OCZ GameXStream 700w ATX PSU
Connectors
Search Reviews
Connectors
Having never reviewed an OCZ power supply before, I wasn't quite sure what to expect in the cabling and connectors department. Generally most manufacturers PSU's follow the same trend throughout their entire range. Lets see what the GameXStream has to offer:
OCZ GameXStream 700w Cables OCZ GameXStream 700w Cables
All connectors are finished in black, with the molex connectors adopting the 'easy grip' design, which should make removal of the connectors from devices easier.
It's also good to see that OCZ have decided to sleeve all cables right to the very last connector. Many manufacturers only sleeve some of the cables, or sleeve up to the first connector on every cable. The sleeving job is professional with cable ties holding the sleeving in place, and heat shrink keeping everything neat and tidy.
OCZ GameXStream 700w ATX OCZ GameXStream 700w P412V
The ATX connector on the GameXStream is native 24-pin. However, as you can see above, a small block of 4 connectors can be broken off to switch the connector to 20-pin, and thus make it compatible with older motherboards. This is also true for the 8-Pin EPS12v connector which can be split in half, providing the user with a 4-Pin P4-12v connector.
ATX EPS12v PCI-E
SATA Molex Floppy
With 6 SATA connectors, 6 Molex connectors and 2 Floppy connectors the GameXStream 700w should have enough plugs to suit almost every configuration of PC.
«Prev 1 2 3 4 5 6 7 Next»
14-09-2006, 04:45:33
Jim
"OCZ have always been well known for their DDR memory and high-end PowerStream PSU's. Today I'll be taking a look at their latest addition, the GameXStream 700w SLI certified unit."
Linkage
14-09-2006, 05:50:30
PV5150
Great review as always Jim. Agreed, on the very ordinary appearance especially from the likes of OCZ. Again the solid build and very stable voltages are sure to please most people and cause them to forget about the bland look. Well done anyway mate
14-09-2006, 06:02:40
Jim
Cheers fella
14-09-2006, 06:03:39
FarFarAway
Looks like a tip-top PSU Jim
14-09-2006, 08:07:52
Archmage
Great review and even more so cos I've just got the 600W version of this, so I'm hoping it's as good.
14-09-2006, 09:36:41
mrapoc
wow i might get this for my new build (lower wattage version) i like the blue fan
deffo quiet enough, 95% is great
was it the best psu uve played with?
14-09-2006, 09:51:31
FarFarAway
Tagan 1100w or PCP&C 1kw
Me: I'd get a PCP%C - sexy as hell
14-09-2006, 09:57:11
Jim
Its definately up there with the top ones. If you are looking for a quiet PSU under load then none of the other units tested so far can touch this one.
14-09-2006, 12:17:36
mrapoc
i like the blue effect coming from its 120mm fan
im guessing the 600w acts the same?
14-09-2006, 12:25:58
Jim
Yep
14-09-2006, 13:38:36
mrapoc
great, im going for one of those babies now
14-09-2006, 13:49:43
twisted5
Nice review. I know there is a 600w version but are there anymore? I am trying to find one 550w or less that will support high end SLI/CF and a few extra things for my lan rig. I may just go with the 600w version of this though.
14-09-2006, 14:43:48
mrapoc
600w or 700w mate
14-09-2006, 15:15:33
mrapoc
seems perfect to me high enough wattage to last, good enough quality to last, 3 years warranty to last and that sweeeeeeet blue light + 120 mm fan
14-09-2006, 18:13:41
kimandsally
Very nice review I just bought one yesterday and noticed there wasn't a review on here so I was going to have a try at showing what mine does after my holiday, but after seeing your superb review I cannot come close to that I'm sure.
I'm very pleased with mine much more stable than the Enermax Liberty 620 that it replaced although I think I had a duff one considering it blew up (literally) I know some people say blew up but this took out the mains of the house and did it again when I reset the RCD I wasn't too impressed but at least it didn't kill any of the PC components.
Anyway the OCZ is super stable not moving more than 0.2v from idle to full load on my Conroe with ATI X1900 set up. And very impressed with how quiet it is, my only moan is the leads are very long but considering that some cases are much bigger these days it caters nicely for them as well.
Keep up the good work I really like your method of reviewing.
14-09-2006, 21:00:20
NickS
My dad has a 600w GameXStream, its freakin awesome. Great review XMS
15-09-2006, 01:15:54
Jim
Glad you like it peeps
15-09-2006, 02:28:36
mrapoc
u saved me from getting a boring psu i love it now
need to get it!
