Thermaltake ToughPower XT 775w PSU Review
Simulated Load Results (Data)
OK, so we've seen the graphs over on the previous page. Now here's the data that they were derived from.
Thermaltake XT 775w Load Results @ 50°C
   +3.3v  +5.0v  +12v  +5vSB  -12v  AC Watts /
 DC Watts
 Efficiency  Intake /
 Exhaust
Δ Temp
Test1
(25%)
4.50A 4.50A 12.75A 0.75A  0.12A 222w /
197w
88.73% 50.0°C /
51.0°C
1.0°C
3.34v 5.07v 12.10v 5.08v  -11.98v
Test2
(50%)
9.00A 9.00A 25.50A 1.50A  0.25A  435w /
392w
90.11%  50.1°C /
54.2°C
4.1°C
3.28v 5.03v 12.04v 5.04v  -11.86v
Test3
(75%)
13.50A 13.50A 38.25A 2.25A  0.37A 649w /
583w
 89.83% 48.9C /
59.3°C
10.4°C
3.25v 4.99v 12.00v 4.99v -11.90v
Test4
(100%)
18.00A 18.00A 51.00A 3.00A 0.50A 878w /
777w
88.49%  49.9°C /
62.1°C
12.2°C
3.21v 4.94v 11.96v 4.95v -11.92v
TestX1
(x-load)
18.00A 18.00A 1.00A 0.00A 0.00A 198w /
160w
80.80% 50.3°C /
53.1°C
2.8°C
3.26v 5.00v 12.10v 5.08v -12.79v
TestX2
(x-load)
 1.00A  1.00A  64.00A  0.00A  0.00A 844w /
773w
91.58% 50.9°C /
60.9°C
10.0°C
3.31v 5.05v 11.96v 5.05v -14.00v
TMax1
(Max)
 20.00A 20.00A 68.00A 3.00A 0.50A 1140w /
990w
86.84% 50.1°C /
67.5°C
 17.4°C
3.21v 4.91v 11.90v 4.92v -12.06v
Once again it's hard to really find any fault with the ToughPower XT's results. It puts out good efficiency levels, the exhaust temperatures are about average, the voltages at 100% load are highly respectable and the unit was completely unfazed by the cross-load tests. Furthermore, being able to run at 990w continuous is pretty damn impressive for a PSU rated at 775w and although the voltages were on a downward turn at this point, it felt like the unit could easily break 1KW if pushed a little further.
Thermaltake XT 775w Scope Results @ 50c
   +3.3v  +5.0v  +12v
Test1
(25%)
Thermaltake  ToughPower XT 775w PSU Review Thermaltake  ToughPower XT 775w PSU Review Thermaltake  ToughPower XT 775w PSU Review
Test2
(50%)
Test3
(75%)
Test4
(100%)
TestX1
(x-load)
TestX2
(x-load)
TMax1
(MAX)
ATX specification
states that ripple should be no higher than 50mV on the +3.3v/+5v rails and 120mV on the +12v rails, and judging by those flat lines in the screenshots above the ToughPower XT 775w certainly had no trouble meeting these requirements in all of the tests. In fact, with the highest results recorded being 24mV on the +5v rail and 54mV on the +12v rail, the XT actually keeps the ripple at below half of what is required. Awesome.
Now that we've got a good idea of how it looks and how it performs, lets move on to the conclusion page and try to bring it all together...
«Prev 1 2 3 4 5 6 Next»
10-05-2010, 07:36:56
tinytomlogan
The XT may have 25w more power than its 750w competitors, but does it have what it takes to impress OC3D?
Continue ReadingQuote
11-05-2010, 04:20:43
Stefan Payne
Isn't the 775W version silver certified?Quote
12-05-2010, 13:38:38
JN
Stefan, I've been hearing mixed things. Apparently the website says silver, but the box most definitely says bronze
Maybe they re-submitted after the first batch went out. :/Quote
13-05-2010, 13:34:22
VonBlade
Great review as ever Jim. Only you could make endless power supplies always seem fresh and interesting.
Love the new graphs too. Far simpler for people with less knowledge like myself to see the important data.
Great stuff.Quote
22-05-2010, 12:37:25
Stefan Payne
Ah, OK.
It seems that the PSU Manufacturers tend to not advertise the gained 80+ certification but rahter one (or even two!) down.
It's understandable if you'll know something about it.
Anyway, there is a mistake in that review:
Originally Posted by Review
"Thermaltake TT-1425B". However, after a bit of digging around it would appear that it is actually a re-labelled Yate Loon D14BM-12
That's not the case.
If you'll take a closer look, you'll see 'HA1425M12B-Z' wich leads to Ong Hua, the same Ong Hua Fan you'll find in Corsairs HX750/850.Quote
18-08-2010, 06:06:15
Newbie
Hi. Can I start by saying great site and great reviews. As you can see by the user name I'm new to this and would really appreciate some clarity on the figures (as I must be missing something).
I have taken the figures from the 25% load line
........3.3v 5v +12v 5vsb -12v Totals
Volts 3.34 5.07 12.1 5.08 -11.98 13.61V
Amps 4.5 4.5 12.75 0.75 0.12 22.62A
Power = volts * amps = 307.8582 Watts
The output power shown in the table is 197 DC Watts
Could someone please explain what I'm missing
Many thanksQuote
18-08-2010, 09:14:00
JN
Hi Newbie, the reason you're arriving at a wattage higher than what is stated in the table is because you are multiplying the initial power draw against the resultant voltage output.
What the table actually shows is the amperage load placed on each of the rails, and the resulting voltage output by the rails due to the strain from the load.Quote
