OCZ ProXStream 1kw OCZ1000PXS ATX PSU
Introduction & Specs
Published: 2nd March 2007 | Source: OCZ | Price: |
Up until recently 1000w of power was only available to those of us with plenty of space inside our PC cases. This was a problem for a lot of people as they wanted to be able to run the latest and greatest Quad/SLI and Crossfire set-ups but just simply didn't have the space for the over-sized (and highly expensive) units that were available at the time.
In the past few months several manufacturers have made it their mission to fill this gap in the market by attempting to cram the full 1000w into units suitable for fitting into standard sized ATX cases. In all honesty most attempts have been pretty poor, with most models not being able to hold up the full 1000w for any sustained period, being extremely noisy and/or ending up so hot that you could fry an egg on top of them.
Will the recently released ProXStream 1000w PSU from the enthusiast orientated manufacturer OCZ be the answer to our prayers? Read on to find out.
Specifications
The following information has been shamelessly copied directly from OCZ's website:
| The Multi-GPU Ready ProXStream 1000 Watt power supply is designed specifically for the most demanding computing environments of PC enthusiasts, high-end system builders, and die-hard gamers. With today’s top-of-the-line graphics cards consuming large amounts of energy, the ProXStream supplies stable and reliable power to quad-GPU platforms, as well as all your systems vital components. The new OCZ ProXStream 1000W PSU utilizes a powerful, server-class core and merges it with an unparalleled compact form factor to accommodate virtually all computer cases, a requisite for today's enthusiasts and system-builders. The most powerful and compact PSU comes backed with an industry-leading warranty, and OCZ offers an exclusive 3 year PowerSwap warranty program for unsurpassed peace of mind. |
| • 1000W Configuration • 3 year warranty backed by OCZ’s exclusive PowerSwap™ replacement program. No more endless return-for-repair loops! • Internal 80mm fan • 4 Channel 12V Output provides stable electric power to computer components • 4 Channel PCI-E connectors • Dual CPU support: provides 8-pin 12V dual CPU support with stable voltage • 20+4 pin: compatible with all motherboards available on the market • 4pin & 8pin: accords with the requirements of CPU in ATX or EPS 12V V2.91 systems • Active PFC: enhances utilization of energy • Over Voltage and current protection: A complete protection circuit is implemented, protecting every component in your system. • Environmental protection specifications: accords with WEEE & RoHS by Europe 115Vac 60Hz / 230Vac 50Hz • Rail Layout: +3.3V(28A), +5V(30A), +12V1(20A), +12V2(20A), +12V3(20A), +12V4(20A) |
In terms of specification the ProXStream looks like a very capable unit. With a total of four +12v rails rated at 20a each and a combined +12v output of 70a the PSU certainly can't be accused of being underpowered. The same goes for the +3.3v and 5v rails rated at 28a and 30a respectively.
Anyway, enough of the boring stuff, let's get down to the nitty gritty...
Fairly decent performance there, quite like the looks of it too
Not impressed tbh - enermax ftw... Agreed, fairly decent performance, but who wants fairly decent when you can have unequivocal top notch performance elsewhere?
Decent review though...
Decent review though... |
for a 1k psu and the size, and also using a 80mm fan, i think its a rather good psu, if they used a 120mm fan im sure temps and the sound would be dropped alot more.
Looks to be a decent unit, I like the size. I don't like the noise output though, that's a killer for me.
Review updated. It has been reported that the unit is available for up to £25 less at other retailers. Pricing score has been adjusted from 7 to 8.
Linkage
