OCZ Blade DDR3 PC3-16000 6GB Kit
Packaging & Appearance
Published: 25th May 2009 | Source: OCZ | Price: £344.99 |
The packaging of the OCZ Blade kit is understated yet better than most manufacturers have managed to muster. The front of the outer box is a glossy black and grey affair with a telling slogan: 'The best performing DDR3 Memory on the market. Period'. That remains to be seen however if the packaging is anything to go by, there are certainly encouraging signs. The rear of the box goes on to describe the quality assurance of the package as well as customer support.
The modules are presented in blister style packing that protect from both static and scratches to the product. Along with the individually packed modules is an instruction leaflet explaining how to install the modules in the correct manner while avoiding anti-static discharge.
Here we see the three modules free from the blister packs in all of their glory. The heat sinks seem to be aluminium but also feel much heavier than that alloy. Swathed in a brushed black effect, the memory sticks certainly look very appealing with the chrome effect log emblazoned on the front of the modules.
The memory heat sink on the modules comes in two parts (pre-built) and screwed together very tightly, so much so I could not release these screws to get a sneak peek of the integrated chips beneath. The top side of the cooler is curved in design with fins uppermost that should dissipate heat very well. The rear of the modules is flat black and here is where you will find those pesky screws should you wish to replace the stock heat sink although I cannot think why you would want to as the stock heat sink should be more than capable of cooling the memory down.
A small stick is affixed to the front of the modules displaying the specification of the kit along with the serial number. In this case the specifications are of the top end kit - CAS7-8-7 @1.65v 2000MHz PC3-16000.
With the memory profile now visible you can see just how unique this cooler is with the curved metal covering the front of the memory stick formed into fins that wrap around the product. This curvature obviously adds width to the Blades form but not so much so that each module cannot be placed side by side, even if you choose to run this kit in a 12GB configuration.
So then, a very attractive and well presented 6GB kit. I do like the matching black heat sink and black PCB which oozes class and even though the metal 'fingers' are gold as standard in every kit, there's something about black and gold that just screams quality. I would be interested to know just how well the heat sinks keep the kit cool as other manufacturers seem to prefer adding a separate cooler, not only to keep the memory cool but to enhance the longevity of the product. Nevertheless, nobody can deny that this kit is a lush piece of equipment that will satisfy the design freaks out there and as a bonus, because black goes with everything, should match anybodies motherboard be it black, blue or red.
Let's take a look at our test setup that I will be using to test the kit out today...
A very impressive kit there with some incredible bandwith figures, granted, at the price of a high end graphics card!
Excellent review w3bbo.
This is the thing that bothers me about the cpu vS memory benching and testing.
A linked-to website, which has been a companion listing of all cpus in conditions, listing many hardcore intensive processing examples of how cpus compare to others ------- this qualifier out of the way.
On this listing, the comparisons of said cpus show no-difference in running memory kits in single/dual/tri arrangements when running the benches used - but appears to show 1 cpu triumphing over others and is accepted as "well that shows that these cpus are better than others".
Surely this is complete crap. Just as a starter, every1 will know that dual channel memory works more efficiently than single - that's a straight forward 64 bit vS 128 bit logical answer. Same as 2 disks in raid0 vS a single disk, as a loose example.
Now, if the cpu benches in the list are proving "it doesn't matter" - which is bollox imo, I'm sure the majority will agree, then surely the intensive hardcore professional benches they're using, the likes of video conversion, archive packing, are failing the test and the results are worthless.
These memory strips are obviously extremely good. The said site would have u believe that using 2 of these strips instead of 3 will have no-difference to professional apps being used on ur pc (which we have established is a load of crap).
Argument may be that the tests used are done in seconds where the differences in running various memory arrangements aren't appreciated - well that's crap too cos let's realize for a second that it's the 21st century, and although computers and software are moving at a snails-pace compared to the huge strides we would get in the past, these processes are actually done in seconds!
No account either of 12m cache vS 6m over periods - which makes a difference.
Awesome review, great set of memory, and two fingers to stoopid bench listing sites that people rely on to make points about "new tech".
Looks some great RAM, bit pricey, but you get what you pay for I guess. 12GB might be a little pricey tho
Could you rerun that last far cry test because that overclock will obviosuly massively affect the results?
Re run it in what way? You can't have DDR3 running at 2000MHz with the CPU at stock speed I'm afraid. It's either 2180 or 1866
.Fantastic review mate and a scrummy looking piece of kit. Luff OCZ RAM (8GB myself
)Quote:
lol, no worries m8. Tbh it's a pita reviewing kits that need the CPU overclocking to attain the speed required as you are correct, it does skew the results slightly hence I put the disclaimer in there.
Still, the bandwidth results speak for themselves
.sweet looking and performing set of sticks
pitty they don't add some kind of 'dominator fan'-like thing
Yeah that is a shame as the Dominator coolers are sweet pieces of kit. I would maybe like to have seen one of OCZ's XTC coolers included with a nice black paint job.
Hate to seem ungrateful (which I am not, since I loved this review), but I would be very interested to know if you could drop the latency at all while retaining the stock MHz, or see how much you would have to drop the MHz to get some lower timings. Just for the sake of completeness.
Shame we can't find out what chips it is running. Anyone happen to know by any chance?
IC's used are reportedly Elpida MNH-E Hyper which are the best around at present.
I did try lowering the timings further but not by lowering bandwidth (which defeats the object of high speed ram imo). Sadly they wouldn't run at anything lower than the stock CAS7 @2000MHz.
http://www.elpida.com/en/index.html
Not as well known as other memory companies.
I can verify that their "el-cheapo" memory rocks http://forum.overclock3d.net/picture...463581&thumb=1
I did try lowering the timings further but not by lowering bandwidth (which defeats the object of high speed ram imo). Sadly they wouldn't run at anything lower than the stock CAS7 @2000MHz. |
I am so very tempted to save up and fork out for some near Christmas. I finally plan on watercooling my NB and Mosfets as well as my (current) CPU and 4870X2. I think these sticks would do me wonders in reaching the highest overclocks possible. Only the best will do :P
http://www.overclock3d.net/gfx/artic...140625597s.jpg
