Patriot PDC32G1866LLK PC3-15000 2GB DDR3 Kit
Test Setup, Settings & Overclocking
Published: 22nd November 2007 | Source: Patriot | Price: £350-£360 |
With DDR3 speeds ramping up on an almost weekly basis, It's extremely difficult to obtain two or more memory kits with similar specifications to perform any kind of worthwhile comparison. Therefore, the Patriot PC3-15000 kit will be placed up against the recently reviewed OCZ Platinum PC3-12800 kit with it's stock frequency, latencies and voltage changed to match the Patriot kit.
Patriot PDC32G1866LLK PC3-15000 | OCZ Platinum PC3-12800 | |
| Processor | Intel Core 2 Quad Q6600 "G0" 2.4GHz 2x4MB | |
| Motherboard | Asus P5K3 Deluxe | |
| Graphics Card | Sapphire Ultimate X1950 Pro 256mb PCI-E | |
| Hard Disk | Hitachi Deskstar 80GB 7K80 SATA2 7200RPM 8mb | |
| CPU Cooling | Stock Intel Aluminium Cooler | |
| Operating System | Microsoft Windows Vista Ultimate (Latest Updates) | |
| Graphics Drivers | ATI Catalyst 7.4.44981 | |
| Motherboard Drivers | Intel INF 8.300.1013 | |
To guarantee a broad range of results, the following benchmark utilities will be used:
Synthetic Memory Subsystem
• Sisoft Sandra XII 2008c
• Lavalys Everest 4.0
File Compression & Encoding
• 7-Zip File Compression
• River Past ViMark
3D / Rendering Benchmarks
• Cinebench 10
• 3DMark05
• 3DMark06
3D Games
• Quake 4
• Bioshock
• F.E.A.R
• River Past ViMark
• Cinebench 10
• 3DMark05
• 3DMark06
3D Games
• Quake 4
• Bioshock
• F.E.A.R
Test Settings & Overclocking
It is an unfortunate fact that many memory kits tested here at Overclock3D fall at the first hurdle by not being able to run with 100% stability at their advertised stock settings. Therefore the first test for the Patriot PDC32G1866LLK kit was to test their ability to run at 933mhz with 8-8-8-24 timings on 1.9v.
While the screenshots above appear to show the Patriot modules happily running at their stock speeds, we experienced no end of problems getting them to run stable at these settings. ..
On first installing the modules and manually setting the timings and frequencies on our P5K3 testbed, Windows constantly bluescreened during bootup. Remembering some of the settings used to stabilise the previously reviewed OCZ Platinum DDR3 kit, we switched the modules into DIMM slots A2 and B2 on the board and set the "Relax Level" to 3 in the BIOS.
This time the modules successfully booted into Windows, but on attempting to run any memory intensive benchmarks, the system once again blue screened. Not deterred by this, we switched out the Asus P5K motherboard for an Asus Blitz followed by an Asus Maximus - neither of which could add any further level of stability to the modules.
Finally, we changed back to the P5K3 motherboard and loosened several memory subtimings along with running the modules at a lower-than-rated 1.85v. This added enough stability for us to complete all benchmark tests without any errors but was far from ideal for any kind of 24/7 usage.
Needless to say that Overclocking was totally out of the question, but in the interest of completeness here's how they faired against the OCZ Platinum kit:
Shame really. They could have been onto a real winner.
They given a response yet?
thats really quite pathetic that they couldnt even do what it said on the tin (well, plastic thing
)Hopefully Patriot will get back to you and swap out the sticks for another pair to test. Patriot doesn't seem like they'd BS their claimed speeds by as much as these differed.
board limitation, not ram
sorry, was meant to be a question, but i couldn't edit my post with a "?"
board limitation, not ram ? (
Something is holding something back by the looks of things. Feedback would answer some questions.
couple more questions
What is the max (stable) FSB for that Q6600?
What performance level were the tests completed at in the end?
And how much voltage did you try on the NB?
I found I ran out of NB voltage rather quickly on the P5K3 when testing some Ballistix... been thinking about trying a voltmod ever since lol (or buying/trying X38 or X48)
Here's some Ballistix at 2000 just for ref. (unstable)
http://www.overclock3d.net/gfx/artic...123527350s.jpg
Patriot PDP32G1866LLK Review
