Silverstone Zeus 750w ST75ZF Quad Rail PSU
Connectors
Published: 10th May 2006 | Source: Silverstone | Price: |
Now this is where things start to get interesting. The Zeus has been designed with the most modern systems in mind, providing backward compatibility by means of extension cables included in the extra's box that comes with the unit.
It is also worth mentioning at this point that the PSU is NOT Quad-SLI certified. So don't start moaning if it can't run 4x 7900GTX's!
EDIT: 12/05/06
Silverstone have confirmed that they are currently in the process of obtaining Quad SLI Certification for this unit and are just awaiting Stickers and other media before they can promote the unit as Quad SLI Certified.
* The 8-Pin EPS12v connector can be converted to a 4-Pin ATX/P412v connector by means of an included converter.
** An additional 2 PCI-E connectors have been included in the accessories box.
Jesus - that is rated with twice as much power as my current PSU!
I'm liking the current idea of only needing to plug in the connections you want - leaves a nice tidy box (as the actress said to the bishop).
Yes, i'm a big fan of Modular too (my last 3 PSU's have been).
Coming up soon is a Silverstone Strider 600w Modular review - should be a nice bit of kit :)
It also worries me slightly that 18a might not even be enough to power the latest generation of ATI cards (x1900xtx) especially when used in crossfire mode as the current draw from these cards is quite unbelievable.
120.6w according to xbitlabs if yoi wanted to know specific numbers :)
http://www.xbitlabs.com/articles/video/display/gpu-consumption2006_4.html
but all in all a good review but a way to pricy psu for my taste.
So thats a good 10a for a single card (despite hearing some cards drawing more).
However, now that Silverstone have confirmed that they are re-arranging the PSU rails, this problem doesn't really apply.
Cheers for the linkage :)
this is the methode xbitlabs uses and sounds to me like it could be accurate.
We utilize a special modified mainboard that has special shunts attached to PCI Express x16 power lanes as well as we attach the shunt into additional 12V power connectors that some of the graphics cards have.
but wouldnt surprise me at all if it differers between manufactures too, some like to raise the speed and/or use faster memories for example.
do you have any thoughts of starting to measure power consumption like this ?
at present time i have no reason to believe xbitlabs measurements are off, i looked at them before i bought my 7800gt and come to the conclusion my psu could manage the extra load and it has, flawless.
As for OC3D measuring power consumption, this is not something we are planning on performing at present, but if there is a need for it then we'll certainly look into getting the equipment.
However, on the PSU side of things, we will very shortly be measuring: Power Consumption (for Efficiency), Noise and Heat. The key thing for us is making sure that all of these tests are performed under the same conditions, so results are comparable.
their isnt directly a need for it but from my point of view it would be interesting as its one part i look at when researching a card.
also interesting to know if a current psu can manage the load or not, not everyone can just go out and buy a stronger psu if problem should arise.
one simple way but not so accurate is to only measure the pcie power cable, remember some site measuring that way back in the agp days.
for psu's efficiency and noise is the 2 most interesting aspects so will be interesting to se it comming :)
if you havent already guessed it i chose components to minimize power usage but still be powerfull for what i do.
