OCZ GameXStream 700w ATX PSU
Looking Inside
Search Reviews
Looking Inside
As with all power supplies that pass through Overclock3D, I'll be taking a look inside the GameXStream. By doing this I should be able to get a good idea of the overall build quality of the unit and how it is likely to perform in our tests.
OCZ GameXStream 700w Inside OCZ GameXStream 700w Inside
Normally I'd be quite shocked by the seemingly inadequate internals of the GameXStream unit, however these internals strike an amazing resemblance to a power supply manufactured by FSP that I reviewed a short while ago.
After giving the unit a thorough inspection, I was able to find the FSP logo on the PCB (circuit board), which leads me to believe that I'm going to find the GameXStream to be a very capable power supply indeed.
OCZ GameXStream 700w Pot
Also during the inspection of the GameXStream, I came across what appeared to be an adjustable potentiometer (pot for short). Pot's can be used to adjust the voltage output by the rails on the power supply, and can come in handy when voltages droop outside of ATX specifications.
OCZ GameXStream 700w Fan
Cooling the GameXStream is a 12cm fan manufactured by Protechnic Electrics. The maximum speed of this fan is 2500rpm at 38.3dB when running at 12v. As mentioned earlier, the fan also includes a blue LED to brighten things up a bit!
«Prev 1 2 3 4 5 6 7 Next»
14-09-2006, 04:45:33
Jim
"OCZ have always been well known for their DDR memory and high-end PowerStream PSU's. Today I'll be taking a look at their latest addition, the GameXStream 700w SLI certified unit."
Linkage
14-09-2006, 05:50:30
PV5150
Great review as always Jim. Agreed, on the very ordinary appearance especially from the likes of OCZ. Again the solid build and very stable voltages are sure to please most people and cause them to forget about the bland look. Well done anyway mate
14-09-2006, 06:02:40
Jim
Cheers fella
14-09-2006, 06:03:39
FarFarAway
Looks like a tip-top PSU Jim
14-09-2006, 08:07:52
Archmage
Great review and even more so cos I've just got the 600W version of this, so I'm hoping it's as good.
14-09-2006, 09:36:41
mrapoc
wow i might get this for my new build (lower wattage version) i like the blue fan
deffo quiet enough, 95% is great
was it the best psu uve played with?
14-09-2006, 09:51:31
FarFarAway
Tagan 1100w or PCP&C 1kw
Me: I'd get a PCP%C - sexy as hell
14-09-2006, 09:57:11
Jim
Its definately up there with the top ones. If you are looking for a quiet PSU under load then none of the other units tested so far can touch this one.
14-09-2006, 12:17:36
mrapoc
i like the blue effect coming from its 120mm fan
im guessing the 600w acts the same?
14-09-2006, 12:25:58
Jim
Yep
14-09-2006, 13:38:36
mrapoc
great, im going for one of those babies now
14-09-2006, 13:49:43
twisted5
Nice review. I know there is a 600w version but are there anymore? I am trying to find one 550w or less that will support high end SLI/CF and a few extra things for my lan rig. I may just go with the 600w version of this though.
14-09-2006, 14:43:48
mrapoc
600w or 700w mate
14-09-2006, 15:15:33
mrapoc
seems perfect to me high enough wattage to last, good enough quality to last, 3 years warranty to last and that sweeeeeeet blue light + 120 mm fan
14-09-2006, 18:13:41
kimandsally
Very nice review I just bought one yesterday and noticed there wasn't a review on here so I was going to have a try at showing what mine does after my holiday, but after seeing your superb review I cannot come close to that I'm sure.
I'm very pleased with mine much more stable than the Enermax Liberty 620 that it replaced although I think I had a duff one considering it blew up (literally) I know some people say blew up but this took out the mains of the house and did it again when I reset the RCD I wasn't too impressed but at least it didn't kill any of the PC components.
Anyway the OCZ is super stable not moving more than 0.2v from idle to full load on my Conroe with ATI X1900 set up. And very impressed with how quiet it is, my only moan is the leads are very long but considering that some cases are much bigger these days it caters nicely for them as well.
Keep up the good work I really like your method of reviewing.
14-09-2006, 21:00:20
NickS
My dad has a 600w GameXStream, its freakin awesome. Great review XMS
15-09-2006, 01:15:54
Jim
Glad you like it peeps
15-09-2006, 02:28:36
mrapoc
u saved me from getting a boring psu i love it now
need to get it!
