OCZ EvoStream 600w Modular PSU
Looking Inside
Published: 30th October 2006 | Source: OCZ | Price: |
Now for my favourite part of PSU testing - lifting the hood and having a poke around inside! By doing this I should be able to get a good idea of the overall build quality of the unit and how it is likely to perform in our tests.
I was really surprised to see that the EvoStream was based on a dual PCB design. Normally this is only seen in high wattage power supplies that need to make full use of the casing without extending the length of the PSU. The layout of the unit seemed rather crowded but had been kept as tidy as possible with the use of cable ties.
Several aluminium heatsinks can be seen at various places on the circuit boards, the largest being at the top of the unit that has the responsibility of keeping the mosfets cool.
From the images above we can see that the upper of the two boards (pictured right) has a single transformer with a wire-wound inductor alongside. Around the other side of the board is a large bank of small capacitors rather than a one or two large capacitors as seen on most other power supplies.
The lower part of the board (pictured left) contains several more inductors along with another large aluminium heatsink cooling multiple mosfets. At the back of the board we can also see a small transformer most likely responsible for 3.3/5v transformation.
During my inspection of the EvoStream I found the logo of a company called PloTech printed on the PCB. Normally this would indicate that the power supplies internals were produced by an industry manufacturer. However, with no previous history of PloTech manufacturing power supplies it is unlikely that they are responsible for the EvoStream.
The EvoStream also has several adjustable potentiometers (pots) on the upper PCB, which are often responsible for fine-tuning the output voltages of the unit. However, a layer of glue as been applied to the pots to prevent them from being tampered with.
nice review and nice looking psu.....cept for the modular system.... thats just manky
Originally Posted by name='XMS'
Would have looked much much better in black for sure
i cant see the pics of the unit
Another good review mate.
I must admit, the pictures seem a much higher quality now
Linky
