Enermax Galaxy 1000w Quad-SLI ATX PSU
Appearance
Published: 14th December 2006 | Source: Enermax | Price: |
Enermax certainly aren't shy when it comes to appearance. Looking back at some of their older creations, I can remember a PSU that resembled a solid gold bar and many other units sprayed in either red or blue metallic paint. Have Enermax continued this trend with the Galaxy? Lets find out.
Things aren't quite as snazzy this time round, with the unit being sprayed in a glossy (but non-metallic) black paint. I would have put money on Enermax going for metallic considering that this is the 'Galaxy' - but never mind!
The Galaxy features a 135mm clear plastic fan on the bottom of the unit responsible for pushing air over the components, with an 80mm around the back for extracting hot air. Both fans are protected with Enermax's trademark gold fan grills that contrast well with the colour of the casing.
Enermax have done away with the minuscule power switches found on many other units in favour of a heavy duty version and a similarly rugged reset button. This is certainly a necessary feature when you consider that this unit will be drawing substantial power from the mains when at full load.
When you've got a PSU like the Galaxy sitting inside your machine you want to show it off right? Well to help you out, Enermax have placed white 'Galaxy' logo's down both sides of the unit so as long as you've got a windowed case everybody will be able to see what power supply you are 'packing'. It also helps to 'Snazz' up the look of the unit too!
The top of the unit (the bit most people won't see unless you've got one of those up-side down cases) is partially covered with the Enermax specification sticker that details the output of the units rails along with the usual warnings about opening the PSU casing.
nice review and a pretty hefty psu. i see you point about the pre-fixed cables making it half modular but what 1000W pc wouldn't use all those cables anyway lol
That thing is huge....
Looks nice but I'd still buy a PCP&C
now thats a Power Supply!!!!
no no no get out of my head I've spent far too much already
Great review as always guys.
will that thing fit in a normal case lol
wheres NickS? somebody told me he liked enermax
It's impressive... But To big?
1000w?! humph
*walks off in a huff*
Its nice having a 1KW PSU, amazingly enough hardware is coming out that can actually make use of its wattage. The size is kind of a downer, takes some finagling to get it into most cases, maybe a little Dremeling... but once its in, power problems become a thing of the past.
I had an Enermax Liberty 620W PSU, and after 3 months it popped, no rhyme or reason. Thankfully nothing else in my setup got damaged, bought a PC P&C 610W for my backup pc.
You can go cheap with some hardware, especially if reviews are favorable... but for a component that can destroy all your other hardware should something go wrong, I prefer to spend a bit more for piece of mind.
Also, I've read that modular is good, but not as good (yet) as non-modular(?) PSU's. Yes, the Galaxy is only half modular, and it is nice to be able to disconnect unused cables to keep clutter down in a case, but it's still modular. The upshot is that its less expensive than a PC P&C while still being a respectable brand name.
TJS
TJS
wheres NickS? somebody told me he liked enermax ![]() |
-- XMS, did you apply 15a * 5 at one time for a total of 75a of 12v? I wanna see what it does
dang
thats one big fat psu
I have one of these beasts in a Coolermaster Stacker (massive case) and had to adapt the case for it to fit.The 120mm fan on the top will now not fit and had to bend back the alli clips so psu would fit in.Think its about 3 inches longer than a regular psu.
Once in the case it has been a sweet psu,and it is half modular but i only need one of the modular leads.Theoretically you could easilly run 2 high end gaming pc's from this psu.
Linkage
