Etasis ET750 750w Quad-SLI PSU
Testing
Search Reviews
Load Testing
In order for the results from all current and future PSU reviews to remain fair and comparable, Overclock3D uses a custom built Power Supply load stress tester.
The tester will be placing the following loads on each of the ET750's rails:
+3.3v - 20a Load
+5.0v - 20a Load
+12v1 - 10a Load
+12v2 - 10a Load
+12v3 - 10a Load
+12v4 - 10a Load
The results are collected from a Mastech MAS-345 Multimeter which logs its readings via RS232 to a PC.
Etasis ET750 +3.3v Rail Etasis ET750 +5v Rail
The ET750 showed excellent results on both the +3.3v and 5v rails. Strangely the +3.3v rail actually increased under load, which just goes to show there is certainly no need to worry about the voltages on the Etasis falling outside of ATX specifications.
Etasis ET750 +12v1 Rail Etasis ET750 +12v2 Rail
Etasis ET750 +12v3 Rail Etasis ET750 +12v4 Rail
Continuing the trend on the +12v rails, the ET750 breezes through our stress testing with a maximum of 0.03v fluctuation on the rails. Yet again, these results place the Etasis up against some of the best power supplies we've ever tester here at Overclock3D.
Efficiency Testing
Efficiency tests are performed by measuring the wattage consumed by the power supply at the mains against the power (in watts) consumed by the OC3D power supply stress tester.
The results may not be as accurate as those produced by professional testing equipment, but will certainly come in handy when comparing several power supplies against each other.
Efficiency
The Etasis was placed under a load of 646 watts. This counts for a total of 86% of the power supplies rated output. At this load, the power supply required 790 watts from the mains to produce the 646 watts required by our custom made power supply tester. Therefore the efficiency of this power supply can be found by a simple equation: (646 / 790) * 100 that works out to be an efficiency rating of 81.7%.
Noise Testing
Possibly the hardest part of any PSU review is summarising the level of noise given out by the unit. The threshold for what is considered 'noisy' varies from person to person and therefore what I may consider a quiet unit, another person may consider extremely loud. A common way to resolve this issue is to use a dBA meter to measure the units noise level, however this doesn't take into account the pitch (type) of noise emitted and whether it is likely to irritate end users.
For this reason OC3D records all power supplies at idle and load in wav format for you to make your own informed decisions. All recordings are taken at 30cm away from the PSU and outside of a PC case. You will need to remember that noise levels will be reduced by varying amounts once the PSU has been installed inside your PC enclosure.
Idle Recording - Download
Load Recording - Download
Under idle conditions the fan speed was significantly throttled. This meant that all that could be heard was the whisper of air moving around the unit.
When placed under load, the ET750 gradually increased the fan speed to counteract the heat. As you can hear from the recording above, the ET750 was fairly noisy. With the Etasis installed inside a PC case this should be much more reasonable.
«Prev 1 2 3 4 5 6 7 Next»
29-09-2006, 10:19:57
Jim
"Today I'll be taking a look at a Quad-SLI certified unit from a little known company called Etasis. Will this unit be able to withstand the OC3D PSU testing equipment? We find out.."
Linky
29-09-2006, 10:38:23
FarFarAway
Looks pretty nice...solid as hell
29-09-2006, 10:59:57
Raging
quality reveiw mate,that is one hell of a solid psu too
looks pretty slick as well.
cheers.
29-09-2006, 11:01:24
FragTek
Wirelessly posted (LG "Fusic": LG-LX550 AU-MIC-LX550/2.0 MMP/2.0 Profile/MIDP-2.0 Configuration/CLDC-1.1)
Wow that looks like a mad nice piece of kit. Competition giveaway?
29-09-2006, 11:10:42
Jim
Lol - nope not this one
29-09-2006, 11:17:23
KuTz
Great review! a good read and an awsome product *Thumbs up*
29-09-2006, 16:18:54
specialtech
Originally Posted by name='Nathan-Nanopoint-UK'
Great review! a good read and a awsome product *Thumbs up*
No discount for you sonny Jim
05-10-2006, 12:12:45
KuTz
Tagan for me
24-11-2006, 11:34:58
NickS
Nice review. Odd, has some Estasis traits AND some Topower traits.
24-11-2006, 11:38:43
Jim
Yeah the twisted cables etc give it a Topower feel, but i'm sure they are just borrowing some good ideas
24-11-2006, 13:45:29
NickS
Yeah, that's what I noticed "topower" like.
You're probably right, just sharing/borrowing ideas . I really like the braid though, almost as much as sleeving. I hate un-braided/un-sleeved PSU's.
24-11-2006, 14:10:02
Jim
Ye i'm not too keen on loose wires either.
Mind you the PSU i'm reviewing at the mo has some nice unsleeved "ribon-style" flat cables..
http://www.overclock3d.net/gfx/artic...124216453s.jpg
24-11-2006, 15:29:28
NickS
Ahh, Corsair HX. Amazing units. I like those cables too. Prolly very easy to route behind motherboards and such.
