BFG EX-1200 (1200W) Modular PSU
Simulated Load Testing
Search Reviews
To provide our readers with the most accurate results, Overclock3D uses a professional grade SunMoon SM-268+ ATE load tester capable of placing a sustained load of 1690w across a total of six rails (including +5vsb and -12v) on the PSU. Unlike our previous resistor-based load tester, the SM-268+ gives us the ability to adjust amperage loads in increments as small as 0.01A while also measuring voltages and wattage readings on-screen.
During today's tests, we will be placing the BFG EX Series 1200w under 25%, 50%, 75% and 100% load levels at both room temperature and inside a hot box regulated to a temperature of around 50°C. Additional cross load tests will also be performed under these conditions to simulate how the PSU would perform with a heavily uneven distribution of load. It should also be noted that the all +12v rails on the BFG EX will be combined during the testing, allowing us to make best use of the load testers configuration.
BFG EX Series 1200w Results @ Room Temp
   +3.3v  +5.0v  +12v  +5vSB  -12v  AC Watts /
 DC Watts
 Efficiency  Intake /
 Exhaust
Δ Temp
Test 1
(Low)
5.50A 5.00A 18.50A  0.75A  0.12A  326w /
271w
 83.12%  24.9°C /
  30.3°C
 5.4°C
 3.29v 4.94v 12.08v 4.93v  -11.46
Test 2
(Med)
 11.00A  10.00A  37.00A 1.5A  0.25A  630w /
538w
 85.39%  26.0°C /
44.5°C
 18.5°C
3.24v 4.89v 12.00v 4.89v  -11.64v
Test 3
(High)
16.50A 15.00A 55.50A  2.25A  0.37A  941w /
808w
 85.86%  27.1C /
56.5°C
 29.4°C
3.21v 4.85v 11.94v 4.84v -11.91v
Test 4
(Full)
 22.00A  20.00A  74.00A  3.00A  0.50A  1279w /
1065w
 83.26%  27.2°C /
66.7°C
 39.5°C
3.17v 4.82v 11.86v 4.79v -11.90v
Test 5
(x-load)
22.00A 20.00A 1.00A 0.00A 0.00A  264w /
193w
73.10% 21.1°C /
45.5°C
 17.4°C
3.24v 4.87v 12.06v 4.93v -12.04
Test 6
(x-load)
 1.00A  1.00A  74.00A  0.00A  0.00A  1012w /
890w
87.94%  28.0°C /
52.4°C
 24.4°C
 3.24v 4.91v 11.92v 4.90v -12.09v
Starting first with the efficiency results, the EX-1200 certain surpasses the 80% efficiency quoted on the packaging with 83% straight off the bat in test 1 increasing to 85% in tests 2 and 3. Things go quite a bit down hill as the +3.3v/+5v crossload is applied in test 5 with the unit dipping down to a rather nasty 73% efficiency. However, as soon as the crossload is weighted towards the +12v rails in test 6 the EX-1200 more than redeems its self with close to 88% efficiency!
Voltage stability throughout the testing was reasonable, with each of the rails starting quite close to their 'ideals' in test 1 and maintaining good stability all the way up to test 3. Only once the unit is placed under a 1065W load in test 4 does it start to show signs of strain with the +3.3v rail dropping down to a lowly 3.17v but both the +5v and +12v rails remain well within spec producing voltages of 4.85v and 11.86v respectively. Additionally, the grueling crossloads of tests 5 and 6 didn't phase the EX-1200 in the slightest, with decent voltages throughout.
BFG EX Series 1200w Results @ 50c
 DC Watts
 Efficiency  Intake /
 Exhaust
Δ Temp
Test 1
(Low)
5.50A 5.00A 18.50A  0.75A  0.12A  329w /
271w
 82.37%  50.7°C /
  53.7°C
 3.0°C
 3.27v 4.93v 12.06v 4.93v  -11.51
Test 2
(Med)
 11.00A  10.00A  37.00A 1.5A  0.25A  634w /
538w
 84.85%  50.6°C /
64.3°C
 13.7°C
3.23v 4.89v 12.00v 4.88v  -11.73v
Test 3
(High)
16.50A 15.00A 55.50A  2.25A  0.37A  952w /
799w
 83.92% 50.6C /
71°C
 20.4°C
3.20v 4.85v 11.92v 4.84v -11.93v
Test 4
(Full)
 22.00A  20.00A  74.00A  3.00A  0.50A  1283w /
1065w
 83.00%  50.9°C /
78°C
 27.1°C
3.16v 4.80v 11.84v 4.79v -11.98v
Test 5
(x-load)
22.00A 20.00A 1.00A 0.00A 0.00A  263w /
192w
73.00% 50.4°C /
67.6°C
 17.2°C
3.23v 4.87v 12.04v 4.93v -12.07
Test 6
(x-load)
 1.00A  1.00A  74.00A  0.00A  0.00A  1014w /
889w
87.67%  50.4°C /
72°C
 21.6°C
 3.23v 4.91v 11.88v 4.90v -12.12v
With the temperature cranked up to 50°C and a re-run of all the previous tests, the EX-1200 showed no additional signs of strain, producing voltage and efficiency results almost exactly the same as those at room temperature. However, as highlighted by the red text in the temperature results, the EX-1200 got EXTREMELY hot in in tests 3,4 and 6 with the exhaust temperature coming close to 80°C at one point. Granted the ambient temperature was around 50°C, but this is still far higher than any other PSU we've ever tested in the past and is borderline capable of melting nearby objects!
BFG EX Series 1200w Scope Results @ 50c
   +3.3v  +5.0v  +12v
Test 1
(Low)
T1_3.3V T1_5V T1_12V
Test 2
(Med)
t2_3.3v t2_5v t2_12v
Test 3
(High)
t3_3.3v t3_5v t3_12v
Test 4
(Full) *
t4_3v t4_5v t4_12v
Test 5
(x-load)
t5_3.3v t5_5v t5_12v
Test 6
(x-load)
t6_3.3v t6_5v t6_12v
* During Test4 the scope configuration was changed from 20mV to 50mV to accomodate the EX-1200's large waveforms.
Finishing up with the scope readings taken during the 50°C tests, both the +3.3v and +5v rails remained well within acceptable limits, only hitting 28mV and 30mV respectably during test 4. The +12v rails on the other hand were a completely different matter! Bearing in mind that these results are a combination of all four rails attached via both modular and hard-wired connectors, the result of 92mV during test 4 is quite worrying to say the least. Granted ATX spec requires the +12v rails to stay below 120mV in order to stay within specification, but this is still by far the worst result of any PSU tested on OC3D thus far.
Now let's move on to the conclusion where I attempt to sum up the previous few pages.
«Prev 1 2 3 4 5 Next»
10-06-2009, 13:12:31
Jim
"BFG sure know a thing or two about making graphics cards, but how does their latest 1200w power supply cope under the strain of the OC3D load tester."
http://www.overclock3d.net/gfx/artic...070705659s.jpg
10-06-2009, 14:02:03
monkey7
Hmm bit of an average psu
An 8 for presentation though? Yes the packaging and bundle is quite good but isn't the paint part of the presentation?
10-06-2009, 14:41:58
zak4994
Box packaging looks exceptionally bland.
10-06-2009, 15:06:53
lasher
Could come wrapped in brown paper for me.
All i would be bothered about is the performance, which from the review it comes out admirably.
Its rare ive seen cases with the power supply on view when windows are fitted.
It could look like Amy winehouse for i care.. long as it performs. ( Hmm perhaps a bad comparison there but im sure you get my drift )
Know what you mean about the paint, My Antec 1000w Quattro is sprayed and just looking at it, it threatens to scratch the paintwork. Would only possibly affect the resale value in the long run though.
26-06-2009, 02:26:08
kimandsally
I think that 92mv is not as bad as it seems, to be honest if it is the highest seen on here that says only high quality PSU's have been tested there are dozens of PSU out there with higher ripple.
I agree though for a premium product which has Jonny Guru's input at BFG it's not too good, I would certainly not spend my money on one there are many better PSU out there.
As usual though great review.
