Aspire Chameleon 550w PSU
Specification
Specification
Specification taken directly from Aspire's website:
* Aluminum casting for best cooling
* LED color switch changes the fan colors
* High quality colorful components and materials ensure superior performance and appearance
* Excellent ventilation:1 x 120mm uv blue LED fan and punched out side panels for excellent cooling
* Super silent:1 x fan speed controller optimizing cooling while reducing noise
* Wire management:fully sleeved cables to avoid clutter and improve airflow
* Supports ATX Intel 12V V1.2 and AMD systems
* All connectors, switch and wire sleeves are uv green reactive
* Protection:Short circuit/ Under voltage/ Over voltage/ Over current/ Over power/ Electric-shock free protection
* Safety approval:UL, CSA, FCC, CE, CB, TUV
* High efficiency and reliability
* Low noise and ripple
* 100% Burn-in test/ Hi-pot test/ Viibration test/ Leak Current test
Aspire 550w Specs
«Prev 1 2 3 4 5 6 7 Next»
25-04-2006, 07:01:36
JN
Looking for high power and 'bling' to match? We test out Aspire's PSU, so see if it cuts the mustard.
Review HereQuote
25-04-2006, 07:11:48
WC Annihilus
Nice review man. Shame bout it, though as you said, should make a decent alternative to generics for lower level rigs.Quote
25-04-2006, 15:19:26
NickS
I've had one before, the 20p version. I bought it back when I had my P4/6800 rig, to replace my Enermax 350w. I didn't replace it cause I needed to but because I was going to upgrade to s754 soon and I wasn't sure. So I got it, popped it in, and ran 3D01. It emitted a LOUD high pitched squeal but was stable. So, I RMA'ed it and got another one. Same thing! So I RMA'ed that and demanded it be replaced with the Enermax Noisetaker 420w that I had for so long.
Yeh, they aren't that good . Nice review, XMS . Very thorough.
NickQuote
