PC Power & Cooling 1kw Turbo-Cool TC1KW PSU
Measuring in at 149mm x 86mm x 231mm (WxHxD) the Turbo-Cool is longer than your average power supply. People with small cases, cases with PSU cages or cases with fans situated at the top should take measurements before considering this power supply.
Under normal circumstances the Turbo-Cool would have no problems fitting inside my Silverstone TJ05, however, with my dual radiator mounted at the top, the power supply is about 50mm too long.
PCP&C Front PCP&C Side
As you can see above, the Turbo-Cool is a simplistic 'no-bling' unit sprayed in matt black paint. The label on top of the unit informs the user of its vital statistics such as peak output and rail amperages. Proudly placed on the side of the unit is the Nvidia SLI Certified sticker.
The front of the unit sports an 80mm fan covered with a black painted fan grill. We can also see that the Turbo-Cool is capable of auto-detecting the input voltage (230v/110v) as a voltage switch has been omitted from the unit.
PCP&C Top PCP&C Back
The back of the unit makes use of a honeycomb grill to allow for the 80mm fan placed around the front to pull air over the components. Also something you don't normally see on most power supplies is the inclusion of a small 'lip' with two screw holes. I can only assume that this can be used to bolt the end of the power supply to the top of a case, thus stopping the end of the power supply from 'sagging' downwards under the weight of its internal components.
«Prev 1 2 3 4 5 6 7 Next»
22-05-2006, 10:56:55
Often regarded as the "Big Daddies" of the PSU market, do they deserve their reputation? OC3D find out...
Review HereQuote
22-05-2006, 11:01:42
I want one....now Quote
22-05-2006, 11:08:49
Was this frags?
And can i have the sitcker?Quote
