FSP Booster X3 300w 12v PSU
Introduction & Packaging
Published: 12th July 2006 | Source: FSP | Price: |
So you've just upgraded your PC with 2 brand-spanking-new high end graphics cards which you plan to run in SLI / Crossfire. You set it all up, turn it on, only to find that your faithful 480w power supply which has been serving you well for the past year, just cant meet the demands of these power hungry cards.
Up until recently there has only been one option: buy a new power supply. This can be pricey, with most decent SLI certified units starting at around £80-100. However FSP have come up with a more affordable solution, which will not only solve your SLI power woes, but also ensure your PC has enough power for future expandability.
Enter the Booster X3 300w VGA (+12v) power supply. Designed to fit in a spare 5.25" bay, and powered directly from the mains, the Booster X3 provides a total of 25a on a single 12v rail, which should keep your dual card setup happy.
Packaging
Taking a step away from the highly flashy packaging we saw on FSP's Epsilon series of PSU's that I reviewed last week, FSP have opted for more professional look. Yet again, it is a shame that most of us people based in the UK won't get to see it out on retailers shelves, but will instead need to purchase it over the internet.
The back of the box goes into detail about how the unit works, and provides step-by-step instructions on how to install it. I find this a particularly great idea, as many people may be wary of purchasing such an inventive piece of hardware without knowing the steps required to install it.
As you can see from above, the BoosterX3 is very well protected from any kind of transportation damage by being totally encased in a styrofoam cut-out.
- FSP Booster X3 300w unit
- Colour manual
- Power cable
- PCI Bracket for routing AC power inside case.
- Dual PCI-E cable
- Large bag of thumbscrews
- Cable ties
The Booster X3 comes with everything required to get the unit up and running. Strangely it also comes with a huge pack of thumb screws, which is a nice touch but in most circumstances won't be required as 4x cd-rom drive screws are all that's needed to secure the unit.
Where did you find about this one Jim?
- And might i add: before any other review site on the net ;)
They just asked us if we'd like to take a look at one :)
w00t! FSP frickin' r0x0rz b0x0rz. I luvx uz guyz!
silence is important these days.
for example an 80mm fan.
I like the pci power slot thing. good idea.
Also maybe someone with an OEM machine who wants to add a meaty GPU/other accessories :)
