Edimax Wireless nLITE High Gain USB Adaptor
Published: 23rd March 2009 | Source: Edimax | Price: £19.73 |
The humble wireless network adaptor is often something that is overlooked by it's users. As long as it does it's job, then the user is happy. After all, there isn't much to distinguish one model and brand from the other. Or is there? With this question in mind, we will be taking a close look at the Edimax Wireless nLITE High Gain USB Adaptor. Before we take a look at the new adaptor, let's find out about Edimax:
(taken from the Edimax website)
The new adaptor has generated some good sales figures since it was released, with over 3000 units being bought by resellers on just the first day of release. With it's mix of up to date features and a competitive price point, it looks like Edimax are on to a winner with their new wireless adaptor. Time to take a closer look now, and see exactly what it has to offer.
Specifications and Features
• Complies with wireless 802.11b/g standards
• Compatible with wireless 802.11n standard with data rate up to 150Mbps
• Increases wireless coverage 3 times further
• Rotatable Antenna: 90 degree of vertical angle and 180 degree of horizontal angle
• Includes multi-language EZmax setup wizard
• Supports 64/128-bit WEP, WPA , WPA2 encryption and WPS-compatible
| HARDWARE INTERFACE | STANDARD | FREQUENCY BAND |
| • 1 USB 1.0/2.0 Type A • 3 dBi High-Gain rotatable antenna | • IEEE802.11b, 802.11g | • 2.4000~2.4835GHz (Industrial Scientific Medical Band) |
| DATA RATE | INSTALLATION | LED |
| • 11b: 1/2/5.5/11Mbps • 11g: 6/9/12/24/36/48/54Mbps • 11n (20MHz): MCS0-7 (up to 72Mbps) • 11n (40MHz): MCS0-7 (up to 150Mbps) | • Multi-language EZmax Setup Wizard | • Link/Activity |
| SECURITY | DIMENSION | HUMIDITY & TEMPERATURE |
| • WEP 64/128, WPA, WPA2 • Cisco CCX Support • WPS configuration | • 15(H) x 15(W) x 155(D) mm | • Max. 95% (Non Condensing) • 32~104°F (0~40°C) |
| SYSTEM REQUIREMENTS | OUTPUT POWER | CERTIFICATIONS |
| • Windows 2000/XP/Vista, Mac OS | • 11n: 14dBm±1dBm, • 11g: 14dBm±1dBm, • 11b: 17dBm±1dBm | • CE, FCC |
Moving on, let's see what you get for your money and take a look at the packaging and contents on the next page.
I'm interested if that "woohoo" "high gain!" antena unscrews.
Good review by the way too mate.
Quick thing though, did ya kinda miss a sentence off the end? No info on where to buy it for the £19.99 price.
Also the forum link at the bottom isn't a link :)
Bungral, done and done :) Cheers mate.
Nice work Stu :)
Any chance of asking Edimax if they plan to offer 'tux drivers??
