Thermaltake ToughPower XT 775w PSU Review
Once again Thermaltake has proved to be a worthy contender in the high-end power supply market. The Toughpower XT has everything you could want in a PSU....and then 25w more! Starting with voltage stability, the XT managed to hold good levels all the way up to its maximum output of 775w. Even during the cross-load tests the voltages stayed well within specifications showing that this unit is one of genuine power, unlike some competitors that require perfectly balanced loads in order to maintain acceptable voltages. Further reinforcing this fact was the results from the MAX-Load test that had the XT 775w running at a continuous 990w with a 50°C ambient temperature - and voltages still well within ATX spec. Simply excellent.
Ripple suppression was equally as good, which came as somewhat of a surprise considering the competitive pricing of the unit. Most manufacturers tend to save their pennies going for cheaper/fewer capacitors if they're intending to compete on pricing, but not Thermaltake with the XT. Nippon Chemicon and Teapo grace the unit along with two VRM's using solid state caps. This kept ripple on the +3.3v and +5v rails below 25mV and the +12v rail below 55mV in every single test thus ensuring the longevity of the hardware that it will be powering.
Efficiency was above expectations too. Considering that the XT 775w is 80PLUS Bronze certified I was expecting results around the low to mid 80's. But based on the test results Thermaltake really shouldn't have had any issues meeting the requirements of a Silver certification. 90% efficiency was hit at a 392w load, which will more than likely be the kind of wattage that most users of this PSU will be running at unless a seriously power hungry graphics card is used.
Finally the appearance of the unit is quite unique. I'm not 100% sure if I like the idea or looks of the integrated fan grill as I can imagine it to be quite restrictive in comparison to a wire one. However, the tough grey powdercoated finish is a refreshing change from black, and the status LED's at the side of the unit is a novel idea that will undoubtedly give users of windowed PC cases something new to look at.
Available from Yoyotech for £87 all inc, it is actually quite a steal.
The Good
- Solid 5v and 12v rails.
- Awesome ripple suppression.
- Above rated efficiency.
- Reasonably quiet
- Excellent value for money.
The Mediocre
- 3.3v output could be tighter.
- Fan grille looks quite restrictive.
The Bad
- Absolutely nowt.
Overclock3D Editors CHoice
Thanks to Thermaltake for providing the XT 775w for review. Discuss in our forums.
«Prev 1 2 3 4 5 6 Next»
10-05-2010, 07:36:56
tinytomlogan
The XT may have 25w more power than its 750w competitors, but does it have what it takes to impress OC3D?
Continue ReadingQuote
11-05-2010, 04:20:43
Stefan Payne
Isn't the 775W version silver certified?Quote
12-05-2010, 13:38:38
JN
Stefan, I've been hearing mixed things. Apparently the website says silver, but the box most definitely says bronze
Maybe they re-submitted after the first batch went out. :/Quote
13-05-2010, 13:34:22
VonBlade
Great review as ever Jim. Only you could make endless power supplies always seem fresh and interesting.
Love the new graphs too. Far simpler for people with less knowledge like myself to see the important data.
Great stuff.Quote
22-05-2010, 12:37:25
Stefan Payne
Ah, OK.
It seems that the PSU Manufacturers tend to not advertise the gained 80+ certification but rahter one (or even two!) down.
It's understandable if you'll know something about it.
Anyway, there is a mistake in that review:
Originally Posted by Review
"Thermaltake TT-1425B". However, after a bit of digging around it would appear that it is actually a re-labelled Yate Loon D14BM-12
That's not the case.
If you'll take a closer look, you'll see 'HA1425M12B-Z' wich leads to Ong Hua, the same Ong Hua Fan you'll find in Corsairs HX750/850.Quote
18-08-2010, 06:06:15
Newbie
Hi. Can I start by saying great site and great reviews. As you can see by the user name I'm new to this and would really appreciate some clarity on the figures (as I must be missing something).
I have taken the figures from the 25% load line
........3.3v 5v +12v 5vsb -12v Totals
Volts 3.34 5.07 12.1 5.08 -11.98 13.61V
Amps 4.5 4.5 12.75 0.75 0.12 22.62A
Power = volts * amps = 307.8582 Watts
The output power shown in the table is 197 DC Watts
Could someone please explain what I'm missing
Many thanksQuote
18-08-2010, 09:14:00
JN
Hi Newbie, the reason you're arriving at a wattage higher than what is stated in the table is because you are multiplying the initial power draw against the resultant voltage output.
What the table actually shows is the amperage load placed on each of the rails, and the resulting voltage output by the rails due to the strain from the load.Quote
