OCZ Blade DDR3 PC3-16000 6GB Kit
Test Setup
Test Setup
For today's testing we will be using the Gigabyte EX-58 UD5, a mid-range Core i7 motherboard from Gigabyte that will allow us to push the memory on test to its absolute limit. Here's a breakdown of the rest of the components:
Intel Core i7 920 'Nehalem' @ 2.66Ghz
Gigabyte EX58-UD5
OCZ Blade Series CL7 2000MHz 7-8-7-20 3x2GB kit (CPU @ 2717Mhz)
Corsair Dominator GT CL7 1866MHz 7-8-7-20 3x2GB kit
Crucial Ballistix Tracer CL8 1600MHZ 8-8-8-24 3x2GB kit
Mushkin XP CL7 1600MHz 7-8-7-20 3x2GB kit
Patriot Viper CL8 1600MHz 8-8-8-24 3x2GB kit
Corsair Dominator CL8 1600MHz 8-8-8-24 3x2GB kit
Graphics Card
Nvidia 280GTX
GeForce 180.60
Gigabyte Odin 1200w
Operating System
Windows Vista Ultimate 64bit SP1 + Updates
For testing the memory we used a number of synthetic benchmarks and games:
Synthetic Benchmarks
  • Lavalys Everest 4.10
  • SuperPI mod_1.5
  • Sisoft Sandra 2009
3D Benchmarks
  • 3DMark Vantage
  • Far Cry 2
For the run of benchmarks, we will be comparing the OCZ Blade kit to all the other memory kits we have tested to date for the X58 i7 platform. Consideration needs to be given to the fact that the CPU was mildy overclocked to 2717MHz (see below), 51MHz above stock speed to attain the 2000MHz stock speed when viewing the results overleaf.
Starting from scratch we disabled on the settings that may affect the overclocked settings such as Intel Speed Step as well as disabling the C-State settings which may also affect some of the results in the benchmark testing phase of the review. Here's how the sticks look at stock speed:
stock cpu stock mem
With the kit already running at a mind boggling 2000MHz it was hard to imagine that the kit could possibly be pushed any further. However...
Yup you're reading that right! A massive 2128MHz was achieved by simply dropping the latency a notch to CAS8. This equals the previous best kit we reviewed, the Dominator GT and while both kits reached this scorching speed, the OCZ needed slightly less Vdimm to get there with a small jump from stock voltage to 1.68v. I tried getting the memory to go higher by slackening the timings further but it seems that either the motherboard just doesn't like anything above this speed (QPI limit?) or the memory has reached it's limit. No amount of voltage tweaks or setting adjustments could surpass this speed so with that in mind I returning the settings back to their stock values and then ran our suite of memory benchmarks to see how the modules compare.
Let's see how I got on...
«Prev 1 2 3 4 5 6 Next»
25-05-2009, 07:18:31
"Want the best performance? Got the money to pay for it? Then maybe you should check out our latest DDR3 memory kit review where we put the OCZ Blade through it's paces..." - by W3bbo
OCZ Blade DDR3 PC3-16000 6GB KitQuote
25-05-2009, 07:46:32
A very impressive kit there with some incredible bandwith figures, granted, at the price of a high end graphics card!
Excellent review w3bbo.Quote
25-05-2009, 07:53:31
This is the thing that bothers me about the cpu vS memory benching and testing.
A linked-to website, which has been a companion listing of all cpus in conditions, listing many hardcore intensive processing examples of how cpus compare to others ------- this qualifier out of the way.
On this listing, the comparisons of said cpus show no-difference in running memory kits in single/dual/tri arrangements when running the benches used - but appears to show 1 cpu triumphing over others and is accepted as "well that shows that these cpus are better than others".
Surely this is complete crap. Just as a starter, every1 will know that dual channel memory works more efficiently than single - that's a straight forward 64 bit vS 128 bit logical answer. Same as 2 disks in raid0 vS a single disk, as a loose example.
Now, if the cpu benches in the list are proving "it doesn't matter" - which is bollox imo, I'm sure the majority will agree, then surely the intensive hardcore professional benches they're using, the likes of video conversion, archive packing, are failing the test and the results are worthless.
These memory strips are obviously extremely good. The said site would have u believe that using 2 of these strips instead of 3 will have no-difference to professional apps being used on ur pc (which we have established is a load of crap).
Argument may be that the tests used are done in seconds where the differences in running various memory arrangements aren't appreciated - well that's crap too cos let's realize for a second that it's the 21st century, and although computers and software are moving at a snails-pace compared to the huge strides we would get in the past, these processes are actually done in seconds!
No account either of 12m cache vS 6m over periods - which makes a difference.
Awesome review, great set of memory, and two fingers to stoopid bench listing sites that people rely on to make points about "new tech".Quote
