Silverstone Zeus 750w ST75ZF Quad Rail PSU
Search Reviews
The Silverstone Zeus 750w Power Supply is a monster. It passed our PSU Stress Tests with flying colours where many other manufacturers have failed miserably in the past.
The rail stability, particularly on the +12v rails was outstanding, much better than I would have ever expected of any Power Supply.
With Matt Black paint, this Power Supply is as plain as they come so 'bling' seekers should look elsewhere. However, this isn't to say you cant respray the unit in some funky metallic paint and sleeve the cables in UV braiding ;)
From what I've heard, this is Silverstone's first batch of the ST75ZF. Future batches will include an all black fan grill, all cables sleeved, and four dedicated PCI Express power connectors!
With a retail price expected to be around 158EUR + VAT, this is a great value piece of kit at a very competitive price. Now there's no reason for anyone not to have a top quality PSU in their PC!
Pro's
Outstanding performance.
Competitive pricing.
Excellent build quality.
Enough connectors for any system.
Cables to run 4x PCI-E cards.
Con's
May not fit all cases (check before buying).
Not all cables are sleeved.
No adjustable potentiometers (that I could find).
May be a little too noisy for some.
Editors Choice
Thanks to Silverstone for providing this unit for review :)
Discuss this review in our Forums...
«Prev 1 2 3 4 5 6 7 Next»
12-05-2006, 09:26:01
mr_fishbulb
Jesus - that is rated with twice as much power as my current PSU!
I'm liking the current idea of only needing to plug in the connections you want - leaves a nice tidy box (as the actress said to the bishop).
12-05-2006, 09:28:49
Jim
Yes, i'm a big fan of Modular too (my last 3 PSU's have been).
Coming up soon is a Silverstone Strider 600w Modular review - should be a nice bit of kit :)
12-05-2006, 09:42:38
PV5150
Very nice PSU, it looks very solid and with the performance to back it up. How good were those 12V rails? Awesome review again XMS :yumyum:
12-05-2006, 09:45:04
Raven
It also worries me slightly that 18a might not even be enough to power the latest generation of ATI cards (x1900xtx) especially when used in crossfire mode as the current draw from these cards is quite unbelievable.
120.6w according to xbitlabs if yoi wanted to know specific numbers :)
http://www.xbitlabs.com/articles/video/display/gpu-consumption2006_4.html
but all in all a good review but a way to pricy psu for my taste.
12-05-2006, 10:04:51
Jim
So thats a good 10a for a single card (despite hearing some cards drawing more).
However, now that Silverstone have confirmed that they are re-arranging the PSU rails, this problem doesn't really apply.
Cheers for the linkage :)
12-05-2006, 10:11:38
Raven
this is the methode xbitlabs uses and sounds to me like it could be accurate.
We utilize a special modified mainboard that has special shunts attached to PCI Express x16 power lanes as well as we attach the shunt into additional 12V power connectors that some of the graphics cards have.
but wouldnt surprise me at all if it differers between manufactures too, some like to raise the speed and/or use faster memories for example.
do you have any thoughts of starting to measure power consumption like this ?
at present time i have no reason to believe xbitlabs measurements are off, i looked at them before i bought my 7800gt and come to the conclusion my psu could manage the extra load and it has, flawless.
12-05-2006, 10:24:19
Jim
Yes, different cards with different stock speeds and different cooling solutions will change the power draw slightly. For example some pre-overclocked cards use slightly higher voltages on memory/core to achieve the stability. Also on the x1800 series for example, different revisions of cards had either 5 or 6 phase power i believe.
As for OC3D measuring power consumption, this is not something we are planning on performing at present, but if there is a need for it then we'll certainly look into getting the equipment.
However, on the PSU side of things, we will very shortly be measuring: Power Consumption (for Efficiency), Noise and Heat. The key thing for us is making sure that all of these tests are performed under the same conditions, so results are comparable.
12-05-2006, 10:31:35
Raven
their isnt directly a need for it but from my point of view it would be interesting as its one part i look at when researching a card.
also interesting to know if a current psu can manage the load or not, not everyone can just go out and buy a stronger psu if problem should arise.
one simple way but not so accurate is to only measure the pcie power cable, remember some site measuring that way back in the agp days.
for psu's efficiency and noise is the 2 most interesting aspects so will be interesting to se it comming :)
if you havent already guessed it i chose components to minimize power usage but still be powerfull for what i do.
14-05-2006, 18:34:58
Eguy
This was one of my fist PSU's, but I returned it for how loud it was. I remember it being amazing power though
14-05-2006, 18:51:35
WC Annihilus
Eguy, you're slightly off again :D Yours was the 650W. This is the recently released, Etasis made (650 was Enhance) 750W ;)
