Seasonic X900 SS-900HP 900w PSU
Introduction & Specifications
Published: 26th September 2007 | Source: Seasonic | Price: £130 |
Over the past 30 years Seasonic have gained a reputation for manufacturing some of the most silent and stable power supplies in the market. With models such as the S12 as part of their portfolio, Seasonic will always be one of the first names mentioned to those seeking silence without compromising performance.
Back in November 06, we were given the chance to test their first ever modular PSU:- the M12. With unique modular cables and decent performance the M12 design was head-hunted by memory giants Corsair. After some minor alterations to the cooling layout of the M12, Corsair released the unit as their now extremely popular HX series.
With more and more high-powered units entering the market from a whole range of manufacturers it's hard to stay with the same product for too long, and for this reason Seasonic have released a new high-end, performance orientated unit named the X900. The X900 power supply is (not surprisingly) rated at 900w, has quad PCI-E connectors and most interestingly of all - an 80mm fan. Today I'll be putting this unit though its paces, comparing its performance to other similar units and finding out if Seasonic have managed to keep their finger on the pulse since the release of their last PSU almost a year ago.
Since the incorporation of Sea Sonic Electronics Co., Ltd. in 1975, we have maintained our focus on research and development and the production of quality power conversion products.
For the past decades, supported by cutting edge technology based upon a strong research and development team, Sea Sonic Electronics has provided timely and professional solutions to meet many of the IT industry's requirements.
For the future, we will continue our philosophy of dedication; innovation, professionalism and 4G's (Great Technology, Great Quality, Great Service & Great Price) in order to maintain our goal of continued long-term business partnerships and create "win-win" situations for our customers.
Specifications
The following information has been taken directly from Seasonic's recent press release and Nanopoint's (Seasonic's UK Distributor) website:
The Seasonic X900 is designed and built for power, performance, stability and reliability as demanded by power users, gamers and over-clockers. The X900 is a true 900W output power unit with a peak output of over 1,000 watts.
Seasonic X900 is equipped with multiple +12V rails to support high-end graphic cards’ need with a total power output of 72 amps. A Double Forward Converter circuit design achieves a 99% Active Power Factor Correction and an industry-leading efficiency rating of up to 88%. Additionally, the power supply utilizes a Dual Magnetic Amplifier circuit to maintain a class-leading 3% line regulation tolerance on all +12V output rails to meet the demands of high-end graphics cards, CPU’s and peripherals for accurate and stable power output.
Features
• Super high efficiency for energy savings, up to 88% efficiency
• 3% line regulation for +12v rails for maximum stability, security and performance.
• Multiple 12V outputs with enhanced +12V current capability to broaden utilization capabilities.
• High reliability aluminium electrolytic capacitors for increased product life and reliability.
• Active power factor correction [99% PF] for reduced line noise and power distortion.
• Advanced dual forward converter circuit design for added reliability and efficiency.
• Smart and silent fan control [S2FC], one of the best-performance noise controllers available on the market.
• 8cm double ball bearing fan for increased lifetime.
• 4x PCI-Express connectors to support high-end graphic cards. With 6p to 8p PCI-E adapters x2
• All in one DC cabling to support PC, IPC, workstations, servers and dual CPU systems.
• Patented easy swap peripheral connectors for easy plug and unplug connection.
• Total protection with Over Voltage, Over Power and Short Circuit protection.
• Fixed 220V AC input.
• >100,000 hours MTBF, excluding fan.
• RoHS compliant.
• PFC harmonics compliant, EN61000-3-2: 2000
• EMI/ EMC: CE, C-tick & safety approvals: CB, TUV & Semko
As we can see from the specifications above, the X900 provides support for the latest 8-Pin PCI-E powered graphics cards along with multiple +12v rails that Seasonic tout as offering enhanced stability, security and performance.
In addition to this, the X900 is rated at a whopping 88% efficiency. If these figures are indeed confirmed in our testing, this will make the X900 the most efficient PSU we've ever tested!
i'd stil have a pcp&c over it any day...but i bet its cheaper than the pcp&c equivilant....
I have to say I do like Seasonic PSUs. :)
Jeeze that is a PCP&C rip off if ever I saw one... the silnecer sprigns to mind when I look at that. Similar internal layout, same exhaust fan and positioning etc. But that is a good thing - more manufacturers like PCP&C mean more stable and quality PSU's. A single rail would have been nice but excellent PSU none the less - whopping efficiency!
Quote from Dave Hammock @ http://forums.extremeoverclocking.com/showpost.php?p=1615995&postcount=234
SeaSonic M12 SS-700HM 700W [Performs as a Single +12V Rail PSU.] [Modular]
Up to +12V@56A, Rated@40C, Efficiency up to 85%, 3yr warranty
Corsair HX 620W [Performs as a Single +12V Rail PSU.]
Up to +12V@50A, +5VSB@3A
I think most manufacturers design around multiple rails to stay withing the ATX specification.
BitTech in their review of the Seasonic X900, state the Corsair is actually a 750w psu thats "under-rated" to 620w to guarantee silence. They suggest Seasonic should take the same approach with the X900 i.e. class it as a truly silent/quiet 700w psu. I guess if true in this respect with regards to silence you could argue the pcpwr is more like a corsair a 620w? ...well maybe a bit noisyer :)
I can tell you this I am running:
Opteron 175 OC from 2.2 to 2.8GHz
X1900XT Crossfire Master + X1900XTX in crossfire OC to 688/1584 core/mem
2x 10000rpm raptors
2x 500GB WD RE2
2x 320GB WD RE
2x 200GB Seagate
1x 180GB IBM GXP IDE
under load the psu is cool and the fan runs idle speeds!
Ye that system will only put out about what...300-400w?
i was wondering about the output, but I guessed it to be around 400-500. i got the Seasonic to replaced my old PCPower 510 SLI turbo cool. I wasn't having much joy running crossfire. the cards were intermitantly not responding a little to frequently for my liking. this was occurring on a non-overclocked crossfire pc with a hard drive count of 6.
Of course, if you was hell bent on making it total silent, you could always swap out the fan with a SilenX or something. Not that I'd advise anyone to fiddle inside a PSU :nono:
