Corsair HX850W (850w) ATX PSU
Simulated Load Results
Search Reviews
Simulated Load Testing
To provide accurate and consistent results in all of our PSU testing, Overclock3D uses professional grade DC electronic load equipment capable of placing a sustained load of 3690w across a total of six rails (including +5vsb and -12v) on the PSU! This is achieved by using a combination of SunMoon and Analogic electronic load equipment which allow us to adjust amperage loads in increments as small as 0.01A while also measuring voltage and wattage readings on-screen.
During today's tests, we will be placing the Corsair HX850W under 25%, 50%, 75% and 100% load levels at both room temperature and inside a hot box regulated to a temperature of around 50°C. Additional 'Cross Load' and a 'Max Load' tests will also be performed under these conditions to simulate how the PSU reacts to heavily uneven loads as well as running above its specified output.
Corsair HX850W Results @ Room Temperature
   +3.3v  +5.0v  +12v  +5vSB  -12v  AC Watts /
 DC Watts
 Efficiency  Intake /
 Exhaust
Δ Temp
Test 1
(Low)
4.37A 4.37A 14.00A  0.75A  0.20A  233w /
213w
 91.41% 24.5°C /
25.5°C
1.0°C
3.32v 5.10v 12.20v 5.07v  -11.86v
Test 2
(Med)
8.75A 8.75A 28.00A 1.5A  0.40A  458w /
426w
 93.01%  25.3°C /
26.1°C
0.8°C
3.30v
5.08v
12.18v 5.02v  -11.84v
Test 3
(High)
13.12A 13.12A 42.00A  2.25A  0.60A  684w /
637w
 93.12%  25.5C /
26.2°C
0.7°C
3.26v 5.06v 12.14v 4.98v -11.83v
Test 4
(Full)
17.50A 17.50A 56.00A 3.00A  0.80A 930w /
848w
91.18%  25.5°C /
27.2°C
 1.7°C
3.24v 5.04v 12.14v 4.93v -11.85v
Test 5
(x-load)
17.00A 16.00A 1.00A 0.00A 0.00A  176w /
149w
84.65% 25.0°C /
26.1°C
1.1 °C
3.30v 5.08v 12.20v 5.11v -12.47v
Test 6
(x-load)
 1.00A  1.00A  69.40A  0.00A  0.00A  910w /
850w
93.40%  24.5°C /
26.3°C
 1.8°C
3.29v 5.06v 12.14v 5.06v -13.08v
Test 7
(MAX)
 21.00A  21.00A 73.00A  4.50A  0.60A  1201w /
1084w
90.25%  26.4°C /
28.7°C
 2.3°C
3.21v 5.02v 12.10v 4.85v -12.09v
Starting with tests 1-4 (the ones you're most likely to see in real life) the HX850W has left me pretty much speechless. Not only was voltage regulation extremely tight all the way up to 848W load, but the efficiency...DAMN, the efficiency was simply amazing staying above 91% at all times. This clearly also had a knock-on effect on the exhaust temperature of the unit which rarely moved more than 1°C above the Intake temps, showing that there is VERY LITTLE energy wasted inside the HX850W during AC/DC conversion.
Moving on to the cross load tests 5 & 6, very little changed in terms of voltage regulation. In both tests the HX850W laughed in my face, keeping all rails totally in check like nothing was happening. Only in Test 5 did the testing manage to chip away at the stellar efficiency of the unit by bringing it down to 84.65%. Seriously though, this is still better than a lot of PSU's can manage on a good day!
Finally in test 7 the HX850W was hooked up to both of our load testing machines to try and bring the unit to its knee's. Did I manage it?...did I hell! With 21A on both the +3.3v and +5v rails and 73A on the +12v rail the PSU was still laughing at me while delivering rock solid voltages. That's 1084W by the way, 234W more than what it says on the box!
In one last off-the-record attempt to get one over on the HX850W I hit it with everything it could take on the +12v rail. 91 AMPS was the read-out on the load tester before the PSU finally decided safely power off. Even then the voltage readout was 12.12v  right up to the end. Corsair - 1, Me - 0!
Corsair HX850W Results @ 50°C
 DC Watts
 Efficiency  Intake /
 Exhaust
Δ Temp
Test 1
(Low)
213w
 91.41% 50.4°C /
49.7°C
-0.7°C
Test 2
(Med)
8.75A 8.75A 28.00A 1.5A  0.40A  460w /
426w
 92.60% 51.2°C /
50.8°C
-0.4°C
3.30v
5.07v
Test 3
(High)
13.12A 13.12A 42.00A  2.25A  0.60A  685w /
637w
 92.99%  51.9C /
52.4°C
0.5°C
3.26v 5.06v 12.14v 4.97v -11.83v
Test 4
(Full)
17.50A 17.50A 56.00A 3.00A  0.80A 933w /
848w
90.88%  50.7°C /
51.5°C
 0.9°C
3.24v 5.04v 12.14v 4.92v -11.87v
Test 5
(x-load)
149w
84.65% 52.0°C /
52.8°C
0.8 °C
3.30v 5.08v 12.20v 5.09v -12.47v
Test 6
(x-load)
 1.00A  1.00A  69.40A  0.00A  0.00A  913w /
850w
93.09%  51.2°C /
52.5°C
 1.5°C
3.29v 5.06v 12.14v 5.06v -13.06v
Test 7
(MAX)
 21.00A  21.00A 73.00A  4.50A  0.60A  1206w /
1084w
89.88%  49.9°C /
52.0°C
 2.1°C
3.21v 5.02v 12.09v 4.85v -12.09v
Bumping up the ambient temperature to a toasty 50°C and re-running the room temperature results, hardy anything at all changed. In fact, aside from the odd +/-0.2v fluctuation on a couple of the rails and a few dips in efficiency, the results might as well be classed as identical. It really is beginning to look like nothing I can throw at the HX850W can phase it in any way, shape or form.
Corsair HX850W Scope Results @ 50c
   +3.3v  +5.0v  +12v
Test 1
(Low)
T1_3.3V T1_5V T1_12V
Test 2
(Med)
t2_3.3v t2_5v t2_12v
Test 3
(High)
t3_3.3v t3_5v t3_12v
Test 4
(Full)
t4_3v t4_5v t4_12v
Test 5
(x-load)
t5_3.3v t5_5v t5_12v
Test 6
(x-load)
t6_3.3v t6_5v t6_12v
Test 7
(MAX)
T7_3.3 T7_5 T7_12
For the last part of the testing I analysed the ripple on the +3.3, +5 and +12v rails using a Rigol 25Mhz 400MSa/s oscilloscope. All readings were taken while the HX850W was installed inside the 50°C hot box to provide us with worst case scenario results.
Yet again the HX850W gave stunning results with the +3.3v and +5v rails staying below 10mV ripple in tests 1-6 and only hitting 12mV ripple in test 7. The +12v rail was also extremely clean with ripple starting at 10mV in test 1 and only increasing to 32mV by test 4. Test 7 saw the ripple hit 42mV, but this is still way below the maximum of 120mV as specified by ATX standards.
Now let's move on to the conlcusion where I try to sum up everything seen today...
«Prev 1 2 3 4 5 Next»
25-06-2009, 07:38:09
Jim
"Both the Corsair HX620W and HX1000W PSU's were massive hits among enthusiasts, but how does the recently released HX850W perform? Today we find out."
http://www.overclock3d.net/gfx/artic...183437159s.jpg
25-06-2009, 07:40:46
tinytomlogan
Love the Corsair PSU's, always have and here is another wicked reason too <3
25-06-2009, 08:19:08
uchihas
Oh my god! That's simply amazing! What an amazing efficiency and stability, it seems that Corsair knows how to improve even more the things that are really good.
25-06-2009, 08:38:52
Jim
Yep. Right at this moment in time I would say that this is the best PSU you can buy. Enermax Revolution85+ comes in a fairly close 2nd, but the HX850W really dominates.
25-06-2009, 08:41:48
monkey7
1kW off a 850W unit without it even blinking O.o That is one rock solid unit right there.
25-06-2009, 08:52:47
Jim
Yeah and 91A off a 12v rail rated at 70A! Anybody still into peltier cooling?
25-06-2009, 08:59:18
Ham
Here's an odd question, does it fit in the PSU bay of the dimas bench tables?
Ask because the kettle plug on my CM unit is situated very close to the edge, meaning it can't be used .
25-06-2009, 09:00:30
tinytomlogan
feels a fight brewing
25-06-2009, 09:06:58
Rastalovich
Heck of an impressive unit. Price is a little arguable, but tbh it's a quality purchase.
U have to hand it to Corsair when it comes to packaging their psus.
25-06-2009, 09:15:04
cl0ck_ed
why have the cost of psu's gone up so much??. a year ago the hx1000 was £140.
25-06-2009, 09:21:13
Jim
Yeah they have all gone up recently. Not entirely sure why but it started happening abut 3 or so months back.
In the current market tho, £140 is actually very good for a decent 850w. I think the Enermax is closer to £180 which is mighy painful.
25-06-2009, 09:24:06
Jim
Hmm not entirely sure as the kettle plug on the HX is also quite close to the edge. I'll give it a try ad let ya know.
25-06-2009, 09:59:50
Rastalovich
Companies used to have scaled templates on their sites for purposes like this, wonder if Corsair do ??
25-06-2009, 12:39:27
tinytomlogan
Its because the £ is still worth lots less than it 'should' be against the $
27-06-2009, 09:48:02
Rastalovich
It's not quite how the UK economy works these days. Ever since the increase in customs control on imported items, especially from outside the EU - but alarmingly (in this "free trade" era) including the EU.
Their pricing considerations start with "what can we get away with charging" b4 they even think of US or EU prices. No thought what-so-ever of costing of production or shipping or anything logical that u might learn in economics.
The previous examples of supply and demand bringing about an equilibrium price are no longer applicable.
27-06-2009, 11:10:51
Wyshniukas
I like Corsair PSUs, have one, but those flat modular cables just doesn't go with me. Round ones would have been brilliant update on this PSU, in my opinion.
12-07-2009, 07:03:17
w3bbo
Sweet PSU...excellent review!
12-07-2009, 19:18:38
mayhem
Any info on this. would be interesting to hear as i need to upgrade my screaming PSU.
13-07-2009, 03:46:31
Jim
To be honest I'd totally forgot. I'll try and remember to dig the case out of the garage tonight and give it a whirl.
17-10-2009, 15:37:03
gorilazm
Few days ago purchase coolmaster 850 modular. i thought it will be quiet and many online test reviews say that, but the actual PSU make annoying noise like small transformer what make him louder then own cooler. can you,please, tell me is Corsair hx850w have any annoying cracking/bugnoise accept cooler. will you say it is really quite PSU.
25-10-2009, 15:10:58
e07
Have to say that I have being using the HX850w for nearly two months now and I am kinda sorry that I bought it. It is much louder that my last psu ( tagen turbojet 900 ).Then all I could hear were the hard drives. Can get on your nerves after a while but I am stuck with it as I sold my tagen.
25-10-2009, 16:21:46
Jim
I find that really surprising. Are you sure your HX850w doesnt have a faulty fan? The Tagan Turbojets are named that way for a reason...they sound like an airplane taking off.
26-10-2009, 05:10:24
e07
The tagen for me was very quite.You could just about hear it when it was working hard but it had no anoying 'whine'. My HX850 on the other hand has an soft but noticable 'whine' that gets on my nerves. It just has a different sound that I dont like. But thats me and others may have no problem with it.
26-10-2009, 18:32:59
Stefan Payne
No, not neccissarily.
I've heard some complaints about the noise of the two new HX-Series Units.
Maybe you had the version with a Yate Loon fan and he had one with Ong Hua fan.
26-10-2009, 18:34:34
Bungral
My HX750 is lovely and quiet.. Only thing I can hear is my pump vibrating against the foam I have it on. Hmmm have to sort that out.
27-10-2009, 08:02:55
Nelly
I bought the HX750 just over a week ago, have to agree very quiet, I much prefer the cable connectors on these PSU's too - 7 year warranty which Scan will cover for you which is excellent.
28-10-2009, 22:22:07
bapetpe
That's great! That's quite a very informative post. Thanks for your share.
12-05-2010, 14:21:07
fredeb
I myself own a HX850W , runs cool and quiet - amazing PSU .
21-06-2010, 15:48:15
Kartoff
The best PSU ever made i think !!! If u have noises seems u can stop the fan and PSU dont overheat And also seems it can handle even more than 1084W if u do something with protections ;-) Really verry nice PSU !!! I have it a couple of monts and will buy it again
