OCZ PC2-6400 Titanium 2Gb DC Kit
Benchmarks
Published: 12th March 2007 | Source: OCZ Technology | Price: |
From the graphs below we can see that the Intel Core2Duo processor and P5B Deluxe chipset combination does not suffer from any kind of memory speed bottleneck and the larger speed increases can only be obtained by increasing the CPU speed.
I totally regret splurging exessive ammounts of cash on dominators when for about half the price I could get the same performance with these, well done OCZ
great review PV !!!! Those sticks definitely are nice. BTW 2.3V is the max Promos responds to neways , so you arent missing nething by not giving them more. 550 mhz is a great overclock for sure , especially for a mediocre price range memory.
Thanks |3ourne, and it's great to see you back.
Originally Posted by name='limqareb'
first nice review but made me think , i have 2 g.skill memory and run at stock 4-4-4-10 how come the rest arent at 10 ? , even after ocing i managed to tighten them to 10 and difference does it make higher freq or tighter timings
Originally Posted by name='MikeEnIke'
Great review peevles. Awesome cause i was looking for a cheap 2gig kit also.
Is it ok to ask in this thread if I would be better off with the tested RAM or would it be worth spending the extra on the Ocz GX XTC 2gb PC2-8800 DDR2 1100?
Originally Posted by name='PV5150'
Sorry Lim, but I'm not sure if I quite get what you mean. Your GSKILL ram defaults at CAS4 (or latency), the OCZ sticks will do the same running on an EPP enhanced mobo which is like an auto overclock per se', but they are specified to be run at CAS5 (5-4-4-15) on a non-EPP enhanced motherboard like my P5B. As far as the lowest latency and timings were concerned, that was the furtheset I could push them and still retain Prime and F@H stability. Any further increase in voltage or tightening of the timings resulted in blue screen or Prime/F@H failure. Does that clarify? If not lemme know, and perhaps rephrase your question a little.
Thanks Mike, glad you found it useful for a potential future purchase |
Nice read and great info for me thanks!
Found it very intresting and they beautiful!
Linkage
