OCZ ProXStream 1kw OCZ1000PXS ATX PSU
Published: 2nd March 2007 | Source: OCZ | Price: |
The OCZ ProXStream 1000w is a great looking unit with stable voltages all the way up to 886w and quite possibly beyond. The tweakers among us will be delighted to see that the ProXStream has internal pots that can be used for fine tuning the output voltages (providing you can remove the anti-tamper glue), and with an efficiency of over 81% the unit should also appeal to those who are looking to save valuable pennies on their energy bills.
Unfortunately due to the way that the ProXStream is crammed with two levels of circuits, the unit gets very hot. To counteract this OCZ have installed a high-cfm 80mm fan that unfortunately can only be described as a leaf blower when running at full speed.
If noise isn't a factor in your next PSU purchase, then the OCZ ProXStream can be found over at SpecialTech or Tekheads retailing for around
Update 04/03/07
We have been informed that the OCZ ProXStream 1kw has been reduced in price by £20 over at SpecialTech. This brings the retail price down to £175 making the ProXStream far more competitive in the 1kw market. For this reason, the price sub-score has been increased from 7 to 8.
Pro's
• Great looking electroplated finish.
• Sleeved cables and easy grip molex connectors.
• Good efficiency at medium and high load levels.
• Fairly stable voltages when tested up to 886w.
• Standard sized ATX casing. Suitable for all PC's.
• Adjustable pots for tweaking voltage output.
Con's
• Very noisy even with 0% load.
• Unit gets hot under heavy load.
• +5v rail results could have been better.
I'd like to extend our thanks to OCZ for providing the ProXStreme 1kw for review.
Discuss this review in our forums.
Fairly decent performance there, quite like the looks of it too
Not impressed tbh - enermax ftw... Agreed, fairly decent performance, but who wants fairly decent when you can have unequivocal top notch performance elsewhere?
Decent review though...
Decent review though... |
for a 1k psu and the size, and also using a 80mm fan, i think its a rather good psu, if they used a 120mm fan im sure temps and the sound would be dropped alot more.
Looks to be a decent unit, I like the size. I don't like the noise output though, that's a killer for me.
Review updated. It has been reported that the unit is available for up to £25 less at other retailers. Pricing score has been adjusted from 7 to 8.
Linkage
