Corsair Neutron GTX 240GB SSD Review
Up Close and Test Setup
Published: 14th September 2012 | Source: Corsair | Price: £198.23 |
Up Close
You'd be forgiven for thinking this was a Force GT, such is the similarity of the design and packaging. But if it ain't broke, don't fix it is the maxim, and the Neutron GTX will blend in with any system.
Test Setup
HIS HD7970
Catalyst HD7970 Drivers 12.8
Intel Core i7-3960X @ 4GHz
ASUS P9X79 Pro
Corsair Dominator Platinum
Corsair AX1200W
Corsair H100
Windows 7 Ultimate x64
Personaly I still think ssd's are to expensive for the size, I'd like to see 250g below £100 b4 I'd consider buying 1
Any thoughts, Tom?
(Also, I can't thank you enough for all the review vids - they've been extremely helpful while I've been gathering parts for my first PC build.)
But I've a doubt in my mind over the reliability of new LM87800 controller.
just out of curiosity in your review you say you don't care about ocz is there any particular reason why?
Personaly I still think ssd's are to expensive for the size, I'd like to see 250g below £100 b4 I'd consider buying 1 ![]() |
The new vertex 4 with indilinx controler might be a diferent story, but about previous versions I wont recomend anyone to get them. I really regret have bought mine since I had some issues(and still do sometimes) of sistem frozing, etc. I had to turn OS HDD plug and play to be able to be stable.
Next time I get an SSD is gona be corsair or Intel for sure.
SATA 6? AHCI or IDE?
Could just be a faulty unit I support - or maybe even a dodgey sata cable?
Id put money on the fact you are using a 2011 board.
^^^Be config problem, IE: user/driver related issues.
Id put money on the fact you are using a 2011 board. |
I have used a new SATA cable, different SATA port and even try a secure clean as advised by corsair posts.
Maybe the SATA controller on older motherboards dont play game with these new drives.
But yeh, your motherboard will be why.
I have just added the as a boot drive and have just installed windows 7 onto it. Obviously a clean install. I am experiencing crashing and freezing.
I am coming from the Force 3 120gb so I know how a SSD behaves with windows and this is the first time I have ever seen the spinning loading symbol on the taskbar during startup.
What should I do?
EDIT: I just updated the bios on the mobo and it improved drastically but it still lags, horribly, Programs like chrome which work smoothly on any system just keep freezing.
EDIT2: I should mention that its lags for a bit, then it works, then lags, then works. It just goes in a cycle. However, this is not okay for any SSD, this is supposed to be one of the best.
The first SSD equipped with the LM87800 controller appears in our offices. How does it perform?
Continue Reading
