Corsair HX650w 650W ATX PSU
Published: 15th January 2010 | Source: Corsair | Price: £93.40 |
"If it aint broke, don't try to fix it...just update it". This phrase (although slightly modified) pretty much sums up what was going through Corsair's heads when they decided to release the HX650w. They knew that they already had one of the most respected PSU's on the market with the HX620w, so why change anything that didn't absolutely need it? The look of the unit was great, the size was just perfect, the modular connectors were a hit. All that really needed updating was the efficiency and maybe a few other minor performance tweaks to prevent any other manufacturer from knocking it off its perch.
And that's all they did.
The HX650w IS in simple terms a HX620w with ~6% higher average efficiency, slightly more stable voltages, and according to Corsair, lower noise output thanks to less energy being wasted as heat.
Additionally the tests over on the previous page also show that the HX650w has awesome ripple suppression, a working set of safety features that kick in at around 720w load and the ability to deliver pretty much its entire 650w output on the +12v rail alone.
As per usual the packaging is second to none, the 7 year warranty included with the HX650w is exactly whats needed to show people that a PSU purchase is for life, not just for Christmas (sigh) and the average retail price of £90-95 is more than acceptable for a PSU of this caliber.
So what is there not to like? Well, I cant deny not being every-so-slightly disappointed when I found out that Corsair didn't opt to use CWT as the OEM for this unit as they did for the amazing HX750w and HX850w models. Why? Simply because the HX750w for example has higher efficiency, even more stable rails and in my opinion a better modular connector interface. Of course, I've already mentioned that Corsair probably didn't want to run the risk of spoiling a good thing, and additionally the CWT units are generally quite a bit more chunky than similar wattage Seasonic variants - so the size of the casing may have not been able to stay the same.
But at the end of the day the HX650w is one great PSU and that's all there is to it.
The Good
- Stable voltages across all rails
- Reasonably high efficiency with an average of around 86%
- Great looks and tasty modular cables
- Excellent ripple suppression
- Max output around 720w
- All Japanese caps.
- 7yr warranty!
The Mediocre
- Not quite as efficient or stable as the HX750w or HX850w
- Didn't like one of the cross-load tests (but as I've said already 3 times, its not likely to be reproduced in real world)
The Bad
- Nothing.
Thanks to Corsair for sending their latest PSU in for us to torture. Discuss this review in the OC3D forums.
Originally Posted by name='thestepster'
nice review jim, im upgrading my psu pretty soon and these corsairs are defintely the way 2 go but i was going to get the HX750 one since its more future proof
1) Form and fit (not afraid of a little metal work, however)
2) cable management (more along the lines of reach and airflow than aesthetics), and
3) the PSU's ability to handle Stepped Approximated Sine wave or Pulse Width Modulated sine wave UPS's (battery side only, not AC side).
These Dells are notorious for crashing when presented fake sine waves from their power sources. Any idea if the Corsairs care if it's a pure or fake sine wave? Ever test that? If interested pick up an APC BX1300G and see if your PSUs puke when it goes into battery mode... I'd be real interested in the result!
Great report, Jim.
Cheers, BZ
To be honest I have little (read:no) experience with aftermarket PSU's in Dell machines. The last I heard tho was that they switched around certain cables on the ATX connector so that only their PSU's would work and anything else would go *bang*. Not sure if this is still the case though?
All the recent Dell machines I have replaced PSUs in have had standard ATX (albeit crappy) units in them. I would think yours is no different, the only issue I can forsee is if there is enough room in the case for a new one, since Dell OEM PSUs tend to be on the short/small side and the Corsair units are a little bigger. Remember you'll need some cable clearance too. The only newer Dells that I've worked on with non-standard PSUs were smaller form factor machines, which is almost to be expected, though even some of the larger towers (probably not XPS) have been more narrow than normal.
Never seen a Dell with the ATX connectors switched round wrongly yet, I would hope that they'd also change the plug so that a standard one simply wouldn't fit in that case, who knows if they do or not.
I can see many complaints on the net about your PSU having problems like you mentioned, but no issues with Corsair units in the same way, so I would think a decent quality unit would solve the problem or not present the issues you are concerned about.
Remember, if you buy a unit from the internet, you can use the Distance Selling Regulations to get it returned if you find out it won't fit, but you do only have 7 days to do that and obviously you mustn't damage it.
Hope that helps.
I have a Corsair HX620 ready for RMA (still) and by the sounds of how they operate I may get back one of these newer units, glad to hear it's at least an improvement on the old one.
Thanks for the feedback and sharing your observations/experience. I've been inside the XPS tower - it seemed pretty roomy, bet then again I wasn't trying to replace the biggest blob inside the box at the time. Based on your and Jim's reply I guess the best thing to do is get a multimeter out and check everything before trying to slip it in place. Agree - not changing the plug while messing with polarities and voltages would be criminal. I'm building my next box...
Thanks again both. I'll report back after the Corsair arrives (tomorrow as scheduled).
Cheers,
BZ (from across the pond - Northern Virginia, USA)
It seems that starting after September of 1998 Dell defected from the cause of industry standardization and began using specially modified Intel supplied ATX motherboards with custom wired power connectors. Of course they also had custom power supplies made that duplicated the non-standard pinout of the motherboard power connectors.
An even bigger crime than simply using non-standard power connectors is that only the pinout is non-standard, the connectors look like and are keyed the same as is dictated by true ATX. There is nothing to prevent you from plugging the Dell non-standard power supply into a new industry standard ATX motherboard you installed in your Dell case as an upgrade, or even plugging a new upgraded industry standard ATX power supply into your existing Dell motherboard. But mixing either a new ATX board with the Dell supply or a new ATX supply with the existing Dell board is a recipe for silicon toast. How do you like your fried chips, medium or well done?
source
So - I ordered an HX750W from the net and after doing so thought it prudent to call Corsair to discuss this before installing. Explained my situation to the quite knowledgable tech; mainly the story on the factory PSU, speed bumps people had run into, and my problem with the OEM power supply not liking the "dirty" AC signal coming from my UPS's inverter. He said he'd never seen that problem with a Corsair, so that was the first bit of good news. I was torn between sticking with the old PSU and upgrading to a pure sine wave UPS (less risk) - or - buying a new PSU and sticking with my relatively inexpensive UPS (much less cost despite making a major upgrade to the PC itself). Whilst speaking with him he urged me to verify (with Dell) that my motherboard was ATX12V 2.2 (& backward) compliant, had a 20+4 pins main power plug and either an 8 pins or 4 pins power plug for the CPU. So off I went first to Intel to read the ATX 2.x spec. Found pinouts and other information useful to non-Dell users - since Dell only publishes scant marketing level descriptions (hardly full specs). So then off I went to (useless) Dell. The only thing they could tell me was their part number (F217J) for my original PSU - couldn't recommend any others as replacements. I cross-referenced that to a Flextronics Model #VP-0900073-000. Couldn't verify that it was ATX 2.2 compliant, but found a few posters out there who claimed to have successfully replaced this exact model with a number of differing brands, all ATX 2.2 compliant PSU's. The new Corsair arrived yesterday and down went the PC to the workshop. I cracked the machine open, cleaned and dusted, took a bunch of pictures and measured stuff. Decided it would fit and it was safe to open the new Corsair.
Wow - was I thrilled when I opened up that box! High quality nylon pouch for the modular cables, packaging like I've never seen before (velvet-like bag containing the PSU), wire ties, extra mounting screws and a very well written installation guide - even a metal "Powered by Corsair" logo tag for the outside of the machine. I was really impressed. So, the new PSU was about 1/2" shorter and about 7/8" longer, but turns out those dimensions don't matter much in my chassis. True to form, Dell's external mounting holes in the chassis didn't line up with the PSU. I extended the upper right chassis hole by making it a bit oblong (up and to the right about 1/8") and drilled a new lower left hole (about 5/16" directly below the original one). New PSU slipped right in and the holes lined up with their threaded mounting screw bosses in the PSU case. Because the Corsair isn't as tall, it didn't rest on a stamped-out horizonal chassis tang that the original rested upon, but there was no give or movement of any kind once the four screws were securely in place. The cables are some of the best quality I've ever seen. Took about 15 minutes to route stuff, another 10 minutes to tidy and close things up, and back up to the office I went.
Fired right up (I like my chips medium, thank you Jim). UPS monitoring S/W said I was burning 195W - about 50W less than before (I suppose that's a manifestation of the unit's efficiency... cool!). Then off to test the el cheapo APC Back-Up system (el cheapo - US$169 - not that cheap). Ran the self test and voila. It worked. This PSU's so quiet - what a purchase.
Jim and alexhull24 - I owe you a debt of gratitude. Thanks for the prudent warnings and good advice - and Jim - thanks for the exceptional review the 650. While I didn't necessarily write this for just you gents, I thought you might appreciate the detail and the news on the XPS Studio 435T's ATX 2.2 compliancy. Maybe somewhere along the line Dell got the message... Then again, probably just an "oversight" on their part.
One footnote. Someone out there blamed Active PFC as the root cause of my problem between the PSU and the UPS. Not true. The old PSU is a switching PSU. Says so right on the label. Glad I didn't rule out Active PFC. Had I followed that "advice" I probably would not have bought this and may have ended up with the same problem... There you go, Jim. See if you can show that Switching PSU's can't handle the Step Approximated or Pulse Width Modulated sine waves. Maybe that's the root cause... Maybe it's just a piece of junk Dell OEM PSU that's the problem.
Cheers,
BZ
Attachment 2844
Continue Reading
