FSP Epsilon 700w ATX PSU
Testing
Search Reviews
Load Testing
In order for the results from all current and future PSU reviews to remain fair and comparable, Overclock3D uses a custom built Power Supply load stress tester.
The tester is capable of placing loads on the following rails:
+3.3v - 20a Load
+5.0v - 20a Load
+12v1 - 10a Load
+12v2 - 10a Load
+12v3 - 10a Load
+12v4 - 10a Load
(or 10-40a on a single +12v rail)
The results are collected from a Mastech MAS-345 Multimeter which logs its readings via RS232 to a PC.
3.3v Rail +5v Rail
+12v Rail
The results given out by the Epsilon were extremely strange. Rather than the voltage on the rails dropping under load as expected, the voltages on the 3.3v and 12v rails actually increased by quite a worrying amount.
I don't have any real explanation for these results other than the possibility that the Epsilon 700w has some unusual crossloading requirements, or that the power supply has tried to compensate for the load placed on the rails by increasing the voltage (too far).
Either way, an increase in voltage also means a decrease in amperage, which means that the Epsilon may be falling short of its rated output.
Just in case there was an incompatibility between our power supply tester and the Epsilon, we have also tried the unit in our test machine which comprises of the following components: 7900GT, P4 Prescott @ 4.1ghz, 2gb Ram, Laing D5 Pump. The results can be seen below:
Rail
Idle Voltage
Load Voltage
+3.3v 3.29
3.27
+5v 5.08
5.06
+12v1 12.24
12.21
+12v2 12.28
11.91
+12v3 12.25
11.98
+12v4 12.23
12.16
When plugged into a high-end PC, the Epsilon gives voltage readings much more like what we'd be expecting. All voltages remained within ATX specification, and despite the +12v rails dipping by around 0.3v, never fell low enough to cause any problems.
Efficiency Testing
Efficiency tests are performed by measuring the wattage consumed by the power supply at the mains against the power (in watts) consumed by the OC3D power supply stress tester.
The results may not be as accurate as those produced by professional testing equipment, but will certainly come in handy when comparing several power supplies against each other.
FSP Efficiency
The Epsilon 700w was placed under a load of 646 watts. This counts for a total of 92% of the power supplies rated output. At this load, the power supply required 723 watts from the mains to produce the 646 watts required by our custom made power supply tester.
Therefore the efficiency of this power supply can be found by a simple equation: (646 / 723) * 100, which works out to be an efficiency rating of 89.3%
With a load of 646w which is very close to the maximum output of this power supply I was pleasantly surprised by the efficiency, which is in line with the figures given by FSP for this unit.
Noise Testing
As mentioned earlier in the review, the Epsilon 700w makes use of a 2500rpm, 38.3dB fan manufactured by Protechnic Electrics, which pushes 80cfm when running at 12v.
This many not seem the kind of fan you'd associate with a quiet running PC. Thankfully FSP limit the speed of the fan based on the PSU load to counteract this.
In idle situations, the power supply is barely audible at 1 metre away. I'd estimate the noise output at idle to be around 20dBA. However under heavy load the Epsilon increases the speed of the fan substantially, making the unit clearly audible for 1 metre away. I would estimate the noise output under load to be around 28-30dBA.
«Prev 1 2 3 4 5 6 7 Next»
04-07-2006, 06:35:39
Jim
Looking to save some dosh on your electricity bills, but at the same time have enough grunt to power your crossfire rig? Look no further than this review.
04-07-2006, 06:54:00
FarFarAway
Originally Posted by name='XMS
Looking to save some dosh on your electricity bills, but at the same time have enough grunt to power your crossfire rig? Look no further than [B]this review[/B'].
Looks a decent, solid, if not a little strange acting PSU
04-07-2006, 06:59:33
Jim
Yeah it threw a bit of a 'hissy fit' on our load tester, but managed to do pretty well when plugged into the test rig.
04-07-2006, 08:42:35
|3ourne
holy **** ! you both are rocking reviews after reviews. How about sending something for your American brother here ?? Ive been bored out of my mind forever !
04-07-2006, 10:49:38
PV5150
sweet review as usual Jim
04-07-2006, 11:37:41
Ham
Good job mate.
Whats EPS stand for?
04-07-2006, 11:43:31
FragTek
Glad it started working for you correctly mate! FSP usually makes a great unit. My blue storm was the heaviest and most solid psu I'd ever had for the price I paid for it.
04-07-2006, 15:06:17
NickS
Lookin good XMS . Looks very bare inside, yea but it performs well . Those Protechnic fan's rape! I have one in the top of my Lian Li. Came out of a Compaq PSU .
Nick
05-07-2006, 07:08:25
Counter Terrorist Zombie
the hiper uses the same connectors. Just out of curiosity, will you have various charts/graph diagrams comparing all the psus you've reviewed?
05-07-2006, 07:26:34
Jim
HI CTZ,
Yes, once we've got a few more manufacturers on board, i will create a comparison chart so we can truly see what PSU takes the crown
05-07-2006, 13:16:52
NickS
You gotta get a Tagan 1100w to review. Now that'd prolly take the crown *drool* Quad SLi connectors are so sweet, especially the way Topower sleeves them. Topower makes most of the OCZ PSU's, Tagan PSU's, and I think the Mushkin PSU's too... gotta check tho.
Nick
05-07-2006, 17:59:41
WC Annihilus
Ya, Mushkin's is Topower made to Mushkin's specs.
A funny little note is that OCZ's newer Gamestream PSU's are the FSP Epsilons
09-03-2010, 03:41:10
MTBF
FORTRON / FSP Power Supply Units are unreliable hardware devices.
Failed just after 784 days of normal use (about 3500 hours only)!.
