Edimax nMax Wireless 802.11n Gigabit Router
Testing the BR-6574n
Published: 15th April 2009 | Source: Edimax | Price: £59.98 |
Here is our test system setup:
Asus P6T using:
- Onboard Realtek® 8111C PCIe Gigabit LAN controller featuring AI NET2
Wireless router
Client PC
Sony Vaio using:
- Edimax Wireless nLITE High Gain USB Adaptor
- Onboard Realtek® RTL 8139 LAN controller
Testing of data transfer rates
I will be transferring a 701MB AVI file from the host to the client PC, testing the router for data transfer rates. The transfer will be run at 802.11n mode and via gigabit ethernet. At the time of writing this review, I did not have another router to be able to draw comparisons with, but the test results will be a good indicator of performance. As the only wireless 802.11n adaptor I had to hand was the Edimax nLite USB adaptor, the maximum data rate would be limited by the wireless adaptor to 150Mbps. Full speed 802.11n offers a maximum of 300Mbps, and the router is capable of this.
Testing of Wireless Signal Strength
As in the previous test, I can only test the router's wireless signal strength at 802.11g and half speed 802.11n modes. The results will still indicate the improvement of 802.11n in terms of signal strength though. I set fixed locations at set distances from the router and recorded the strength in dBm. It should be mentioned that the results shown here are not conclusive, as environmental factors can affect results. I tested in a victorian, 2 story house, with solid brick partitioning walls, and it does put any wireless network through it's paces.
The router clearly offers an increase in working range when in 802.11n mode, and I did not experience any network drop outs in either 11n or 11g mode anywhere within my property, something I have experienced with other routers and wireless adaptors. The data transfer rates were entirely acceptable, and the wireless connection would have shown an increased speed if I had been able to use a full speed 802.11n adaptor.
On the next page, I will give my final thoughts and scores.
The radio channels wouldn't really be helped by the dual 2.4/5.8 newer versions that are coming out, mainly as they're "meant" to be for media traffic devices. Only today looked at a view screen for a hd camera using the 5.8 freq to see the screen of the camera - it's pretty impressive. Ofc the 2.4g traffic doesn't afflict it. 2.4 being free for use does tend to get pretty crowded, but there are tools out there that will allow u to graphically see how busy the traffic is about u so that u can pick the best for ur setup.
Notice a trend of them looking similar to what the Apple wireless-n predicted router will look like. Believe this is coming in May. Perhaps with the wireless n-iPhones.
The price seals this unit for me. U can buy barely usefull wireless-g routers, with gigabit switches, for just under the price.
I'm w8ing for a d-link 855? unit with the dual radio, out of interest above the features also.
Great stuff.
I am thinking about upgrading from my aging Linksys Wireless G router. Would be nice to have a Gigabit network, and it's getting a bit haggered from all the wireless connections..
@Zak: When you see the panel in person, it ties in really well with the router. I think these routers with the LCD displays are a bit of overkill tbh, as a router is normally shoved on a shelf, under a desk or somewhere out of direct sight.
http://www.overclock3d.net/gfx/artic...173340790s.jpg
Read the full review here.
