Corsair HX620 620w Modular PSU
Connectors
Published: 27th November 2006 | Source: Corsair | Price: |
As I've said in previous modular power supply reviews - some like the idea of modular, some don't. Those in favor of the design are likely to be those who spend hours routing cables behind their motherboards to prevent them from being seen through their case windows. At the opposite end of the scale are the more skeptical PC enthusiasts who believe that the modular cabling system is unreliable and can cause increased resistance where poor connectors are used. In the end it really comes down to the quality and type of connectors the manufacturer has adopted for the unit and how well they have implemented the design.
Corsair have made a departure from the sleeved cabling used by almost all other PSU manufacturers in favor of a moulded plastic, ribon style cable. Not only are these slimmer than the standard sleeved cable (especially when bundled together with a cable tie), but they are also extremely flexible and look very cool. The only disadvantage of course, is that they cannot be easily sleeved in another colour to suit your customised PC.
Seems very pricy to me though.
Price?
Originally Posted by name='Mr. Popo'
Price?
Originally Posted by name='Ham'
Read the review, its in there.
Can I see a quote?
Originally Posted by Mr. Popo
I've read it twice, nothing...
Can I see a quote? |
Originally Posted by XMS
"For a ~600w unit the sum of £96 (over at Scan.co.uk) may seem a little higher than most other competing products, however as the saying goes - "You get what you pay for", and this is certainly true for the HX620."
I was looking for $$$.
Originally Posted by Ham
Had a quick flick though. Another good job Mr XMS.
Seems very pricy to me though. |
Another thing to add is the 5 year warranty has to be worth something extra, I rate it very highly and I have had or built PC's for other people dozens of different PSU's.
PS Very nice review as usual XMS.
Another great feature is it's quiet operation, in my humble opinion only the Etasis 750 850 Sliverstone series are better, the downfall of those for me are the noise and not being modular.
I hope when you get yours your as pleased as I am with mine.
Originally Posted by kimandsally
Hi Frag, I'm sure you will be pleased with it the cables are a nice touch if you like them, they are slightly stiff but they are easy to bend and move around will make your case look great.
Another great feature is it's quiet operation, in my humble opinion only the Etasis 750 850 Sliverstone series are better, the downfall of those for me are the noise and not being modular. I hope when you get yours your as pleased as I am with mine. |
I'm not all too terribly worried about the noise levels as I've got a couple of noisy 120's inside the Vapo case which will probably outnoise the PSU, hehe. I am looking quite hard @ the SS psu's as well, but I'm really really liking the cables they've used on the Corsair.
Originally Posted by name='FragTek'
Thanks! I'm sure I'll be a happy camper once I find one
I'm not all too terribly worried about the noise levels as I've got a couple of noisy 120's inside the Vapo case which will probably outnoise the PSU, hehe. I am looking quite hard @ the SS psu's as well, but I'm really really liking the cables they've used on the Corsair. |
Originally Posted by name='kimandsally'
Don't know what the price would be but I would send you one from the UK if your stuck.
Canadian site, so you could pick it up pretty cheap
Same about the price..
and the reason for this is that it has 1 big 12v rail and not 3 different 12v rails.During the +12v load testing, each of Corsair's three rails (rated at 18amps) were placed under a total load of 30 amps. As a result of this, each rail produced the same voltage output results across the board and therefore only necessitated a single graph as shown above.
all 3 rails gets their power from a single transformer and the rails are not differented on pcb level but more on the wire level.
one reviewer asked corsair about this and received this explanation.
For this, Corsair sent us this explanation: “Since our PSU follows the latest Intel design spec, it is consider an UL Level 6 design, which means there is no 240VA limitation on the +12V rails. In addition, all the +12V rails are drawing from single transformer, the rail separation is not done on the PCB side, but on the wiring side. Therefore the +12V1 and +12V2 you see on the PCB doesn't really mean anything.”
another reviewer loaded one single rail with 40a and didnt notice any drop in V or any other problems such as overcurrent shutoff.
Although it is not a new product it was showcased at CeBIT 07 powering a monster system - a watercooled, overclocked quad FX with 8800GTS SLi, 4gb of OC'd ram and a 150gb raptor plus the usal bits and pieces...
All on 620w!
Link I know it's the Inq but it is true!
Anyone tried or seen this configuration, thanks for any info.
For those interested im looking at making something along the lines of:
Lian-Li V1000B
Corsair HX620W
Core 2 Duo E6600
Thermalright U-120 Extreme
Asus Striker Extreme
2Gb Corsair dominator
XFX 8800GTX 768MB
X-Fi Elite Pro
Adaptec 3805 (8chan PCIe raid)
4x 500GB Seagate 7200.10 (Raid 5)
1x 150 GB Raptor
Dell 2407WFP
.Nice spec you got there btw, 2TB
Get the dremel out if there is any issues
.Nice spec you got there btw, 2TB ![]() |
Last case was a custom modded H2O cooled Lian Li PC70 with a 120x240 radiator modded into the top panel, self built custom FanBus, window, Cathodes etc. Hoping to keep this one nice and plain and simple as I dont really have the time and workshop space these days to do this kind of work
Well 1.5Tb once you take raid into account (less due to native drive sizes etc)
Should be about 1.6Tb once you add on the 150Gb raptor system drive.
Last system I have was built some time ago now:
Barton 3000
1Gb Ram
Ati 9800pro
640Gb Hdd
So its about time I treated myself .
Probably be another month till I have the spending money together to pull this off, so will likely have changed a bit by then anyway.
http://upload.overclock3d.net/get.php?id=3606
The VX-550, and the TX-750 are not Seasonic built, they are build by Channel Well(CWT). They seem to be just as good quality, although they are not as quiet as the Seasonic built models(VX-450, HX-520, HX-620 and TX-650)
From the whirlpool forums
http://forums.whirlpool.net.au/forum-replies.cfm?t=858908&r=13612187#r13612187
Originally Posted by name='node159'
Something to consider when picking up a Corsair PSU:
From the whirlpool forums http://forums.whirlpool.net.au/forum-replies.cfm?t=858908&r=13612187#r13612187 |
Linkage
