Super Talent PC2-8000 DDR2 2GB Kit
Sandra, 3DMark06 & CS:Source
Search Reviews
Sandra, 3DMark06 & CS:Source Results
Once again we can see that the results from both the synthetic and 3D-based benchmarks are extremely similar regardless of the memory timings and frequencies used. As mentioned before this is largely down to memory speed not being the bottleneck in our test systems configuration.
However, it would seem that the most benefits to be had are by decreasing the memory timings, which in almost all cases offered marginally better results than running the memory at higher frequencies.
Super Talent PC2-8000 Sisoft Bandwidth Results Super Talent PC2-8000 Sisoft Latency Results
Super Talent PC2-8000 CSS Results Super Talent PC2-8000 3DMark06 Results
«Prev 1 2 3 4 5 6 Next»
10-01-2007, 15:31:29
Jim
"Super Talent may be relatively unheard of in the UK market but they are certainly no newcomers to the memory scene. Today I'll be looking at their high-end T1000UX25G modules to see how they fair in the fierce DDR2 market."
Linky
10-01-2007, 17:12:10
NickS
This is probably the first OC3D review I'm really saddened by.
XMS man, please if you have time retest these! GKX's should do 600MHz so easy!
Please make sure you were at
Twr - 6
Trrd - 5
Twtr - 3
The RAM should have done 600MHz 5-5-5-5-15 @ 2.5v.
At 1000MHz they should do
CAS - 4
TRCD - 4
TRP - 4
TRAS - 7 (Or Lower, try 6, 5 & 4.)
TRC - 12
TWR - 6
TRRD - 5
TWTR - 3
With 2.2-2.35v.
If the BIOS doesn't have the proper RAM settings available, you can get Memset.
Oh, and test with active cooling (of some sort). D9 pumps out a lot better results with a breeze.
GL man.
10-01-2007, 18:00:08
Jim
Twr - 6
Trrd - 5
Twtr - 3
CAS - 4
TRCD - 4
TRP - 4
TRC - 12
TWR - 6
TRRD - 5
TWTR - 3
With 2.2-2.35v.
GL man.
Its not having it i'm afraid mate. It does very little over 566mhz with stability.
As for active cooling - it makes it a bit unfair on previously tested modules.
10-01-2007, 18:52:54
NickS
Wow really? That's some TERRIBLE GKX then. Jeez. Most D9GMH does better.
Nevertheless, great review Jim
10-01-2007, 19:01:44
NoL
Could we see a different approach?
Possibly set for 4/3/3/8 and then go for max mhz at 2.4v vs just a show of a rating?
10-01-2007, 19:04:24
Jim
Looking around, many of the other reviews of these kits haven't done even 566mhz
I just tried again, and its a total non-booter at even 580mhz The 680i chipset has many more options over the P965/975X so mebe i'll explore some of those tomorrow.
10-01-2007, 21:14:00
NoL
Um Nicks, GKX generally wants more than 2.4V thats why.
11-01-2007, 05:01:46
Jim
Unfortunately it wouldn't even go down to 4-3-3-12 @ 2.4v
11-01-2007, 05:39:30
GrimReaper
Nice review Jim
looks like really badly bined GKX memory 4-4-4-12 at 2.4V
my memory does 1050 4-4-4-12 with 2.2V
cellshock GKX and GMH memory have 8 layer PCB this really helps them OC better and handle more voltages
11-01-2007, 23:25:32
NickS
8-Layer PCB is gimmicky IMO. If it was that good, other manufs would be all over it too.
@ NOL, I don't think GKX likes that much more voltage than GMH. All I know is, GMH is very sensitive to voltage and WILL degrade >2.3v.
11-01-2007, 23:29:57
NoL
8-Layer PCB isnt a gimmick, its been proven time in and time out to increase the tolerances and life span of the ram.
12-01-2007, 02:24:03
Pyr0
other manufacturers are starting to jump on the 8 layer pcbs for their highest kits like the ocz flexXLC mem and teamgroup pc2-9600 & pc2-8500 C4
as well as improving the voltage tolerance it also helps to decrease the ammount of noise, crosstalk and interference of signals allowing for more stable operation at higher speeds/voltages
