Patriot PDC32G1866LLK PC3-15000 2GB DDR3 Kit
3D/Rendering Results
Published: 22nd November 2007 | Source: Patriot | Price: £350-£360 |
Cinebench 10 is a benchmarking tool based on the powerful 3D software Cinema 4D. Consequently, the results of tests conducted using Cinebench carry significant weight when analysing a computer’s performance in everyday use.
3DMark is a popular synthetic gaming benchmark used by many gamers and overclockers to gauge the performance of their PC's. All 3DMark runs were performed 3 times with averages being calculated from each of the results.
Shame really. They could have been onto a real winner.
They given a response yet?
thats really quite pathetic that they couldnt even do what it said on the tin (well, plastic thing
)Hopefully Patriot will get back to you and swap out the sticks for another pair to test. Patriot doesn't seem like they'd BS their claimed speeds by as much as these differed.
board limitation, not ram
sorry, was meant to be a question, but i couldn't edit my post with a "?"
board limitation, not ram ? (
Something is holding something back by the looks of things. Feedback would answer some questions.
couple more questions
What is the max (stable) FSB for that Q6600?
What performance level were the tests completed at in the end?
And how much voltage did you try on the NB?
I found I ran out of NB voltage rather quickly on the P5K3 when testing some Ballistix... been thinking about trying a voltmod ever since lol (or buying/trying X38 or X48)
Here's some Ballistix at 2000 just for ref. (unstable)
http://www.overclock3d.net/gfx/artic...123527350s.jpg
Patriot PDP32G1866LLK Review
