Zippy Emacs GSM-6600P G1 600w PSU
Testing
Load Testing
In order for the results from all current and future PSU reviews to remain fair and comparable, Overclock3D uses a custom built Power Supply load stress tester.
The tester will be placing the following loads on each of the GSM-6600P's rails:
+3.3v - 20a Load
+5.0v - 20a Load
+12v - 40a Load
The results are collected from a Mastech MAS-345 Multimeter which logs its readings via RS232 to a PC.
Zippy Emacs G1 600w 3.3v Rail Zippy Emacs G1 600w +5v Rail
The results speak for themselves - NO fluctuation was observed on either the +3.3v or +5v rails. This is simply amazing for a unit placed under such a high load.
Zippy Emacs G1 600w +12v Rail
After being so impressed with the +3.3v and +5v rails on the Zippy, we wanted to give the unit a real hard time and decided to place a 40a load on the single +12v rail. This counts for 100% of the rails total rated load and on most power supplies we'd expect to see quite a dip in the voltage. However, the GSM-6600P performed admirably, with the voltage only dipping by 0.04v taking it down to bang on 12.00v.
Efficiency Testing
Efficiency tests are performed by measuring the wattage consumed by the power supply at the mains against the power (in watts) consumed by the OC3D power supply stress tester.
The results may not be as accurate as those produced by professional testing equipment, but will certainly come in handy when comparing several power supplies against each other.
Zippy Emacs G1 600w Efficiency
The Zippy Emacs was placed under a load of 646 watts. This counts for a total of 107% of the power supplies rated output. At this load, the power supply required 764 watts from the mains to produce the 646 watts required by our custom made power supply tester. Therefore the efficiency of this power supply can be found by a simple equation: (646 / 764) * 100 that works out to be an efficiency rating of 84.5%.
Noise Testing
Possibly the hardest part of any PSU review is summarising the level of noise given out by the unit. The threshold for what is considered 'noisy' varies from person to person and therefore what I may consider a quiet unit, another person may consider extremely loud. A common way to resolve this issue is to use a dBA meter to measure the units noise level, however this doesn't take into account the pitch (type) of noise emitted and whether it is likely to irritate end users.
For this reason OC3D records all power supplies at idle and load in wav format for you to make your own informed decisions. All recordings are taken at 30cm away from the PSU and outside of a PC case. You will need to remember that noise levels will be reduced by varying amounts once the PSU has been installed inside your PC enclosure.
Idle Recording - Download
Load Recording - Download
At idle I found the GSM-6600P to be reasonably quiet. With the unit installed inside a PC enclosure, I am confident that the unit would have been inaudible.
Placing a full load on the unit caused the fan speed to increase significantly thus increasing the noise levels at the same time. Despite the load recording above sounding quite high-pitched, I was pleasantly surprised with the way in which the GSM-6600P controlled the 80mm fan, keeping noise levels as low as possible.
«Prev 1 2 3 4 5 6 7 Next»
06-10-2006, 03:52:53
JN
"Zippy Emacs are a name that only the most informed computer enthusiasts among us would have heard of. Today I'll be taking a look at their 600w GSM-6600P(G1) PSU as they make their way into the mainstream market."
EDIT: Oh, and it would appear that this is a world exclusive too
LinkageQuote
06-10-2006, 04:12:17
FarFarAway
Looks sweet.
Dugg!Quote
06-10-2006, 06:06:08
FragTek
Now that is a 1337 PSU, wow... Sweet results! Nice review Jim. Dugg.Quote
06-10-2006, 06:42:47
llwyd
damn those are nice results, any ideas as to what we're looking at in terms of retail prices?Quote
06-10-2006, 06:57:59
JN
At the moment I'm not really sure. OC3D are personally pushing to get the unit over in the UK, and hopefully you should see them in small quantities soon.Quote
06-10-2006, 07:02:56
Ham
*Goes off to poke ST with a stick*Quote
06-10-2006, 07:36:51
FragTek
I like what they've done with the appearance, using the black aluminum case and all, very nice touch. I'm used to the plain boring steel enclosures that they usually use, this is a pleasant upgrade. And wow those rails are solid.
Once they start emerging in the states holler @ me and I'll see if I can't get one shipped over to ya.Quote
06-10-2006, 09:14:30
Raging
Damn! that psu is rock solid,what a way to go on the first retail power supply units they are making
do i see stiff competition for pcp&c??
jason.Quote
06-10-2006, 09:56:46
FarFarAway
Zippy are huge OEM's so I think PCP&C can start looking over their shoulders Quote
06-10-2006, 10:36:17
WC Annihilus
I've actually heard around at points that Zippy makes PCP&C PSUs but I've also heard that they make their own so I really can't be sure. Anyways, Zippys seem to be in general only available at server stores (as that's what Zippy mainly does, build beastly server PSUs) and they can put a fairly large dent in your pocket. I think I've seen a link or 2 around of the server version (same thing, just doesn't have the "gaming power" title to it) so I can look it up if you wantQuote
06-10-2006, 11:04:49
NickS
They make their own & some of PCP&C...
Zippy > PCP&C!!Quote
06-10-2006, 11:20:24
Dav0s
dugg!!Quote
06-10-2006, 12:20:16
Raven
/me wonders if they will come to this side of the pond.
looked like a decent psu from several aspects.Quote
06-10-2006, 12:32:29
JN
I certainly hope they manage to make it out into the market with some reasonable pricing. IMO they have some of the best units i've ever tested.Quote
06-10-2006, 12:40:54
Ham
Not to metion one of the coolest namesQuote
06-10-2006, 12:42:54
JN
I must admit having to resist the temptation to mention bungle and george.....Quote
06-10-2006, 16:04:51
WC Annihilus
OMFG I do believe for that performance this thing is a steal. You wanna know why? MyAOpen.com has them for the price of... $169!!!!!!!. With about $15 shipping, end up only being 185, cheaper than PCP&C 510!
LinkageQuote
06-10-2006, 16:29:31
Raven
that means it will end up to atleast 350 over here making it way to expensive.Quote
06-10-2006, 18:59:11
WC Annihilus
You use the Euro right? I think you're confused about where I live. The price I stated was in USD, not GBP. Thus, it would actually be cheaper for you (sans shipping of course), about 150E.Quote
06-10-2006, 19:20:19
kimandsally
You use the Euro right? I think you're confused about where I live. The price I stated was in USD, not GBP. Thus, it would actually be [B]cheaper[/B'] for you (sans shipping of course), about 150E.
I think what he means is that by the time they get here the price doubles, we have shipping then import tax, then VAT then the poor soul who actually sells them has to put a bit on, he probably makes less than the VAT. There is quite a lot of expense in retailing in the UK.Quote
06-10-2006, 19:34:45
Raven
thats right Kimandsally.
the tax on hardware is 25% for example so its not cheap.
buying from countries outside EU isnt cheap either, high chance of getting charged 25% of the total value + an additional fee.Quote
