OCZ Platinum PC3-12800 (DDR3-1600) DDR3 2GB Kit
Sisoft Sandra, Everest & SuperPI
Published: 9th October 2007 | Source: OCZ | Price: ~£355 |
Sisoft Sandra is a synthetic benchmark utility capable of reporting and benchmarking a wide range of system components. For the OCZ platinum PC3-12800 memory we run both the Memory Bandwidth and Memory Latency benchmarks 3 times to ensure accuracy of results.
Everest is in many ways similar to Sisoft Sandra. Focusing mainly on Software and Hardware information reporting, Everest also comes with a benchmark utility suitable for testing the read, write and latency performance of the memory subsystem.
SuperPI is the benchmark of choice for many overclockers. It's lightweight to download and can give a quick indication on how good a system is at number crunching.
Result Observations
The first thing to note about the above benchmark results is that neither Everest or Sandra were able to successfully benchmark the Platinum PC3-12800 kit when it was running at its top speed of DDR3-1946. This certainly wasn't an issue with the stability of the modules, as they successfully completed several hours of SuperPI and Orthos testing. I can only assume that the results from the modules running at these speeds were beyond the programmed parameters of both benchmarks.
However, even without these results we can see that the OCZ Platinum PC3-12800 kit is blisteringly fast, managing not short of 10GB/s on the Everest Read benchmarks and a 52.2ns latency when overclocked on the Everest Latency benchmarks.
Very nice review Jim!
Now, lets sort out all those spelling mistakes.. hahahah got ya, only joking!!
None the less DDR3 is finally looking up.. but then you look at the price!
How good is that RAM? Absolutely insane!!! Once more peeps start adopting it and the price comes down a bit more I'm on it. Great review as usual Jim
Cheers guys. It is indeed some extremely fast ram. Now I'm tempted to crank it up to 2.1v under some water
i remember about 3 years ago, i mentioned watercooling ram on the forum, and everybody laughed at me, well, look at this now
Damn thats some smokin hot ram.
I won't get ddr3 until the price of 2gb is half that price!
*drool* much nicer stuff than these elpida, kingston sticks which top out at 1500MHz
http://www.overclock3d.net/gfx/artic...105337782s.jpg
OCZ Platinum PC3-12800 Review
