybe you'd consider doing an official review if youcan get hold of one?
31-08-2007, 10:27:09
Deadman
First of all the player only supports FAT32 so use f.e. this software to format
http://www.compuapps.com/download/Swissknife/swissknife.htm
Second if you've not put any files on the drive like one avi file it will display "No Disk".
Thirdly unplug it from the USB (from the back of the UNIT also) before using it on a secondary monitor or TV otherwise it will be giving you problems.
and finally it wont let you copy files over 4GB do to fat32 limitations, and does not support high defination files.
Hope this helps.
05-09-2007, 10:38:25
micheal-murphy
hi i just bought an icy box and fitted a 500gb Seagate Barracuda IDE 16mb drive. When i hook the MP301 upto my pc, it doesn't detect it and the player displays "read" on its display and doesn't change. I know i have to format the drive in FAT32, but do i have to do this before i fit it into the player or can i do it through the usb at a later stage? I know it's probably somethin obvious I'm doing wrong. Any help would be much appeciated
08-09-2007, 13:02:31
carlt
I have the MP301 with a 500Gb drive partitioned as primary and formatted as FAT32.
Mine registers a maximum of 1,200 files at about 15% done and stops counting even though it continues to scan up to 100%. 3000 would be a luxury!
The current format was done with h2format.exe although I previously tried the same with swissknife.
I thought I could live with the 1,200 limit if I could get it to see the 1,200 I actually want to play. It seems to have read the folders in reverse order so I copied around 1,200 files to a folder called XMedia, so it was clearly the last folder. The MP301 just ignores it.
I've tried moving XMedia to various locations. I've tried different format tools and re-copying the files. It only ever sees the original 1,200 files. If I delete those leaving only XMedia, it sees nothing!
How can I get it to forget the first 1,200 it saw and scan again?
Better still, how can I get it to see the 10,000 files I actually have?
Can anyone help?
11-09-2007, 13:15:29
accumulator
This seems really good and cheap alternative to HTPC's. I am however only insterested as using it as sound server sort of.
Can someone tell me whether you can set this to randomly play all the MP3 files on the hard drive, or do you have to pick out certain tracks, using the remote. Can you also use this is without a screen? Can you pick out certain tracks to play or what?
Does anyone know whether remote is IR or is it wireless? The reason I ask is that I have Russound multi-room sound system in the house, which gives you six different inputs which are controlled by IR repeaters. I could set up two of these identically and have different music playing in various rooms.
11-09-2007, 13:40:42
carlt
I've not had mine long and not really got much use so far due to the problems above.
Anyway, I haven't seen a random play function mentioned. I'd be pleased if there is one though. There is a programming function to setup playlists or similar but it looks clunky.
You'll need a screen connected by VGA or composite to operate it.
The remore is definitely IR and is actually quite directional although not sure if that's because the sensor is weak or the transmitter puts out a narrow beam.
Hope that helps.
12-09-2007, 13:01:35
accumulator
Thanks for the info.
22-09-2007, 13:41:02
Furious
Hi, could you comment on the User Interface? Is it difficult to navigate? Also, is the fan loud or quiet?
Thanks.
Also i am curious to know how the firmware upgrade is performed?
12-10-2007, 16:23:37
Mind
Hi! I have the same problem... It just recognizes 1.200 files of more than 30.000 I stored... Any ideas on how to solve this? Is there something we can do on this?
Can anyone help?
12-10-2007, 16:46:14
Rastalovich
If u remove the 1200 it found out of the 30000, does it recognize 1200 different ones ?
12-10-2007, 18:56:14
Mind
Yes! It only recognizes 'the first' 1200 files placed in the HDD. I don't know how the device 'decides' what are 'the first' 1200...
13-10-2007, 04:54:40
carlt
Thanks.
The user interface is somewhat clunky. Worst part is that it is based on something like the old 8.3 file name limits so it displays about the first 6 characters of the filename followed by a number to keep them unique. Very difficult to see which file is which when they're called something like Friend_7.
It's a bit tricky to to navigate between videos, music and photos.
It can't get it to play music while browsing photos.
I can't see a random play function for photos and music.
The remote is very directional so I have to set directly in front of the box and point directly at it.
The fan isn't too loud but it seems to have a high pitched whine bordering on a squeal. The TV sound normally covers it.
The disk and fan don't seem to spin down on standby so I switch it off at the front panel.
I still have the 1200 files limit and am waiting for RaidSonic to develop new firmware. Not sure if that actually means there is some in the pipeline and whether it's a known fault which will definitely be fixed. It could be just a stock response.
Hope that helps.
13-10-2007, 04:59:55
carlt
My vendor gave me the choice of returning it or waiting for RaidSonic. I opted for the latter but many weeks have passed. If you have an option to return it and know a good alternative then I'd recommend you do that.
I've mailed Raidsonic to ask where my new firmware is. If I get a reply I'll post it.
There is no mention of a firmware update method in the manual. The sales blurb does say it is upgradeable. It's not stored on the HDD. I expect there's some kind of hidden maintenance mode to allow it to be sent over USB. I expect I'll find out if and when the firmware comes.
13-10-2007, 05:09:10
carlt
I tried some experiments along these lines.
It seems to somehow remember the original first 1200 files it saw, even between formats. Once it has those 1200 registered it won't see anything new. It has some kind of memory. Removing the 1200 meant that it saw nothing.
I created a folder called zMedia. That placed it last alphabetically but meant the box scanned it first. I copied the 1200 items I most wanted to see into there. It didn't see them, just the old 1200. I tried various things including reformats, front panel resets and factory resets from the menu. Then I gave up, switched off and left it a few days.
Strangely enough the next time I tried it, it picked up the 1200 in zMedia, so I now have access to some files I actually want to see. Perhaps leaving it alone helped it forget it's memory of the initial 1200 files?
I now have new ones to add so I'm hoping I can get it to do the same again somehow...
13-10-2007, 05:24:10
Mind
You said "some files". It means that you couldn't access to all the new 1200?
13-10-2007, 05:24:12
carlt
Here's the firmware update page at Raidsonic but there's nothing there for the IB-MP301 as yet. Watch this space:
Firmware
13-10-2007, 05:46:05
carlt
I can access all 1200 new files in zMedia.
When I said some I meant some of the thousands I would really like to see!
