Tagan Easycon XL 700w TG700-U35 PSU
Connectors
Search Reviews
Connectors
Each modular power supply manufacturer tends to have their own ideas on what the best connector method for a modular unit is. Some stick with the tried and tested Molex style connector, others utilise the newly designed PCI-E connector while the more inventive go for their own proprietary design.
Tagan Easycon XL 700w Connector
Tagan have decided to re-design their modular connectors, making them flush with the unit unlike the connectors found on their older Easycon U15 series. I was hoping that this would make the overall length of the PSU+connectors smaller, but unfortunately Tagan have decided to put extra long rigid covers at the end of the cables thus making the total length of the unit+connectors around 210mm.
Tagan Easycon XL 700w Cables Tagan Easycon XL 700w Cables
Tagan have opted not to make the ATX and P4-12v/EPS12v connectors modular on the TG700-U35, instead hard-wiring them to the unit. Personally I prefer this to fully modular designs as causes less issues when trying to bend the ATX cable around tight corners. The smaller connector (top right) can be screwed to a bare metal part of your PC enclosure to fully ground the unit.
All SATA and Molex cables are sleeved up to the first connector for aesthetics and optimal airflow. Interestingly, the cables also feature twisted wires that assist in the reduction of EMI (Electro Magnetic Interference).
You will also notice that P4-12v/EPS12v and PCI-E cables feature fully RFI/EMI shielded cables. This makes them far more attractive than standard sleeved cables, but does mean that they are slightly harder to route around tight corners in your case.
Tagan Easycon XL 700w P4-12v Tagan Easycon XL 700w ATX
The Easycon XL comes with two separate cables for ATX12v and EPS12v motherboard connections, which gives the unit full compatibility with server & high-end desktop motherboards as well as backwards compatibility with older boards. In a similar fashion, the ATX connector can be converted from 24-pin down to 20-pin for compatibility with older motherboards by simply uncoupling the additional 4 pins at the end of the ATX block.
Temporary Temporary
As the usage of floppy disk drives is slowly declining, Tagan have decided to make the usage of floppy disk power connectors optional by supplying them on a separate Molex-to-Floppy extension cable. In my opinion this is a great idea, as it cuts down on the number of unused cables you need to hide away inside your case.
The TG700-U35 package also contains 4x SATA-to-Molex converters that should come in very handy if you want to use any of the 8 SATA cables for non-SATA devices.
ATX P412v/EPS12v PCI-E
SATA Molex Floppy
«Prev 1 2 3 4 5 6 7 Next»
17-10-2006, 13:22:46
Jim
"It's been a while since Tagan updated their well respected "Easycon" range, and today I've been given the opportunity to test their latest addition - the Easycon XL."
EDIT: Oh and also my first review with my new digicam (apart from the last 2 pics on page 4)
Linky
17-10-2006, 13:48:57
llwyd
nice work (although i think if someone can afford to build a rig that needs 700W then efficiency is the last thing on their mind)
17-10-2006, 14:40:15
Hyper
Nice review mate.
What camera did you get ?
17-10-2006, 14:44:38
Jim
Originally Posted by Hyper
Nice review mate.
Fujifilm Finepix something-or-other.
Needed a cam with manual zoom/focus
17-10-2006, 14:48:36
nathan
F-10?
6.3MP?
1600 ISO?
17-10-2006, 14:49:23
Jim
Originally Posted by nathan
F-10?
6.3MP?
Nah its an S series. When i can be bothered to go upstairs i'll let u know
17-10-2006, 14:59:17
nathan
ah cool, i just brought a canon ixus 65, has a 3" screen for when im too drunk to see properly. anyways, nice review!
17-10-2006, 15:22:36
Hyper
Going a little off topic but you got yourself a nice camera there mate, I own a Canon Ixus 55 and its a cracking camera
17-10-2006, 15:36:05
NickS
Nice PSU.
Deffo a Topower unit. Gotta love Tagan's modular setup/cabling.
17-10-2006, 15:36:44
nathan
i thought i steered it back on topic with the last 2 words :P
18-10-2006, 18:53:50
BUFF
always liked Tagans, glad to see that they're keeping it up.
& nice review btw
