OCZ PC2-6400 Titanium 2Gb DC Kit
Published: 12th March 2007 | Source: OCZ Technology | Price: |
The OCZ PC2-6400 Titanium EPP DC 2Gb kit is a worthy addition for either the gamer or overclocker on a budget. Straight out of the box and ramping up the FSB on an Intel based motherboard produced better than average results, especially considering that this RAM is actually rated at 800Mhz. Sure the Titanium's chips aren't highly sought after Micron D9, but the ProMOS variant certainly give a very respectable account for themselves.
Unfortunately, due to not owning an nForce 590 based motherboard, I was unable to compare results. But I'd wager that the Titanium would perform just as admirably...especially with the additional benefit of being able to run CAS 4-4-4-15 1T latency with Enhanced Performance Profiles (EPP). The 1T command rate should give the EPP modules a boost over standard memory's 2T command rate.
Further, kudos to OCZ for providing the ability to run this ram up to 2.3v without voiding the warranty.
Summing up the overall performance of the OCZ PC2-6400 Titanium EPP XTC 2Gb kit is an absolute no-brainer. The modules are extremely sexy, they perform well out of the box and stay remarkably cool (thanks to their XTC heatspreaders); and they are extremely well priced.
Priced at around £128.66 at time of review from Komplett these modules are definitely recommended for someone who's looking for performance on a budget.
Pro's
+ Can run tight timings of 4-4-4-15 1T (nForce 590i motherboard reliant)
+ Very respectable overclock from DDR2-800 to DDR2-1100
+ Priced to sell
+ Lifetime warranty and EVP up to 2.3v.
Con's
- Initially a little fickle with my P5B Deluxe
Special thanks to OCZ for supplying the review sample
Discuss this review in our forum
I totally regret splurging exessive ammounts of cash on dominators when for about half the price I could get the same performance with these, well done OCZ
great review PV !!!! Those sticks definitely are nice. BTW 2.3V is the max Promos responds to neways , so you arent missing nething by not giving them more. 550 mhz is a great overclock for sure , especially for a mediocre price range memory.
Thanks |3ourne, and it's great to see you back.
Originally Posted by name='limqareb'
first nice review but made me think , i have 2 g.skill memory and run at stock 4-4-4-10 how come the rest arent at 10 ? , even after ocing i managed to tighten them to 10 and difference does it make higher freq or tighter timings
Originally Posted by name='MikeEnIke'
Great review peevles. Awesome cause i was looking for a cheap 2gig kit also.
Is it ok to ask in this thread if I would be better off with the tested RAM or would it be worth spending the extra on the Ocz GX XTC 2gb PC2-8800 DDR2 1100?
Originally Posted by name='PV5150'
Sorry Lim, but I'm not sure if I quite get what you mean. Your GSKILL ram defaults at CAS4 (or latency), the OCZ sticks will do the same running on an EPP enhanced mobo which is like an auto overclock per se', but they are specified to be run at CAS5 (5-4-4-15) on a non-EPP enhanced motherboard like my P5B. As far as the lowest latency and timings were concerned, that was the furtheset I could push them and still retain Prime and F@H stability. Any further increase in voltage or tightening of the timings resulted in blue screen or Prime/F@H failure. Does that clarify? If not lemme know, and perhaps rephrase your question a little.
Thanks Mike, glad you found it useful for a potential future purchase |
Nice read and great info for me thanks!
Found it very intresting and they beautiful!
Linkage
