Corsair HX850 V2 Power Supply Review
Simulated Load Results (Graphs)
Search Reviews
Corsair PSU new
Because I understand that not everyone enjoys getting a headache from trying to read the tabulated results over on page 4, this page is dedicated to some pretty looking graphs that sum up the majority of the results in an easily digestible format.
When viewing the graphs you need to bear in mind that the highest and lowest values on the Y-axis (voltage) represent the maximum and minimum voltages allowed by ATX specifications. If the results should fall outside the graph at any time, then that's an instant FAIL. However, merely staying inside these boundaries does not necessarily indicate a good PSU. In order to display truly great voltage regulation, a PSU must stick as closely as possible to the thick white horizontal line (ideal voltage) as possible.
You will also notice that the graph is split into three sections as depicted by the Green, Amber and Red backgrounds. These indicate normal usage (green), heavily uneven load distribution (amber) and overloading of the PSU (red). For the most part all we need to worry about is how it performs in the green section, but good performance in the other sections will undoubtedly earn the PSU extra brownie points.
Starting with the +3.3v rail, the HX850 offers a very gentle downward gradient across the normal load results (T1-T4) indicating excellent stability. Furthermore, the near-Idle results in T1 come out at 3.34v showing that Corsair have not attempted the age-old trick of over-volting the output at idle to make the full load results seem more favorable. Both of the cross-load voltages are pretty much perfect as well - the first time I've ever seen such a result in any PSU tested on OC3D.
The +5.5v rail tells a similar story with not much of a dip in voltage from idle to full load under the normal tests. The only real difference is that the idle voltage starts a little higher at 5.05v, bringing the rest of the results up a tad and placing the voltage output during test 3 at exactly 5.00v. Once again, the cross-load results are easily the best I've ever seen with almost perfect voltage outputs.
As I've come to expect form Corsair PSU's, the +12v rail results during normal load tests are so flat that I could park my car on them with the hand-brake off. Manufacturing a PSU that drops only 0.16v from idle up to 852w is no mean feat, and it's good to see that Corsair haven't let their standards slip over the years with the release of their new line-up. Best of all though is the TMax result that drops to only 11.80v when running at a whopping 1081w - 231w over spec.
Finally we come to the tree hugging and money saving bit. Corsair have had the HX850 certified as an 80Plus Gold unit, which essentially means it must be 87% efficient at 149.6w / 850w loads, and 90% efficient at 425w. As we can see, that is absolutely no problem for the HX with just over 91% efficiency or greater in all of the standard tests. Only when we apply the extreme cross loads does the % levels drop but this is not part of the ATX specifications. Its worth noting by our tests this would pass the levels needed for a platinum rated efficiency!
If you're interested in how the HX performed under the oscilloscope. Read on....
«Prev 1 2 3 4 5 Next»
01-08-2012, 09:32:43
tinytomlogan
http://www.overclock3d.net/gfx/artic...034458108l.jpg
Corsair are back with a revamp on the HX850 PSU. Will it be a huge leap forward like the original? Its time to test and find out.
Continue Reading
02-08-2012, 02:46:44
Ulijin
Originally Posted by tinytomlogan View Post
we still have not found a use for the velvet bag once you have actually fitted your PSU....
1. Give it to your missus as a jewelery bag
2. Cut 3 holes in the back of it for your little dog / cat's legs and tail and fasten. Now you've got an instant diaper to stop the little bastard crapping all over your house
3. Use it to store the stock fans that arrived with all your PC components that you can't bring yourself to throw away.
4. Use it to store component instructions (I actually do use my one for this)
5. Use it to store random lists.... of which this really is one
02-08-2012, 07:01:08
wassupdoc
haha
02-08-2012, 11:39:46
airdeano
Tom's video and James' written has nailed it again, awesome job team OC3D!
other than the colored wires under the cable braid.. it's a Corsair PSU with strength, stamina,
and style.
gaining a pretty good collection of velour PSU bags and felt Crown Royal bags.. myself
airdeano
06-08-2012, 09:21:03
kilobravo
There`s some new competition,but Corsair is still up there.
Can hardly wait for the AX1200i review.
06-08-2012, 09:32:07
tinytomlogan
Jim has been really ill recently so we will get it up as soon as he is well enough to test it dude
06-08-2012, 09:52:36
Mister B
This is such a sickener. I bought my HX 850 only two months ago. And then they revamp it :/
06-08-2012, 09:54:23
Josh Weston
Ah, it's always the way.
You do still have a great PSU though, so it's not the end of the world.
Also; welcome to the forums
06-08-2012, 09:56:21
Mister B
That is true I wonder how much reworking was actually put in to push it up to 80+ gold?
And thank you! I have been reading threads here for years so I said I might as well register
06-08-2012, 10:14:35
kilobravo
Hope its nothing to serious.
Best thoughts to Jim.
20-08-2012, 15:50:30
shadow
I hope Jim has a speedy recovery.
08-10-2012, 15:14:39
kejser11
Nice review, as always! When can we expect a testing of Corsairs first platinum-rated PSU, the AX 1200i? really eager to see it put through its paces!!
