Enermax Liberty ECO 500w ATX PSU
Search Reviews
Enermax Liberty EC 500wAs we continually stress to our forum members here at Overclock3D: "500w is more than enough power for almost all PC systems providing you pick a good PSU". Judging by the results we've seen today that's exactly what the Enermax Liberty ECO 500w is: a very good PSU.
During testing the Liberty ECO managed to hold some extremely tight voltages across all of its rails, with the +12v lines only dropping by 0.13v from idle to full load. Both the +3.3v and +5v rails also maintained good stability with a drop of 0.06v and 0.12v respectively. Only when applying a heavy crossload to the unit did things start to get a bit out of hand in Test 5 with the +12v rails shooting up to around 12.8v. However, as I've said many times before, this isn't a situation that you are likely to ever come across on a normal PC, so it's hard to give the Liberty ECO negative marks for this result alone.
Efficiency was also extremely reasonable with 84-85% being achieved under most loads. Sure there are PSU's out there capable of maintaining 88-90% efficiency, but at present these units are extremely expensive - and let's face it, it's not until you start sucking really large amounts of power from the wall socket that a 3% efficiency difference would actually be noticeable.
Finishing off with the scope results conducted while the PSU was roasting away in our 50°C oven, I think its fair to say that these were outstanding. Ripple on the +12v rails never exceeded 20mV even when at full load, and similarly the results from the +3.3v and +5.0v were also among the lowest I've ever seen. Amazing.
At time of writing the Liberty ECO is only available at a limited number of UK based retailers. Scan is one of these few and has the 500w model listed at £85.47. This in all fairness, is at the top end of the scale for what I'd expect to pay for a 500w unit especially considering respectable PSU's from manufacturers such as Seasonic, Silverstone and Cooler Master can be had for £65+.
The Good
- Excellent ripple results.
- Stable voltages, even under heavy load.
- Around 84-85% efficiency at most load levels.
The Mediocre
- Cable sleeving falls short of the cable length.
- Some dodgy voltage and ripple results in certain crossload situations.
The Bad
- 5 modular connectors on PSU, yet only 4 modular cables provided.
- Price quite high for a 500w unit.
Recommended Award
Thanks to Enermax for providing the Liberty EC for review. Discuss this review in our forums.
«Prev 1 2 3 4 5 Next»
18-03-2009, 18:42:28
Jim
"Enermax have brought back an old favourite, only this time with increased efficiency and performance. Join us as we check out the Liberty EC 500w."
http://www.overclock3d.net/gfx/artic...204619204s.jpg
Enermax Liberty EC 500w ATX PSU
18-03-2009, 18:49:23
w3bbo
Nice review mate. 12v rail looks especially good.
18-03-2009, 18:50:04
zak4994
I don't necessarily see anything wrong with the packaging and appearance.
18-03-2009, 18:53:35
monkey7
Yay, another OC3D psu review
Odd though, looks like someone just forgot to include that fifth cable in the bundle. Maybe a packaging error? I bet Enermax could explain somehow.
The psu isn't listed on dutch stores either, so can't give a clue about that. If it's priced around €60-80 this should make a good psu for midrange gaming.
Oh and two suggestions:
- Could you include a 'sound' s... nvm. Already remember the psu tester was too noisy to do so.
- Could you make the review immediately go to a page when you select it with the dropdown menu? I always get annoyed when the page doesn't load until I remember to click the 'go' button.
This must be the weirdest post I've made in quite some time :/
19-03-2009, 03:04:23
Jim
If you are referring the low-ish appearance score mate then thats due mostly to the lack of a modular cable, the cable sleeving and the use of gold (its a bit dated now...no seriously).
That was my first impression, but on the side of the box it actually lists the number of modular cables included and for the 500w model there is only 4. The 650w (or 600w cant remember now) version is the only one to have the full 5 cables.
Yeah I agree. If they can nail the price then I would be tempted to give it Ed. Choice award. I think its just been released though, so may be a few weeks before we see some 'real' prices.
Ye noise from everything else makes it too hard to judge most of the time. I was thinking about measuring fan speed as a substitute, just so you could get an idea of how close it gets to running at full speed and at what load. Not sure if that would be of any use?
As for the Javascript redirect, ye I've been meaning to put that in. It was an overhang from the very first revision of the OC3D website that worked in every browser back to Netscape 4
19-03-2009, 03:14:31
monkey7
Hmm hard one.
Fan speed would sure need an indication, especially if you can tell how the fan itself is at full load by putting it at 12v without the load tester buzzing away. Inside layout of the psu influences sound though, so it would be just an indication.
19-03-2009, 04:28:32
Jim
Hmm hard one.
Yeah. The only other thing that I could possibly do is find a USB sound meter (if such a thing exists) and run it inside the hot box (room temp tests are also conducted inside the box - just without the heater on).
The sound levels would obviously be elevated due to ambient noise, but if I could sound proof the hot box (to an extent) then I could at least produce some semi-accurate dbA readings for relative comparison?
19-03-2009, 05:47:25
Bungral
Excuse me??
Hmm hard one.
19-03-2009, 06:02:59
HypoglossalXII
I've been so spoilt by the larger numbers such as 700W, 1000W, and 1200W that I seem to look down or often just ignore 500W psu these days. Damn these capitalistic marketing schemes!
Enermax has always been pretty decent with their PSU's, but would it kill them to offer their PSU's via their expensive casings?
-HypoG
19-03-2009, 06:21:16
monkey7
Originally Posted by name='Bungral'
Excuse me??
Hey, I'm not Jim Not everything has a filthy meaning
A sound meter would give at least an indication of the noise. Of course it takes a while before this indication has any meaning because the results have to be compared with other psu's tested with the same equipment.
Could be an idea to make a PHP page with a graph of the results. POST message with a psu ID (review no.) would highlight that particular PSU.
19-03-2009, 06:37:57
Rastalovich
These reviews are picking up attention : http://pchardwareblips.dailyradar.com/story/enermax_liberty_ec_500w_atx_psu/
I'll go out on a limb and guess a £70 or so price tag. Being as the wattage up from this in the states is something like $138, ish.
I'm glad to see all the lovely connections on the unit, it's performance is great, the price is probably gonna be a little over what I'd prefer - but hey it's got some quality behind it and it should be a solid investment.
19-03-2009, 07:10:08
monkey7
Very well, we need that attention, should make OC3D more of name
I've got to say google gets us the best publicity though. I got here by googling for reviews of specific components and oc3d regularly turned up on page 1.
