Corsair V128 Nova Review
Chips, Test Setup and Windows 7
Search Reviews
No Fish, just Chips
Starting with the controller chip, and Indilinx Barefoot IDX110M01-LC. This is the same controller we saw used to such great effect on the Crucial M225. The LC designation shows that this is one of Indilinx cherry-picked chips from their Barefoot line.
This is also a revised variant which adds improvements to the general performance as well as, for the joy of us all, TRIM support in Windows 7. This is the key element as TRIM ensures the performance of the SSD doesn't degrade over time.
Corsair V128 Nova  Review     Corsair V128 Nova  Review
The cache is dealt with by an Elpida S51321DBH-6DTS-F. This is 64MB of CL3 cache which should eliminate all the stuttering early SSDs suffered with. As manufacturers have got to grips with the amazing performance available from Solid State Drive technology and implemented cache on all their models the stuttering is no longer the issue it was. However the Barefoot/Elpida combination has proven a highly successful partnership so we have high hopes that the advertised performance could be close to the truth.
Finally we have the storage itself. The two major players in the NAND world are Samsung and Intel. For the Nova Corsair have decided upon the Intel, and in this case the Intel 29F64G08CAMDB. These are 32nm NAND chips to provide 128GB of total storage.
Test Setup
As our Corsair Nova uses the Indilinx/Elpida/Intel combination we thought it would be good to put it up against an Indilinx/Elpida/Samsung model, the Crucial M225 which comes in at the same price and same capacity as the Corsair. This should really see the benefits of the 32nm Intel NAND flash and the refined Barefoot controller chip.
Intel Core i7 920 @ 3.2GHz
6GB Corsair Dominator @ 1600MHz
Asus P6T Deluxe
Windows 7 64 Bit
XFX HD5870 XXX
Corsair Nova 128GB using Intel 9.6 RST
Crucial M225 128GB for comparison
Windows 7 Load Time
A test as obvious as it sounds. We measure the time from selecting the operating system, until a 103KB image stored in the startup menu is displayed.
Straight away we can see an improvement. A few seconds here and there in OS loading might not make much of a difference but is a good indicator of the performance we can expect.
Multi-File Load
Along with the other tests we're also testing finding, accessing and loading multiple files from a huge selection. For this test we're using a full add-on graphics package for Football Manager 2010, weighing in at 3.4GB, containing 90000 files. Although it seems a strange choice the way that we can force the game to flush the cache and refil it provides an easily repeatable benchmark.
Outstandingly there is a second between the two drives. On such a short test that's a 10% improvement. Incredible. And yes, both the best times we're spot on to the .0 mark. Rounded for simplicity.
«Prev 1 2 3 4 5 6 Next»
19-04-2010, 05:12:26
tinytomlogan
SSD's are still high on many peoples wish lists, so VB takes a look at the new Corsair varient.
Continue Reading
19-04-2010, 05:41:49
Chewbacca
I want one! Does it really make that much of a difference going from a normal HDD to an SSD?
19-04-2010, 05:47:21
VonBlade
Imagine going from 512MB of RAM on Windows 7 to 4GB.
19-04-2010, 06:41:53
Rastalovich
Not for the outlay. At still over £2 a gig, for the home user I'd still not recommend them.
At such a low capacity, u would probably end up using ur old drive as a means to store stuff, leaving mainly the OS, and ur malware etc on the SSD.
For definite, if the cash is available and u don't use much harddrive space, they're great. But apparently having the cash to buy a pc component is not meant to be the way to look at it, ur meant to look at them value for money. Bang for buck. Speed for sure - capacity (the bread and butter of drives) a definite no. Some people will buy these then complain about the prices of other things, e.g.
I use them in many pc/mac setups now and tbh, if ur OS is installed and maintained efficiently, there are just as viable alternatives, leaving u to spend ur cash on more important components.
19-04-2010, 07:22:18
tinytomlogan
I personally see an SSD as an important part of a high spec system now. mechanicals just dont cut it once you have used a decent SSD. Even short stroked drives you can still notice a difference tbh.
19-04-2010, 07:45:33
nunzio
What I would like to see as a test is if you keep your OS/System on a hdd, and put the games installed on the ssd, would that make much of a difference?
19-04-2010, 09:13:19
Jim
Probably not a massive amount, but if you had the swap file on the SSD and not enough physical ram for the game to function inside it could improve performance a fair bit.
19-04-2010, 10:09:06
AMD_PBz
The results look very impressive for a Corsair SSD.
19-04-2010, 10:11:35
Rastalovich
Results aside, I had decent Corsair's supplied to me - well insisted actually - as I've not come across a more helpful support in a long time. And the controllers the SSDs use ofc.
20-04-2010, 07:08:11
Blackbeard
I've actually done a few tests with the SSD as 'games data drive' and the OS on a HDD.
/digs up results
With the OS and game installed on a P128, a level in Crysis loaded in 18s, compared to 22s with the OS on a 7200.11 and the game installed on the P128. Game and OS on the 7200.11 was 40s.
So there's still a hefty benefit, but really you get the most from an SSD when you use it as an OS and game data drive (for gamers).
