Silver Power SP-SS750M 750w Review
Simulated Load Results (Data)
Search Reviews
SIlverPower 750w
OK, so we've seen the graphs over on the previous page. Now here's the data that they were derived from.
Silver Power 750w Load Results @ 50°C
   +3.3v  +5.0v  +12v  +5vSB  -12v  AC Watts /
 DC Watts
 Efficiency  Intake /
 Exhaust
Δ Temp
Test1
(25%)
4.50A 4.50A 11.75A 0.75A  0.20A 211w /
188w
89.09% 51.8°C /
51.0°C
-0.8°C
3.41v 5.16v 12.25v 5.07v  -12.08v
Test2
(50%)
9.00A 9.00A 23.50A 1.50A  0.40A
 412w /
375w
91.01%  50.1°C /
52.2°C
2.1°C
3.40v 5.14v 12.20v 5.03v  -12.09v
Test3
(75%)
13.50A 13.50A 35.25A 2.25A  0.60A 623w /
564w
 90.52% 51.2C /
54.6°C
3.4°C
3.39v 5.12v 12.16v 4.98v -12.12v
Test4
(100%)
18.00A 18.00A 47.00A 3.00A 0.80A 839w /
747w
89.03%  50.0°C /
59.1°C
9.1°C
3.38v 5.10v 12.10v 4.95v -12.17v
TestX1
(x-load)
18.00A 18.00A 1.00A 0.00A 0.00A 197w /
165w
83.75% 48.8°C /
53.2°C
4.4°C
3.39v 5.12v 12.24v 5.08v -12.54v
TestX2
(x-load)
 1.00A  1.00A  62.00A  0.00A  0.00A 845w /
758w
89.70% 50.0°C /
57.9°C
7.9°C
3.40v 5.15v 12.10v 5.05v -13.85v
TMax1
(Max)
 15.00A 15.00A 65.00A 3.00A 0.50A 1051w /
936w
89.05% 52.0°C /
62.3°C
 10.3°C
3.38v 5.11v 12.06v 4.94v -12.26v
To repeat what's already been said on the previous page, the Silver Power SP-SS750M is one very stable PSU across all tests including the Max load test where it's pushed to an impressive 936w. The only minor issue I'd like to see rectified is the relatively high idle voltages that give the feeling that Silver Power haven't spent much time fine tuning the unit. As for the rest of the results: efficiency is great, exhaust temperatures are low and cross-loading the unit had little negative effect. Nice.
Silver Power 750w Scope Results @ 50c
   +3.3v  +5.0v  +12v
Test1
(25%)
SIlverPower 750w SIlverPower 750w SIlverPower 750w
Test2
(50%)
Test3
(75%)
Test4
(100%)
TestX1
(x-load)
TestX2
(x-load)
TMax1
(MAX)
The greatness also continues on to the ripple results where the +12v rail seems to be impersonating a pancake. Seriously though, 30mV of ripple on the +12v rail at full load is quite possibly the best result seen yet on OC3D since we began using the oscilloscope. The +3.3v rail is equally as awesome with a maximum ripple of 18mV in test 4 and only slightly higher in the Max Load test. The +5v rail results seem to go hand-in-hand with the +12v results which may suggest that only the +3.3v rail received the DC-DC VRM treatment whereas the +5v rail was derived direct from the transformer. But regardless the results are still well within ATX specs.
Now on to the conclusion...
«Prev 1 2 3 4 5 6 Next»
27-05-2010, 09:12:44
tinytomlogan
If there was a PSU to read from page to page its this one. Like a super hero in a comic read as the SP-SS750M fights it out with the big bad HX750w...... But does it win?
Continue Reading
27-05-2010, 09:38:49
alders
wow its done good. and for the gorilla im thinking
02-06-2010, 15:15:50
CrissTM
10x for a very nice review !
im thinking in geting one of the new gorilla !, and change my 500w also silver power wich for its 50€ back than, stil does a very good job today
