ASUS U-75HA 750w ATX PSU
Test Config, Voltages, Efficiency & Temperature
Published: 24th January 2009 | Source: ASUS | Price: N/A |
To provide our readers with the most accurate results, Overclock3D uses a professional grade SunMoon SM-268+ ATE load tester capable of placing a sustained load of 1690w across a total of six rails (including +5vsb and -12v) on the PSU. Unlike our previous resistor based load tester the SM-268+ gives us the ability to adjust amperage loads in increments as small as 0.01A while also measuring voltages and wattage readings on-screen.
During todays tests we will be placing the U-75HA under 25%, 50%, 75% and 100% load levels and taking voltage readings at every stage. The chart below details the exact amperage load placed on each rail of the PSU at the aforementioned load levels:
| Input Load | ||||
| 25% | 50% | 75% | 100% | |
| +3.3v | 6.06A | 12.12A | 18.18A | 20.0A |
| +5.0v | 5.00A | 10.00A | 15.00A | 17.50A |
| +12v1 / +12v2 * | 6.75A | 13.50A | 20.25A | 25.00A |
| +12v3 / +12v4 * | 6.75A | 13.50A | 20.25A | 25.00A |
| +5vsb | 0.875A | 1.750A | 2.625A | 3.50A |
| -12v | 0.175A | 0.350A | 0.525A | 0.60A |
| Total ** | 215.8W | 429.0W | 641.8W | 764.0W |
* Rails 1&2 and 3&4 on the U-75HA have been combined during testing on the SM-268+ due to a limitation with the testing equipment. However, as the U-75HA features only one +12v transformer this becomes irrelevant as we are effectively re-joining virtually split rails.
** Total wattage is taken directly from the SM-268+ readout rather than a calculation of the amperage loads.
Voltage Readings
Now that we've seen exactly what load we're placing on the U-75HA let's see how it performed...
| Output Voltage | ||||
| +3.3v | 3.30v | 3.26v | 3.22v | 3.14v |
| +5.0v | 5.04v | 5.01v | 4.97v | 4.89v |
| +12v1 / +12v2 | 12.16v | 12.12v | 12.08v | 11.89v |
| +12v3 / +12v4 | 12.15v | 12.11v | 12.07v | 11.70v |
| +5vsb | 5.06v | 5.01v | 4.96v | 4.85v |
| -12v | -12.08v | -12.14v | -12.19v | -12.28v |
At 25% and 50% loads we get a chance to see the voltage output of the rails close to what they have been set at in the factory. Unlike some less reputable manufacturers, ASUS has chosen not to over-volt the rails in an attempt to keep voltage readings looking good when a heavy load is applied. Both the +3.3v, +5.0v and +12v rails sit comfortably within 2% of their ideal voltages.
Moving on to 75% load the voltages take a small dip, but aside from the slightly low 3.22v output from the +3.3v rail there's nothing much to worry about.
Finally at 100% load everything goes down hill with +3.3v rail coming extremely close to falling outside the ATX +/-5% requirement. The +12v3/4 rails also take quite a dip down to 11.70v which is still within ATX spec but would have most hardcore enthusiasts running for the hills. All other rails remain reasonable, but the performance certainly isn't anything to shout about.
Efficiency Readings
Efficiency tests are performed by measuring the wattage consumed by the power supply at the mains (Mains Draw) against the wattage readout displayed on the SM-268+ load tester (PSU Load). These results should offer around 99% accuracy placing them extremely close to results obtained from professional equipment.
| Efficiency | ||||
| Mains Draw | 256w | 499w | 752w | 917w |
| PSU Load | 215.8w | 429w | 641.8w | 764w |
| Efficiency | 84.29% | 85.97% | 85.34% | 83.31% |
ASUS claim that the U-75HA is capable of up to 86% efficiency and judging by the results we obtained this is certainly very close to the truth. At 50% load the U-75HA was drawing a total of 499w from the wall socket and the SM-268+ load tester was reporting a load of 429w. By taking both of these figures and applying some simple math (Load / Draw * 100) we arrive at a result of 85.97% efficiency.
Considering that most mid-range PC systems with single high-end graphics cards will consume somewhere in the region of 450w its good to see that this is where the ASUS delivers its best results.
Temperature Readings
As with all components in the modern computer system, the performance of a PSU can be directly affected by heat. Excess levels of heat recorded at the PSU's exhaust can indicate that the cooling system is inadequate in keeping the PSU's internal temperature under control which can subsequently lead to a reduction in the maximum power output of the unit. For this reason Overclock3D takes temperature readings from the PSU's intake and exhaust areas after 10 minutes of running at each specified load level. These results can be seen below.
| Temperature | ||||
| Intake | 19.9°C | 19.6°C | 20.1°C | 19.7°C |
| Exhaust | 22.4°C | 24.9°C | 26.3°C | 29.3°C |
| Delta-T | 2.5°C | 4.9°C | 6.2°C | 9.6°C |
With a maximum exhaust temperature of 29.3°C when under 100% load, the U-75HA certainly doesn't show any signs of overheating. This is undoubtedly down to the high efficiency of the unit (less energy being wasted as heat) and the 135mm fan. Even at 100% load, the U-75HA hardly increased the fan speed to combat the additional heat and as a result the unit remained fairly quiet. While we would like to make an official comment on the noise output of the unit, the SM-268+ load tester is far too noisy and prevents any measurements - subjective or scientific from being taken.
Future Tests
In our continuing efforts to increase the quality and accuracy of reviews here on Overclock3D we recently invested in professional PSU load testing equipment. However, while this allows us to place accurate load levels on a PSU during testing there are still several areas for improvement that you will see from us in the near future:
• Heat chamber testing. All PSU testing will be conducted at a standard temperature of 50c.
• Digital Oscilloscope. For measurement of ripple and line noise.
• Variable AC Transformer. For conducting PSU reviews at both 240VAC and 120VAC mains voltages
• Digital Tachometer. To observe fan speed as temperature and load increase.
• Noise Recordings. Allow readers to experience the noise emitted from the PSU for themselves.
Providing we still have access to the ASUS U-75HA once our updated testing suite is in place we will be sure to update this page of the review with the additional results.
So this fails at 100% load (outside the ATX standards which lets face it are pretty lax) on the 3.3V rail and the 12V is down a long way too. I wouldn't use it with my rig (even if it provided enough power, but you get the point). In my books, Asus should have put it at 700W or so to ensure it didn't go outside the ATX standards. In addition, its dissapointing to see a no name fan and 85C capacitors.
All in all a bit of a dissapointing product. I'm not sure it deserves the 7.5 performance really.
Still nicely presented and great review, nice to see temperature readings and finally have a look at the PSU tester.
Asus are an odd company. Their hardware is usually brilliant, their software less so. They've done well to build up a loyal fanbase but seem to be hoping to work on name value alone with this. Strange.
Great to see the new bit of kit put to good use. Power supplies are something people tend to overlook when buying hardcore hardware, even though it's the heart of the machine, so to get some serious numbers is fantastic!
VB
VB
It seems that this one would be one to avoid, just on the 3.3V line and 11.70V. The PSU is the thing that can cost the most if it goes wrong, so why skimp on it?
first when i saw this review i said to myself: "wow, asus making psu's now? must be pretty good" but after reading i take that back with all i could
like Diablo said, it should be 700W so it wount failt at 100% since it couldn't take the atx standards.
Also when i read DELTA i said: "god there's a delta as psu fan
", but it wasn't so i had to take back again (at least it was running cool even with that "unkown" fan), and im getting full of taking back everytime i read a phrase
. So i stayed quiet and finished reading without saying anything (and it was hard, belive me
after i readed it all, i can say that if it's not alot cheaper (half at minimum) of the price of a corsair 620, its not a good idea buying it, at least for me.
ops forgot (edit time)
great review Jim pretty objective, you told us about every thing in every spot of this psu, sadly it isnt an awesome one but thats asus fault lol.
. after i readed it all, i can say that if it's not alot cheaper (half at minimum) of the price of a corsair 620, its not a good idea buying it, at least for me.
Christ, you guys sure do plan on being the most thorough PSU reviewers ever, don't you!
Not that I am complaining of course; I really look forward to seeing some of the data/results!
Fantastic review Jombo, shame that the PSU can't quite stand up to the pain
Not that I am complaining of course; I really look forward to seeing some of the data/results! |
U don't get these kind of reviews anywhere else afaik, and it is good to know that it may fail to hold a volt at 100% load. That is if u plan on running ur pc @ 727w+ for long periods. Chances are many wouldn't, even high spec'd sli/xfire rigs don't burst over 600w. To that extent, u'd buy it and have no complaints I'd expect.
If the price is a good one and u appreciate giving ur rig an overhead, u would probably do well with the U-75HA.
However, I don't see the price being a good one, and as the great review says, it's not exactly a unique psu.
Wonder who might make it for them, it looks pretty bland. A flashy ASUS logo splashed on it might add to sales just for the heck of it - maybe even a kinky fan feature or summit.
Great stuff.
I'm a bit dissapointed, its no modular, so you have a rats nest in your pc and if you do have a high power system (mine for instance) you can easily eat up 750W no probs.
Cheers for the feedback guys
TBH I was REALLY hoping that ASUS might use their Republic of Gamers brand on the PSU. Something sexy and modular in black + red/blue using well over-spec'd components etc...you know the deal.
I just cant see the idea behind entering the PSU market with something thats even more bland than a lot of the competition and doesn't even really have the stability to keep up with the big boys either.
Nice review Jim.
I think what needs to be remembered, is that it's ASUS' first step into the PSU market...very few people get it right first time.
It might not be the best PSU, but it's certainly not a bad one...it'll be interesting to see what the next generation of PSU's is like.
-VK-
-VK-
Umm....I'd like to make a correction. You say that CapXon is by no means a cheap brand, well...it is. CapXon is utter crap. It's used widely BECAUSE IT IS CHEAP. The only companies considered to be very good quality are: Nippon Chemi-Con, Nichicon, Rubycon, Panasonic (Matsushita), Sanyo, Elna, Mallory/ Cornell Dubilier.
Teapo is meh, and typically do alright in Power supplies. Samxon is pretty good, and it's either hit or miss. Most of the time they do very well. CapXon is crap though. They are close to Fuhjyyu.
For a list of bad capacitors, please refer to this: http://www.badcaps.net/forum/showthread.php?t=388
For a list of good capacitors, please refer to this: http://www.badcaps.net/forum/showthread.php?t=414
http://www.overclock3d.net/gfx/artic...212703361s.jpg
